Stuck in DFU mode
- Hiflyer
18 Oct 2019 04:03 - 18 Oct 2019 07:11 #75274
by Hiflyer
Stuck in DFU mode was created by Hiflyer
I have got a problem with Deviation and my Devo 10.
Some models were corrupt and so I thought it would be a good idea to renew the Deviation 5.0.0
After copying the files to the Devo I had to format the drive on the devo, the space on the
radio couldn't be read neither from my computer, nor from my laptop.
So I formated and thought after that I can copy the files again. From there on the horror began.
After formating the first time, I had the format again and again the space on the devo couldn't be read.
To fix this problem I took the Dfuse tool and flashed the deviation5.0.0.dfu on the radio, and now he stays in
the DFU mode... After flashing the radio reboots for 1 second and switches to the DFU mode again. Clicking the leave
option in the DFuSe doesn't work either. The Radio has no USB mode. After flashing, the Power on button + ENT has the same effect
as only Power on and the same as PowerOn + EXT, namely "Programm Update ....". He is stucked in the DFU...
Is there anything I can do? I tried Walkera Firmware and other Deviation versions, every time he stucks in the DFU mode.
I also tried other Version like Dfuse 1.7 and 2.31 and other Deviation 4.0.1. Battery was unplugged for 24 hours, same problem.
Last edit: 18 Oct 2019 07:11 by Hiflyer.
18 Oct 2019 08:39 #75275
Replied by vlad_vy on topic Stuck in DFU mode
Are you sure that you use "Upgrade" button at Dfuse tool? If you use "Upload" button, the firmware file will be corrupted and you will need download it again.
- Hiflyer
18 Oct 2019 08:59 #75276
by Hiflyer
Replied by Hiflyer on topic Stuck in DFU mode
yes 100% sure..
18 Oct 2019 09:22 #75277
Wrong firmware? deviation-devo10-v5.0.0?
- Hiflyer
18 Oct 2019 10:28 #75278
by Hiflyer
no.. it's the right firmware...
I saw other guys had exactly that problem too with the devo 10... They took another dfuse tool and another firmware and it worked for them.
www.deviationtx.com/forum/3-feedback-que...in-update-mode#12179
that's my problem.. i tried all of it... another dfuse another firmware...
i tried "Verify after Upgrade" and got an error...
maybe the flash memory has a problem...
brand new devo 10..
luckily i have another Devo 10 where everything works wonderful...
brand new devo 10..
18 Oct 2019 12:28 #75279
Look on images at
www.deviationtx.com/forum/3-feedback-que...in-update-mode#64168
Focus to:
1) File information -> Targets in file -> Firmware: Internal Flash
2) Transfer data size = 20 bytes
If you have the same case, the firmware file is damaged.
Focus to:
- Hiflyer
18 Oct 2019 13:59 - 25 Oct 2019 10:10 #75280
by Hiflyer
YEAAA, i got it!!
You will never believe what the problem was...
It was the cable! I took my EDIT: PS3 (not PS4)Cable and everything worked first try...
unbelievable
very happy now.. took me 2 days to find that out
unbelievable
Last edit: 25 Oct 2019 10:10 by Hiflyer.
Time to create page: 0.054 seconds
- Stuck in DFU mode
