Blade 150S cyclic to throttle mixing
14 Feb 2020 02:44 - 14 Feb 2020 02:45 #75918 by Timbo77
Blade 150S cyclic to throttle mixing was created by Timbo77
On my T8SG V2 plus I have racked my brain on how to do this!!! The new 150S asks for the mixing I am guessing as to not bog down during acro.
Please help me figure this out!
Thanks!!!
Last edit: 14 Feb 2020 02:45 by Timbo77.
15 Feb 2020 05:33 #75923 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Blade 150S cyclic to throttle mixing
Hi
you might be able to do this with a complex mixer set up on Ele and Ail and add 20% to the throttle channel.
I have never done something like this before, in earlier days for the Acro Mode a V-shaped curve was programmed for the throttle channel if you didn't have a ESC with Govenormode. But the Blade 150S has one, you can see it on the throttle channel at position 2 of switch B, 90% in all 5 positions.
Personally, I would first change the throttle channel settings (e.g. Sw B with 100% on all 5 points) and try to determine if the power is sufficient for my flying style. More than 100% throttle is also not available by mixing.
15 Feb 2020 08:41 #75924 by -=Hubi-Dirk=-
Maybe i got a solution. It is made on a Devo 12s with Deviation 5, a Nightly from December. Have a try at the T8SG.
16 Feb 2020 06:28 #75932 by Timbo77
Replied by Timbo77 on topic Blade 150S cyclic to throttle mixing
Thanks, I will give it a try, I was trying to set aileron and elevator to cyclic 1, 2 respectively, it then gives you throttle cyclic - aleron and elevator mixing options prior to virtual channels. I then set DR/expo but no where can I see how to mix 20% throttle. Plus, the cyclic was all wonky and nothing moved correct.
16 Feb 2020 09:32 #75933 by -=Hubi-Dirk=-
Don´t forget to program this also for Ail ;) At page 1 and page 2 you can give Expo at "Curve" for Ele and Ail. Never use DR, in extrem Situations you will be thankful to have the maximum steering option! I use cyclic at Helicopters with Paddles, not for one with stabilisation.
10 Sep 2020 04:05 #76774 by txinsuranceguy
Replied by txinsuranceguy on topic Blade 150S cyclic to throttle mixing
Hi :) did you get it to work? would you be willing to share your INI file? i'm not able to figure it out for my 150S.
10 Sep 2020 05:23 #76775 by Timbo77
No, flew very unstable. Ended up getting a used dx6
10 Sep 2020 05:24 #76776 by txinsuranceguy
i'm surprised the 230's ini wouldn't work. dang.
08 Oct 2020 09:34 #76865 by PaulB
Replied by PaulB on topic Blade 150S cyclic to throttle mixing
This is my .ini for my 150S and it works fine, TH on G, Panic (Recovery) on H, Flight modes (3) on D and throttle swash mixing on.
File Attachment:
File Name: model30.ini
File Size:8 KB
Time to create page: 1.390 seconds
