Delay in one mixer
14 Sep 2020 14:24 - 14 Sep 2020 15:45 #76780 by Adriaan
Delay in one mixer was created by Adriaan
is it possible to prog a delay (pitch for example) for only one mixerpage an not only in general for pitch?
Im flying an OMP2 EXP, this one has a Att. Mode wich stabilizes the heli. When I pull switch I go from 3d to Att. Mode, so the heli levels itself. It would be helpful to do this with pitch 0 for 0.5 seconds, and after this 0.5 seconds and the OMP leveld itself I want to yous a hover pitch.
Sorry for my english, I hope you understand what I mean ;-)
Last edit: 14 Sep 2020 15:45 by Adriaan.
14 Sep 2020 20:20 #76782 by propnut
Replied by propnut on topic Delay in one mixer
Look at section 9.2.6 of the manual - Complex Mix Type. You will find delay there. Use a virtual channel to assign this to a switch position.
15 Sep 2020 04:28 #76785 by Adriaan
Replied by Adriaan on topic Delay in one mixer
Hi on 9.26 I only find Symax protocols" www.deviationtx.com/manuals/html-devo8-e....html#protocol-symax "
15 Sep 2020 04:44 #76786 by Gerry
Replied by Gerry on topic Delay in one mixer
Wrong manual, try this one.
www.deviationtx.com/user-manual/user-manual-7e-10
section 9.2.x
FFS (Forever Fixing Stuff)
19 Sep 2020 21:23 - 20 Sep 2020 16:19 #76802 by Sevych
Replied by Sevych on topic Delay in one mixer
Hi Adriaan,
I use Devo 7e, 3-in-1 module, two additional switches (G0/G1 and H0/H1), S-FHSS satellite.
Rescue mode for M2 include 2 steps:
1 Pull G0 switch to G1, it will send "+100" to channel 5 (you can use any other switch, of course)
2 After "0.2" sec, set up value of channel 6 to "53" (by scale from -100 to 100)
channel 5 - set FBL to attitude/3d mode
channel 6 - standart Pitch channel (in this setup, gets value from virt1 channel)
virt1 - with G0 switch active, simply send THR value to channel 6,
with G1 switch active, after "0.2" sec delay (4*0.05 sec), set virt1 channel to "53" (see 9.2.6 section of manual for delay mux type explanation)
In turn, value of virt1 channel ("53"), will be used by channel 6 as THR, what give us a constant little positive pitch.
Both values (delay and pitch) need to be tested in practice.
Part of ini file (referring rescue mode setup):
[channel5]
template=complex
[mixer]
src=SW G0
dest=Ch5
switch=SW G0
curvetype=fixed
[mixer]
src=AIL
dest=Ch5
switch=SW G1
scalar=-110
usetrim=0
curvetype=fixed
[channel6]
template=complex
[mixer]
src=Virt1
dest=Ch6
switch=FMODE0
scalar=83
usetrim=0
curvetype=5point
points=-30,-10,12,52,100
smooth=1
[mixer]
src=Virt1
dest=Ch6
switch=FMODE1
scalar=83
usetrim=0
curvetype=3point
points=-100,0,100
[virtchan1]
template=complex
[mixer]
src=THR
dest=Virt1
switch=SW G0
usetrim=0
[mixer]
src=THR
dest=Virt1
switch=SW G1
scalar=53
usetrim=0
curvetype=fixed
[mixer]
src=ELE
dest=Virt1
switch=SW G1
scalar=4
usetrim=0
muxtype=delay
curvetype=fixed
Any questions/advices are welcome.
Sry my English :side:
Upd: Better value of pitch in rescue mode is 53 (previus was 20) - set in second mixer of Virt1 channel
Last edit: 20 Sep 2020 16:19 by Sevych.
Time to create page: 0.039 seconds
