How to assign roller dial to channel t8sg v3 plus.
10 Sep 2021 03:45 #77547 by Nsanti
Hello, I was wondering how I could assign one of the 2 roller dials on the side of my t8sg to a proportional channel. I would like to be able to go from 0 when it is all the way to one side and 100 when it is all the way to the other side, while being able to get all the values in between. My goal one day is to set up a stabilizer for an rc plane and be able to adjust the gain with a roller knob. I already know how to assign a 3 position switch to 3 different values, just not assign a 0 to 100 range on a roller. Thanks.
10 Sep 2021 13:42 #77548 by Mack775
Assign as source I am a devo fanboy and that works for me. There is not much you can not do! Have fun Mack
10 Sep 2021 23:43 #77549 by Nsanti
I assigned the roller to channel 5 and selected simple for the curve. It only goes from 0 to 100. You can’t set a value in between which is what I need. I also tried to select complex, but got the same result.
11 Sep 2021 11:53 #77550 by Mack775
Mine goes from -100 to +100 but you set the value of the channel not the source
11 Sep 2021 15:11 #77551 by Nsanti
Mine also goes from -100 to +100. I’m trying to be able to set any value in between. For example, go from 0 to 20 then up to 45 and then 100, or any other number.
12 Sep 2021 10:08 #77556 by Mack775
While you are in the mixing portion select channel then enter you can control limits have not tried missing portions of travel
12 Sep 2021 10:19 #77557 by Mack775
My problem is next week --- remembering what I changed this week
13 Sep 2021 06:34 #77558 by Gerry
Are all sticks and pots calibrated correctly?
simple mixer, source set to your roller and curve type should be set to "1 to 1"
FFS (Forever Fixing Stuff)
14 Sep 2021 19:05 #77566 by Nsanti
I calibrated the rollers and everything else. Works great now using the rollers to control a channel. Thanks you guys for the help!
Time to create page: 0.419 seconds
