Problems with DevoDfuSe ver. 1.5 with Win7 x64
16 Oct 2012 14:28 - 17 Oct 2012 05:19 #2285 by kosem
Hi team!
I can't display the DevoDfuSe window.
Everything is installed correctly, the driver is recognized but I can't launch the application. It won't be displayed but rather be "hidden" in the background. When I launch the app I see Windows undocked taskbar "moving" like when a new icon goes there and...nothing.
- STM32DFU recognizes the driver
- I've tried to run the app in compatibility mode (WinXP) and with Admin rights.
- The program won't run regardless if the device (DEVO 6S) is connected or not.
On my wife's Vista laptop it works flawless.
Any help would be very appreciated!
Thanks ;)
FYI, WIN7 Event viewer:
Faulting application name: DevoDfuSe.exe, version: 1.5.0.0, time stamp: 0x4fbc9168
Faulting module name: DevoDfuSe.exe, version: 1.5.0.0, time stamp: 0x4fbc9168
Exception code: 0xc0000005
Fault offset: 0x000065bf
Faulting process id: 0x1768
Faulting application start time: 0x01cdab8ac02b5276
Faulting application path: C:\Program Files (x86)\Devention Upgrade Tools\DevoDfuSe.exe
Faulting module path: C:\Program Files (x86)\Devention Upgrade Tools\DevoDfuSe.exe
Report Id: fdde72eb-177d-11e2-adfb-5404a62c5e85
Last edit: 17 Oct 2012 05:19 by kosem.
19 Oct 2012 16:34 - 19 Oct 2012 16:34 #2334 by kosem
:silly: ??
Last edit: 19 Oct 2012 16:34 by kosem.
22 Oct 2012 11:15 #2373 by NewJocker
Replied by NewJocker on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Hi.
I'have the same problem. On my 1st PC (win 7 64b), dfuse won't launch. But on another pc (same win 7 64b) it's rock!
Maybe a software conflict.
Try another pc.
28 Oct 2012 01:20 #2450 by j35u5fr34k
Replied by j35u5fr34k on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Hi I have the same exact issue. It seems that there is no fix. I resorted to using an older Windows XP computer and I was able to get it work on that PC. Good Luck.
28 Oct 2012 21:11 #2460 by kosem
Very bad support from Walkera.
Thanks anyway guys.
28 Oct 2012 22:37 #2462 by CmdrKeen
Replied by CmdrKeen on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I had the same problem with Dfuse 1.5 from Walkera.com.
But I came across Dfuse 1.4 and now it works fine.
www.derspielstein.com/shop_content.php/c...ntion-Upgrade-Center
I am sorry, it is a german website, but it contains the 1.4 Dfuse-tool:
www.derspielstein.com/soft_up/soft_file_1315373997456_en.zip
and quite a collection on firmwares for the Devos
01 Nov 2012 22:12 #2591 by kosem
A very warm thanks for your help!
It works fine for me too.
Greetings from Paris
01 Nov 2012 22:35 - 01 Nov 2012 22:41 #2592 by Hexperience
Replied by Hexperience on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Just for the sake of gathering more info. I have Win7 64bit and 1.5 works fine for me. I have Intel 64bit... wonder if any of the problems are on AMD 64bit?
.... Actually, now that I think about it... I may have used the x86 driver when I installed. I'll check the driver version and see what I'm using. Just says 3.0.1.0 I can't see which folder it installed from.
Last edit: 01 Nov 2012 22:41 by Hexperience.
02 Nov 2012 00:33 #2593 by j35u5fr34k
I don't think the driver is part of the issue since I can't start defuse even with the tx unplugged.
02 Nov 2012 12:23 #2611 by RandMental
Replied by RandMental on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I could not get it to run on my Intel based PC, Win7 32bit. Decided (for other reasons) to upgrade(?) to WIN7 64bit. It was one of the first items I installed and it rusn without any issues. I guess that supports the notion that it is a sofware clash.
Come to think about it, its been 3 weeks since I last used it and have since installed all my ussual softwware - better check it is still working!
12 Nov 2012 02:45 #2862 by j35u5fr34k
Some users reported reverting to 1.4 fixed their issue.
23 Nov 2012 00:22 #3102 by robertleong
Replied by robertleong on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I am on AMD Athlon 64 X2 processor, Windows 64-bit, opens normally.
06 Jan 2013 17:11 #4742 by clearprop88
Replied by clearprop88 on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
I read the posts in the log.
I can't get DevoDfuSe to run on my computer.
I have;
WINDOWS 7 Home Edition
Service pack 1
64 bit OS
Intl i7 CPU
I tried the 1.4 version from the German site, but that doesn't work either.
It downloads Ok, and unzips OK, but when I try to run DevoDfuSe it just hangs up.
Any ideas?
06 Jan 2013 20:13 - 07 Jan 2013 16:19 #4744 by clearprop88
I got the DevoDfuSe tool working in another computer.
This computer has Windows 7, but it's the starter edition.
Also when I download the zip files from the Walkera site I get a notice that says that the zip SW is not free, and that I get a 30 day trial for the SW.
Last edit: 07 Jan 2013 16:19 by clearprop88. Reason: correction
25 Jan 2013 16:18 #5507 by gapi
I want to add v1.4 solved mine too but am too chicken chit to try v1.5. Anyone do the v1.4 first and then get the v1.5 working?
01 Apr 2013 15:32 #8366 by martin
Still no solution for this? Going back to v1.4 wouldn't work for me, since it's too old to support my TX.
01 Apr 2013 17:49 - 01 Apr 2013 17:51 #8378 by blackmoon
Replied by blackmoon on topic Problems with DevoDfuSe ver. 1.5 with Win7 x64
Rev 1.7 available from walkera
walkera.com/en/updater.php
Note I don't use 7 so I haven't tested it.
Last edit: 01 Apr 2013 17:51 by blackmoon.
  • rbe2012
  • rbe2012's Avatar
01 Apr 2013 17:52 #8379 by rbe2012
It is and it works fine for me on XP and Win7 (both updates from 1.5).
The download link is here: DFuse 1.7
Time to create page: 0.683 seconds
