PB's newgui
23 Jun 2013 22:54 #11266
Replied by PhracturedBlue on topic PB's newgui
I have no idea what happened, but I rebuilt the code, and it seems to work now.
I also pulled Rbe's devo12 gui work, so most of the pages look better on the devo12 now.
- ave1
23 Jun 2013 23:09 #11267
by ave1
Replied by ave1 on topic PB's newgui
deviation-emu_devo12-v3.0.0-510794.zip
Windows 7. Pre-designed template
I am simply rearranging the items on the screen. (Me, the simple FLB heli flyer, wishes someone else told you this
and, hope u smile..
But, trim "1" will still not adjust on the "Y" axis. Locked at a value of "75"....Or maybe I am doing something wrong. That is usually the case.
Take a break, please. it's looking excellent.
- ave1
23 Jun 2013 23:16 #11268
by ave1
delete it, remake it and, it's fine.
23 Jun 2013 23:27 #11269
I see, It only happens on the 1st item on the list. The fix is a simple '>=' which I've now added. Thanks.
- ave1
23 Jun 2013 23:37 #11270
by ave1
Thank you.
You are correct.
Fix is valid
I have found no additional issues as per my typical usage.
You are correct.
Fix is valid
23 Jun 2013 23:59 #11271
I've added quick-page settings now.
They are set on the 'add widget' page.
I'm not really happy with this solution. I think it will make translations difficult as the space available is cramped. (I am aware there is space on the devo12, but on the devo8 there isn't room to make the dialog much wider)
There are 3 other alternatives:
1) pop up a 2nd dialog from the 'add widget' page which allows configuring the menus.
2) use 2 spinboxes, one containing 'menu1', menu2', ..., the other containing the value of the menu.
3) create a new full-page just for configuring the menu
I don't like 1) because it involves popping up a dialog from a dialog. But I could probably make this work. I don't like 2) because you cant see all settings at once. i don't like 3) because the quickpages really are part of the gui definition (they have no impact on the Tx functionality other than page order)
But I'm open to suggestions.
- ave1
24 Jun 2013 00:13 #11272
by ave1
It is most intuitive is it not?
So, perhaps any (the) issue might be, I don't fly w a devo 8? I thought logic flowed nicely and saw no problem.
- Pattaya01
24 Jun 2013 00:13 - 24 Jun 2013 00:21 #11273
by Pattaya01
Replied by Pattaya01 on topic PB's newgui
Sorry, I get a bit confused now. Is this the latest version?
deviation-emu_devo12-v3.0.0-554509.zip
If yes, I loaded it as a "virgin", it starts with an empty screen and there is no way I can add or change anything. Or am I doing something wrong?
Edit: tried again. now get something. Have no idea hat went wrong.
Last edit: 24 Jun 2013 00:21 by Pattaya01.
- ave1
24 Jun 2013 00:21 #11274
by ave1
- ave1
24 Jun 2013 00:25 #11275
by ave1
I don't share that issue on this end.
- Pattaya01
24 Jun 2013 00:28 - 24 Jun 2013 00:31 #11276
by Pattaya01
I re-loaded and all seems fine. Got no idea what went wrong. Now playing with it. At first glance looks very good. Love the additional wide screens. Hope the work finishes soon and can put on my Devo12S for real.
This may be a bit off topic, but I am doing this:
I am an FPV flyer and I need toggles like "RTL", "NAV", etc. So I have added toggles in the directory "media" by just extending the rows with 2 more icons 32x31 bit. It works fine on the emulator. Is this something I can do without screwing up the system?
Last edit: 24 Jun 2013 00:31 by Pattaya01.
- ave1
24 Jun 2013 01:53 #11277
by ave1
button monitor indication/feedback might not be as desired
24 Jun 2013 02:40 #11278
all user toggles should go into toggle3.bmp.
toggle0, 1, and 2 are predefined such that they can be standardized as far as their meaning goes. toggle3 is user owned and you can put whatever you like there.
- Pattaya01
24 Jun 2013 03:06 - 24 Jun 2013 03:10 #11279
by Pattaya01
Last edit: 24 Jun 2013 03:10 by Pattaya01.
- ave1
24 Jun 2013 03:10 #11280
by ave1
The emulator controls do not function here. They obviously do for others. I am in need of instructions (superior to those offered, or what I can locate in forum, please).
- ave1
24 Jun 2013 03:18 #11281
by ave1
cancel that. sorry , got it just not the overlap pictured above as yet
24 Jun 2013 03:32 #11282
I think I'm satisfied with the implementation now, so if someone wants to design a template for the dveo12 default, I'm interested.
This will be the default for all users, so it should not be over-cluttered, nor too specific for any given model type.
Just post your ini file if you want.
I've updated this page for the devo12 so the scrollbar and buttons are in the right place, and the screen is fully utilized.Pattaya01 wrote: OK, got you. I have done that, and there are more toggles now. So when I want to assign pictures to the toggles, a side bar appears (before the toggles fit in the screen) which I can use to scroll down. But this happens:
It works fine, it's just a cosmetic issue.
- Pattaya01
24 Jun 2013 03:33 - 24 Jun 2013 03:35 #11283
by Pattaya01
Last edit: 24 Jun 2013 03:35 by Pattaya01.
- Pattaya01
24 Jun 2013 03:36 - 24 Jun 2013 03:39 #11284
by Pattaya01
Last edit: 24 Jun 2013 03:39 by Pattaya01.
24 Jun 2013 03:49 #11285
I fixed this too. keep the bug reports comingPattaya01 wrote: Another (small) problem:
I place toggles
They show in the screen:
But after "Exit and save" and restart the emulator, they are gone:
Time to create page: 1.994 seconds
- PB's newgui
