Newbie's questions about adding switches to the 7e
  • Khan
  • Khan's Avatar Topic Author
  • Build. Crash. Repeat.
20 May 2014 09:29 #23392 by Khan
Hi Guys !
I'd like very much to add switches to my 7e.
I've read this thread Adding custom switch support in Deviation but I can't understand everything that is at stake there.
So I have a few questions :
1. Can I add 2 3-way switches to my 7e while keeping the existing Hold and Fmode switches functional ?
2. If I understand correctly, the additional switches work with diodes. When I go to the electronics shop, what kind of diodes should I ask for ?
3. I don't remember having seen any wiring scheme. Any info on that, or a close look at Galee's pictures is sufficient ?
4. Does the official Deviation 4.0.1 release support the additional switches yet ? If not, which build I should download & install ?
Thanks !
20 May 2014 13:42 #23397 by IMback!
1. yes
2. dose not matter (within reason any non led diode should work and LEDs might work too.)
3. I don't know if there is a diagram somewhere.
4. no the latest nightly should do the trick. if stability is a concern I can build you a 4.0.1 with the 2x2 patch applied
20 May 2014 15:46 - 20 May 2014 15:46 #23401 by yidc
including custom-switch support in Deviation
FYI, you may refer to the above link for detail wiring scheme.
Last edit: 20 May 2014 15:46 by yidc.
  • Khan
22 May 2014 08:03 #23494 by Khan
Thanks guys !
Time to create page: 0.600 seconds
