A7105 wiring of GIO pins
- Waterbound
12 Apr 2015 16:17 - 12 Apr 2015 16:18 #31106
by Waterbound
Replied by Waterbound on topic A7105 wiring of GIO pins
Thanks again! So to clarify 1 thru 9 are wired like this:
1 VCC to VDD
2 SCS to TMS (a13 in hardware.ini)
3 GND to Ground
4 SCK to SCK
5 SDIO to MOS
6 GI01 to 9 TXEN
7 GI02 to 8 RXEN
Essentially following this diagram minus 6-9 and 7-8?
4.bp.blogspot.com/-xkOUPc1CsSA/VQBfn72G_...w/s1600/A7105-7E.jpg
Thanks again!
1 VCC to VDD
3 GND to Ground
4 SCK to SCK
5 SDIO to MOS
6 GI01 to 9 TXEN
7 GI02 to 8 RXEN
Thanks again!
Last edit: 12 Apr 2015 16:18 by Waterbound.
- Durete
12 Apr 2015 20:19 #31112
by Durete
It's ok.
Replied by Durete on topic A7105 wiring of GIO pins
YepWaterbound wrote: Thanks again! So to clarify 1 thru 9 are wired like this:
1 VCC to VDD
3 GND to Ground
4 SCK to SCK
5 SDIO to MOS
6 GI01 to 9 TXEN
7 GI02 to 8 RXEN
Thanks again!
It's ok.
- Waterbound
12 Apr 2015 21:48 #31114
by Waterbound
Great! Thanks again!
- Waterbound
17 Apr 2015 00:07 #31268
by Waterbound
well I though I was out of the hole and well on my way but no luck, before I chuck this XL-a7105-D03 in the trash is there anything to try for diagnostics?
I have wired per above but used TCK as TMS is used for my NRF module (working)
1 VCC to VDD
2 SCS to TCK (a14 in hardware.ini)
3 GND to Ground
4 SCK to SCK
5 SDIO to MOS
6 GI01 to 9 TXEN
7 GI02 to 8 RXEN
I have checked with DMM all points to ensure continuity which all tested perfect. I have modified the hardware.ini to ensure I was enabling in A14 and for second line I have =1 to enable power amp. I'm at a loss, the only thing I can think of is I killed it by wiring the old method that is published etc. If there is any diagnostics I can run or test, I'm all ears. Thanks!
1 VCC to VDD
3 GND to Ground
4 SCK to SCK
5 SDIO to MOS
6 GI01 to 9 TXEN
7 GI02 to 8 RXEN
- Durete
17 Apr 2015 05:43 #31280
by Durete
So not working with the old nor the new style wiring?
If you have checked carefullly your wiring, probably bad A7105 module...
- Waterbound
17 Apr 2015 13:22 #31292
by Waterbound
Hi Durete
Thanks for getting back and sorry I am such a pain
originally I wired using the spreadsheet published here which I assume is the old wiring method, and then I wired via the picture I linked prior, lastly I wired where I added the loops per your indication.
the only thing I haven't tried is removing the NFR.. module (working) and try just the a7105 by itself, I'm seriously thinking about the multimodule or trying to come up with a easier method to clean things up. I was hoping I could test the module somehow such as apply power on TX and probe the pins to see voltage etc., I just don't have that knowledge of what to look for. Is it possible or should I say fairly easy to kill the module by wiring the original (older method) ? I was under the assumption that both would work but it would use less power with newer method etc. I was confused why some diagrams showed GND looped to TXEN but again, not enough knowledge to understand the differences.
- aMax
17 Apr 2015 18:02 - 18 Apr 2015 10:27 #31310
by aMax
You was right, and both will work with the nightly. Only for the last main version, 4.0.1, you have to use the old wiring method.
The reason is, this version is missing some code to manage the GIO pins accordingly.
Since the module did not work even with this, you can assume the module is faulty.
Replied by aMax on topic A7105 wiring of GIO pins
Waterbound wrote: I was under the assumption that both would work but it would use less power with newer method etc. I was confused why some diagrams showed GND looped to TXEN but again, not enough knowledge to understand the differences.
Last edit: 18 Apr 2015 10:27 by aMax. Reason: new glasses ?
- Waterbound
17 Apr 2015 21:38 #31312
by Waterbound
that's true, thanks for the clarification as well!
I will try a last ditch effort with removing everything then trying just the a7105 module by itself, if that doesn't work then I'm tossing it and replacing
thanks!
thanks!
- Newman
21 Apr 2015 01:10 #31444
by Newman
Replied by Newman on topic A7105 wiring of GIO pins
I am using Deviation 4.0.1 with a A7105 wired the "new power saving way" as per attached image, Is it necessary to use the nightly build to optimise this connection method i.e. lower power consumption and some telemetry support IIRC. Seeing as the nightly built is, I am led to believe not as stable as 4.0.1, is there any problem with using the new wiring with 4.0.1. which is what I am currently doing and it is binding to Hubsan with no apparent issues. Thanks Pedro
- Orion55
30 Apr 2015 12:20 - 30 Apr 2015 19:13 #31848
by Orion55
Replied by Orion55 on topic A7105 wiring of GIO pins
Hi
I have added the connections for the NRF24L01 module as well
Last edit: 30 Apr 2015 19:13 by Orion55.
- Deal57
30 Apr 2015 14:52 #31852
by Deal57
Replied by Deal57 on topic A7105 wiring of GIO pins
Where you show the NRF24L01 ground pin 1 going to the Devo 7e position 4 next to Vdd on the 7e board, that connection may not always work. I found the most reliable connection for ground for both the NRF and A7105 was the ground pin on the CYRF RF Shield pin 7. YMMV, but I think we see a lot of cases where the position 4 was used and had problems.
- Orion55
30 Apr 2015 19:19 - 30 Apr 2015 19:27 #31858
by Orion55
Thanks for the heads up on the GND position
I have changed the diagram above as you suggest
Presently using my devo7e with
WLtoys V911 Pro
Hubsan X4 H107L
Syma X5C-1
WLtoys V911 Pro
Hubsan X4 H107L
Syma X5C-1
Last edit: 30 Apr 2015 19:27 by Orion55.
- Newman
27 Aug 2015 02:19 #37229
by Newman
Orion55 - thanks for adding the NRF24L01 module to my diagram, nice job
Sorry for the late reply I thought that I had already thanked you
- vincentko88
21 Sep 2015 10:49 - 21 Sep 2015 11:02 #37921
by vincentko88
Replied by vincentko88 on topic A7105 wiring of GIO pins
Dear Durete,
What is your latest nightly? V401-92e1705?
Where can I download your nightly that works with my Devo7e new wiring + nrf24L01-PA-LN and XL7105-D03B module
Vincent
Vincent
Last edit: 21 Sep 2015 11:02 by vincentko88.
Time to create page: 0.287 seconds
- A7105 wiring of GIO pins
