Deviation for Devo F4?
- Arnold
31 Aug 2016 21:01 #53341
by Arnold
Can you provide more info?
Replied by Arnold on topic "Dress-up" with LED lights around the F4's buttons
I'd like to do this too.Epitaph wrote: ... I thought ... I might as well add the 6 blue LEDs that the F7 has ...
- Epitaph
31 Aug 2016 21:04 #53342
by Epitaph
Replied by Epitaph on topic Deviation for Devo F4?
I just removed the SMD LEDs from one of those 12V strips, cut the plastic out a little inside, and stuck them in place, then soldered them up with some resistors and fed them from the 5V point on the secondary screen board (the red wire that comes from the primary board).
- Arnold
01 Sep 2016 05:21 - 01 Sep 2016 05:25 #53352
by Arnold
Replied by Arnold on topic Deviation for Devo F4?
Sounds simple. I'll probably have questions.
When you say, "cut the plastic out a little inside" I guess you mean inside the tx, in the vicinity of the buttons, right?
Last edit: 01 Sep 2016 05:25 by Arnold.
- Epitaph
01 Sep 2016 06:52 #53354
by Epitaph
The clear part has little notches cut out for the LEDs, but there is a circle of black plastic around that which I had to cut as the LEDs I had were too big to just slot straight in. And make sure when you fit them that they don't "invade" in the inner part of the circle, or they'll scratch against the buttons when you use them.
- Arnold
01 Sep 2016 22:49 - 03 Sep 2016 20:49 #53389
by Arnold
OK, thanks.
In the mean time...
I used a Photoshop file provided by Coldbrew for the 7E Switch panel (post #44244) and made a version for the F4 based on his work. Attached is a jpg version in its current state. It may be useful or not depending on your switch layout. Maybe I can make a version that suits your needs if you let me know.
Or I could just provide the layered Photoshop file (PSD) so you can roll your own.
In the mean time...
Last edit: 03 Sep 2016 20:49 by Arnold.
- Epitaph
02 Sep 2016 13:07 #53409
by Epitaph
Looks good, although the only problem is we haven't been able to identify the HOLD switch
- Arnold
- djtrance
09 Sep 2016 14:48 - 09 Sep 2016 14:49 #53688
by djtrance
Replied by djtrance on topic DJTrance
sorry, I haven't to much time now, but you can check my repo on git, so see what I forget to fix.
this repo can only make the emu for devof7 but the devo f7 and f5 has the same menu screen.
for build the emu, you can go to src and write this command.
make TARGET=emu_devof7
and ./emu_devof7.elf
mu repo is: github.com/djtrance/deviationtx
Last edit: 09 Sep 2016 14:49 by djtrance.
- Arnold
14 Sep 2016 23:50 #53867
by Arnold
LED's ... The ones I got are way too small - about 1/2 the size of a grain of sand. Too small for me, anyway. eBay shopping again.
- SirDomsen
27 Oct 2016 20:03 #55456
by SirDomsen
Replied by SirDomsen on topic Deviation for Devo F4?
Any progress here? djtrance?
- djtrance
04 Nov 2016 14:34 #55668
by djtrance
Replied by djtrance on topic Deviation for Devo F4?
no one has tested the code that I uploaded to my git.
there are some things that I must fix, but if no one help me to test it, is more dificult. because now I have not to much time to do it, but with yours help I can do it.
- SirDomsen
04 Nov 2016 15:28 #55673
by SirDomsen
Seems,like I havebto,get into how to build deviation then? I was hoping to see it,in the,nightlies,(or a version here in this thread?) but no worries about that
- djtrance
04 Nov 2016 15:38 - 04 Nov 2016 18:22 #55675
by djtrance
you candownload the emulator file with this link :
mega.nz/#!fkdRhSoa!vxV46L9SCqDV5GqXdrBvQZjNVcWnU0RPMYVoPQ98CSA
but is compiled to linux.
Last edit: 04 Nov 2016 18:22 by djtrance.
- SirDomsen
04 Nov 2016 16:27 #55680
by SirDomsen
Linux is OK, I have a Ubuntu machine running. But Link,requires,a PW?
- djtrance
04 Nov 2016 18:22 #55683
by djtrance
Ok there are new links
sorry ..
- victzh
04 Nov 2016 19:53 #55685
by victzh
Replied by victzh on topic Deviation for Devo F4?
Can I build it and try on a real F4? I plan to add support for my module to F4 anyways (adds real filesystem and 4-in-1 module).
- djtrance
04 Nov 2016 19:57 #55686
by djtrance
I has not put the changes to the F4..
all the code are into F7, but the code is exactly the same for F4, if you what, you can copy the files to theF4 .
- victzh
04 Nov 2016 20:00 #55687
by victzh
Why is your project has no connection to the DeviationTX/deviation? Is it not a clone? Then it is harder to compare the changes and put code back into the main project.
- djtrance
04 Nov 2016 20:06 #55688
by djtrance
my project is a fork of the original, because my devoF7 has more memory like the original, but there are only one thing that is different to the official (the memory config).
mustn't be hard to compare with original
- victzh
04 Nov 2016 20:11 #55689
by victzh
So your changes are in commits 0b73ebd and 7b11377?
Time to create page: 0.399 seconds
- Deviation for Devo F4?
