Updating and internationalizing documentation
20 May 2017 08:46 #62427
Replied by FDR on topic Updating and internationalizing documentation
Do you mean the physical file name, or just the name of the download category?
- Moeder
20 May 2017 10:05 #62432
by Moeder
Replied by Moeder on topic Updating and internationalizing documentation
Probably both. The way it is displayed right now may be correct, but it could be nicer! Also, what do you think of renaming them black/white (or monochrome) and touch/color? The 7e/10 manual also applies to 12e, f7 f12 and the other one is for 6s,8s,12s etc.
20 May 2017 10:42 #62435
The 7E/10 manual indeed covers the 12E too, but the text based GUI of the F4/F7/F12E while based on that same code, they sometimes are quite different, for example the F4/F7 don't have graphs, while the F12E has sort of.
AFAIK the F12E can have colors, while the other do not.
So I think dividing them into color vs BW is not enough...
- Morlacus
07 Jun 2017 17:19 #62876
by Morlacus
Replied by Morlacus on topic Updating and internationalizing documentation
While translating the manual in french and updating the lang.fr file, I have realized that I have may be done a mistake in translating some expressions.
They are the following
Gear, ELEV D/R RUDD D/R AILE D/R
As these functions refer also to swiches of the tx I wonder if it is good to translate them as when translated users could have problems to understand which switch is in cause.
Another possibility would be to have a picture of the tx with the original name and translation of the name of the switches
Or in the translated manual always have the two names translated [english]
Has anybody an opinion about this to have a common position for all translations ?
07 Jun 2017 21:23 #62881
I think I didn't translate the switch and button names, but used their original name as they written on the TX...
16 Nov 2017 07:16 #65871
Replied by vlad_vy on topic Updating and internationalizing documentation
How can I get access to manual translation? I've pressed many buttons but see nothing at
www.transifex.com
16 Nov 2017 07:40 #65874
It seems to work for me.
Go to the dashboard:
www.transifex.com/deviationtx/deviation-manual/dashboard/
Select the language below the graph, then a paragraph, and you are ready to go...
16 Nov 2017 07:45 - 16 Nov 2017 07:46 #65875
Once again, I see nothing. Probably I need some permission from "deviation-manual" admin? I don't use Transifex before.
Last edit: 16 Nov 2017 07:46 by vlad_vy.
16 Nov 2017 07:55 #65877
Oh, I see!
Can I use your deviationtx email address to send an invite to you?
16 Nov 2017 07:58 #65878
Nevermind, I found you on transifex, and sent an invitation...
16 Nov 2017 08:57 #65882
As far as I see it works now, doesn't it?
16 Nov 2017 09:06 #65883
It works now. Thank you.
- fneuf
16 Nov 2017 10:57 #65886
by fneuf
Replied by fneuf on topic Updating and internationalizing documentation
I've just created an account there to help with translation effort.
16 Nov 2017 12:58 #65889
As I see you are already on the list of french translators...
Thanks!fneuf wrote: I've just created an account there to help with translation effort.
- fneuf
16 Nov 2017 13:01 #65890
by fneuf
Cannot control the eager to help
16 Nov 2017 13:02 #65891
- Morlacus
16 Nov 2017 13:16 #65892
by Morlacus
I have been lazy this time and there are 19 strings left to translate in french
Help is welcome....
Help is welcome....
- Moeder
16 Nov 2017 14:01 #65893
by Moeder
@FDR: beat you!
@vlad_vy: I thought language ru was more general than ru_RU, that is why I preferred it.
Anyone in for a Chinese translation?
- Morlacus
16 Nov 2017 14:14 #65895
by Morlacus
Some strings are missing for translation in the transifex basis
example
This protocol requires the addition of an
‘NRF24L01’ hardware module to function. See the following document for more information :
These are reffered in transifex but cannot be translated
It would be good to have them somewhere for translation
If possible...
example
If possible...
- fneuf
16 Nov 2017 14:17 - 16 Nov 2017 14:52 #65896
by fneuf
Are you supporting all characters in Deviation ? Like "œ" for instance.
And would it also be possible to gain access to the "English" language, if we have suggestions to make?
Last edit: 16 Nov 2017 14:52 by fneuf.
Time to create page: 0.296 seconds
- Updating and internationalizing documentation
