F12e xms testing
- Toolbox1211
07 Mar 2019 01:11 - 07 Mar 2019 04:28 #73245
by Toolbox1211
F12e xms testing was created by Toolbox1211
I have the f12e and I have done xms,and dfplayer and have the 4 in1 and m9 hall sensor gimbals in the mail
To show my appreciation for the hard work that has gone on in the deviation forums I would like to offer my help to test and report in any way I can. I would love to help but coding is beyond my current ability.
So to start with here is some bugs I noticed .
Toggle icons and switches. Icon is a empty box when switch is in the position radio was turned on in until you move it
if you move a 3 way from pos 0 to 1 then 2 the icon stays in pos1 if you go quickly it will go to pos2 icon.
If you have 2 icons for a 2 way switch only pos1 will display
After enabling the dfplayer there are no haptics anymore
I understand with the dfplayer there is a goodbye message on poweroff but I have yet to hear it
Also if somone is capable of it an organized folder system for the dfplayer sounds would be very helpful. Not sure if the dfplayer allows folders or if the way deviation comunicates the mp3 to run would work with a folder system
Last edit: 07 Mar 2019 04:28 by Toolbox1211.
14 Mar 2019 07:34 #73345
Replied by vlad_vy on topic F12e xms testing
Toggle icons have to be fixed now.
- Moeder
14 Mar 2019 08:51 #73346
by Moeder
Replied by Moeder on topic F12e xms testing
Missing shutdown message is a known issue with voice, haven't been able to fix it yet.
I will look into haptic + voice.
- Toolbox1211
14 Mar 2019 11:57 #73350
by Toolbox1211
Replied by Toolbox1211 on topic F12e xms testing
This place is filled with hard working individuals and its quite refreshing:)
- Moeder
14 Mar 2019 12:26 #73352
by Moeder
Concerning haptic issue I need some clarification: no haptic at all with voice activated? The default timer alarms, telemetry alarms etc should have haptic, but not any of the custom alarms/switches etc you might have assigned. If you turn audio vol to 0 in transmitter config, does haptic return?
- Toolbox1211
14 Mar 2019 17:14 - 16 Mar 2019 01:29 #73356
by Toolbox1211
I have noticed no haptics at all wile dfplayer is active but i havent used it with telemetry enabled or used any timers.
I have had plenty of inactivity alarms and it is only voice. Currently my f12e is in alot of pieces doing all the mods lol. But it should be back together in the next few days I will test 0 volume and with telemetry i will also try timers. And let you know the results
Update: Telem haptics function aswell as timers
Full haptics with 0 volume
Last edit: 16 Mar 2019 01:29 by Toolbox1211.
Time to create page: 0.791 seconds
- F12e xms testing
