Voice alerts test build
- Wene001
26 Sep 2017 19:09 - 26 Sep 2017 20:04 #64677
by Wene001
Replied by Wene001 on topic Voice alerts test build
i ve tested last version on this thread from moeder on my Devo12s.
Welcome message and 2times binding completed @bayang protocol is sucessfully played.
Tested a short flight and telemetry message works too.
No problems so far.
Edit: my dfplayer is powered from the 4,25V Rail for the TX Module
No problems so far.
Last edit: 26 Sep 2017 20:04 by Wene001.
- Solmer
27 Sep 2017 11:14 #64691
by Solmer
Replied by Solmer on topic Voice alerts test build
Hi !
Devo8 working like a charm
Thank you so much for your work
- Moeder
28 Sep 2017 05:23 #64706
by Moeder
Actually it is triggered every time via PROTOCOL_CheckDialogs() when the binding dialog is closed, and additionally some protocols also play binding music when leaving binding state. This doesn't make sense to me, shouldn't we choose either place, but remove the double plays?
Apart from that, I would like to wait for some more feedback on the testbuild concerning startup messages, so far only one user has issues, but major ones, so this is not ready for a pull request yet.
mwm wrote: Binding is played 2 times for some protocols because they have a 2-step binding process, and play the "completed" sound at the end of each step. Works find for beeps, but not so much with a voice alert.
- pulpfiction15
01 Oct 2017 11:16 #64762
by pulpfiction15
@Moeder,
Continued to make some tests, with strange results.
Devo 12S : not working
I have 2 Devo 6 , only one is working, not the other, exactly the same configuration : hardware and build (v5.0.0-7b55485), mp3 same, media is same ?
When installing v5.0.0-53a7951 I have the voice announcements back.
- Moeder
01 Oct 2017 12:40 - 01 Oct 2017 12:40 #64763
by Moeder
@Pulpfiction15:, Could you please check which model file (especially which protocol) the non working vs. The working devos are loading at startup? This could be triggering the issue...
Last edit: 01 Oct 2017 12:40 by Moeder.
- magic_marty
01 Oct 2017 18:58 #64770
by magic_marty
Has the latest build been added to the latest nightly build? If so i will load it up and test it out today
- Moeder
01 Oct 2017 19:37 #64772
by Moeder
No, the welcome message fix isn't in the current nightlies, as pulpfiction15 still seems to have issues we need to fix first. Hhe has no voice at all, so this rather cosmetical fix seems to break something.That is nothing I want to push into nightlies.
- pulpfiction15
02 Oct 2017 07:00 #64775
by pulpfiction15
@moeder,
That's indeed what could be different, I didn't, try with different models, the non working transmitters, are both using 'FrskyX' protocol.
The Devo6 that's is working, I use it for my simulator and is set to 'USBHID'.
Will make some test, changing protocol this evening.
- Moeder
02 Oct 2017 10:26 #64777
by Moeder
Probably no more testing needed. The FrSkyX Protocol changes the serial ports baudrate to send extended telemetry data to the serial port. Before my fix there was an additional audio reset after model load, whch again reset the baudrate. I guess the only solution to this is adding a protocol option to enable or disable serial output of telemetry data and additionaly checking that in voice routines to reactivate buzzer in that case.
- Wene001
02 Oct 2017 14:32 - 02 Oct 2017 14:35 #64781
by Wene001
I can confirm
No voice with FrskyX and the latest voice test build @Devo12s
Last edit: 02 Oct 2017 14:35 by Wene001.
- Moeder
03 Oct 2017 18:17 #64793
by Moeder
I supposed so. I'll make the necessary additions to FrSkyX (I'll also check for other protocols) and prepare a pull request. But please be patient, I'm a little busy and probably won't get to it until the end of this month.
- magic_marty
04 Oct 2017 04:11 - 04 Oct 2017 04:12 #64796
by magic_marty
Not sure if it is related but i recently got the new Frsky R-xsr full telemetry micro rx and i can't get the main battery voltage on my 12s but i get all the other telemetry from the rx like the RSSI, rx input voltage and also the LQI just no main battery voltage..
Last edit: 04 Oct 2017 04:12 by magic_marty. Reason: typo
- Moeder
04 Oct 2017 13:14 #64807
by Moeder
This shouldn't be related to voice, so please post your question to the FrSkyX Protocol thread or open a new one.
- BlackLotus
10 Oct 2017 13:30 - 12 Oct 2017 11:35 #64948
by BlackLotus
Newbie who using Devo 10
Replied by BlackLotus on topic Show my works! and problem question!
Hello~ I'm new in here!
Actually I've got much help in here last 3 month.
(It's really hard to register here. I tried three email address and finally I got code to here
First of all. I'm reaaally thankyou here deviationtx.
I'm newbie on RC, and (of course) still feels happy with learning something I didn't know about Deviationtx.
It's amazing!
I'm using Devo10, at first added 4in1 module. and it works great at first try.
And I've added voice output last couple of days by following deviation wiki.
http://www.deviationtx.com/wiki/voiceoutput
And I think I did it well.
connect signal on #2 on pic,
Using 8Ohm, 0.5W speaker.
Powering by debug port, and set 4.2V by pololu.
Tried sometimes and It works nice!
But problem is.... voice stucked when I set volume 9 and 10.
Same was at volume 8 first few times, but It's being Okay soon.
Volume 8 is noticable, but little quiet using outside.
I hope to perfection my beloved devo 10.
Before I added voice output, buzzer was most loud at Volume 8. Is that relate?
Anyone who thinks clue of this problem, please help me.
and, when I changed model that using FrskyX(XSR Receiver) voice don't working.
I should reset TX to get voice with that model.
Anyone who knows clue of this, please help me.
(Oh now I know that's normal when using FrskyX)
Below is my TX voice working, and stucking video.
Sorry about my poor english, thankyou for reading here.
and THANKYOU AGAIN DEVIATION TX!!
It's amazing!
Last edit: 12 Oct 2017 11:35 by BlackLotus.
- magic_marty
13 Oct 2017 07:44 #65019
by magic_marty
Replied by magic_marty on topic Show my works! and problem question!
Is the voice alerts working on the latest nightly build for Frsky ? I updated and now no voice using R-xsr receiver and i had voice before i updated..
- BlackLotus
13 Oct 2017 08:50 #65021
by BlackLotus
When I power on TX with FrskyX model, it works. I'm using XSR same.
I didn't remember it's going well how many packs.
Maybe reboot needs sometimes. and didn't checked telemtry voice alarm works or not.
- BlackLotus
14 Oct 2017 00:33 #65050
by BlackLotus
Ah.. I'm using nightly of 28th Sep
- Moeder
15 Oct 2017 19:41 #65077
by Moeder
Replied by Moeder on topic Show my works! and problem question!
Please have a little patience, I'm on vacation... Once I return I will prepare a pull request to be included on future nightlies which will
a) include startup sound fix
b) enable voice for FrSkyX by default
c) add a protocol option to disable voice on FrSkyX in favor of s. port telemetry output to trainer jack
Concerning the volume problem, has anyone else run into this?
- magic_marty
15 Oct 2017 19:52 #65078
by magic_marty
I installed the nightly build devo12-v5.0.0-b6032ee on both my 12's and i now get the "Welcome" message nearly every time i power on and also i am now getting the voice alerts on FrskyX and was not before...
- Moeder
23 Oct 2017 14:28 #65217
by Moeder
I took a look at your video and noticed the display light was flashing off and back on when the voice got stuck , so this is probably a power issue. I'm not sure what's feeding Vdd on the debug port, but it seems insufficient when supplying volume levels 9 and above in your specific combination (speaker that is mainly). I don't know which step-up/step-down you chose, but they should be sufficient, so try supplying the Pololu directly from battery voltage as a first step. If this does not solve the problem try a different speaker.
BlackLotus wrote: connect signal on #2 on pic,
Time to create page: 1.413 seconds
Builds
- Voice alerts test build
