Voice alerts test build
26 Feb 2018 05:17 - 26 Feb 2018 06:37 #67776
Replied by vlad_vy on topic Voice alerts test build
I don't understand why it can happen. The drawn background don't touch anything related to audio. Probably extended audio device with drawn background hasn't time to properly initialize and the startup sound AUDIO_SetVolume() do nothing.
What transmitter do you use? Probably we need increase startup delay at "main.c" to 2000 with drawn background.
to
// Add startup delay to make sure audio player is initialized
// AUDIO_Init() has already been called by CONFIG_ReadModel()
#if HAS_EXTENDED_AUDIO
audio_queue_time = CLOCK_getms() + 1500;
num_audio=1;
next_audio=1;
AUDIO_SetVolume(); // Initial setting of voice volume
#endif // Add startup delay to make sure audio player is initialized
#if (LCD_WIDTH == 480) || (LCD_WIDTH == 320)
if(Display.background.drawn_background)
audio_queue_time += 500;
#endif
num_audio=1;
next_audio=1;
#endif
Last edit: 26 Feb 2018 06:37 by vlad_vy.
- pulpfiction15
26 Feb 2018 08:07 #67782
by pulpfiction15
@vlad-vy
I testested it on a devo 6.
26 Feb 2018 08:10 - 02 Mar 2018 04:04 #67783
Can you try this test build with added startup delay?
File deleted...
File deleted...
Last edit: 02 Mar 2018 04:04 by vlad_vy.
- pulpfiction15
26 Feb 2018 08:41 #67785
by pulpfiction15
@vlad-vy,
I am travelling and will only be able to test on Thursday evening, sorry.
- pulpfiction15
01 Mar 2018 19:25 #67847
by pulpfiction15
@vlad-vy,
as promised, flashed your build deviation-devo6-v5.x.x-2018-02-26.zip, this did not help, same results.
With ' drawn_background=1' startup message is at maximum volume.
02 Mar 2018 04:07 - 03 Mar 2018 06:43 #67850
Will be better if extended audio developer Moeder look in to it.
Try next build - I added 0.2sec delay before MUSIC_Play(MUSIC_STARTUP):
File deleted...
File deleted...
Last edit: 03 Mar 2018 06:43 by vlad_vy.
- pulpfiction15
02 Mar 2018 18:47 - 02 Mar 2018 19:18 #67855
by pulpfiction15
@vlad-vy,
some improvement;
drawn_background=1 startup message somethimes maximum volume, somethimes at set volume
drawn_background=0 startup message normal
some improvement;
Last edit: 02 Mar 2018 19:18 by pulpfiction15.
03 Mar 2018 06:46 - 10 Mar 2018 04:58 #67872
It looks like we are close. Try next build with 0.3sec delay before MUSIC_Play(MUSIC_STARTUP):
File deleted...
num_audio=1;
next_audio=1;
while(CLOCK_getms() < audio_queue_time - 1200);
#endif
#endif
MUSIC_Play(MUSIC_STARTUP);File deleted...
Last edit: 10 Mar 2018 04:58 by vlad_vy.
- pulpfiction15
03 Mar 2018 10:11 #67876
by pulpfiction15
@vlad-vy,
all OK now, thanks.
Could you make a build also for a DEV012, to test.
all OK now, thanks.
03 Mar 2018 13:00 - 10 Mar 2018 04:58 #67879
devo12 build with delay 0.3sec:
File deleted...
File deleted...
- pulpfiction15
03 Mar 2018 19:08 #67883
by pulpfiction15
@vlad-vy,
all OK, also on the devo12 , thanks.
- Moeder
05 Mar 2018 14:24 #67914
by Moeder
Thanks vlad for fixing. Influenza had it's grip on me...
- Bisky
12 Mar 2018 20:29 #68033
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic Voice alerts test build
Can't get my U7E to work with dfplayer. The dfplayer it self is working when I pres keys. It does not work over DSC port, external port currently not available in the model voice alert.
What am I doing wrong?
I flashed this to my U7E
www.deviationtx.com/downloads-new/catego...256-v5-0-0-voice-zip
TX, Bojan
TX, Bojan
- Moeder
12 Mar 2018 22:17 #68034
by Moeder
Try the current nightly and closely follow the instructions in the wiki (especially ini settings)
- Bisky
13 Mar 2018 16:45 #68044
by Bisky
voice.ini was missing in the media folder on the transmitter...
Devo F7 doesn't work due cpu limitations?
Ultimate F7-XMS, could it be done?
Tx, Moeder
Tx, Moeder
- Moeder
15 Mar 2018 15:32 - 15 Mar 2018 15:33 #68093
by Moeder
Yes F7 like 7E had only 128 Kb flash, so no room for voice feature. We could compile F7XMS without standard mixer GUI to make room for voice features, but voice config menu would still not work due to ram limitations. Configuration would have to be done via ini editing or emulator.
Last edit: 15 Mar 2018 15:33 by Moeder.
- Remlen
15 Mar 2018 18:49 - 02 Sep 2022 08:23 #68102
by Remlen
Replied by Remlen on topic Voice alerts test build
Last edit: 02 Sep 2022 08:23 by Remlen. Reason: photo
- Remlen
15 Mar 2018 18:50 - 02 Sep 2022 08:24 #68103
by Remlen
Last edit: 02 Sep 2022 08:24 by Remlen. Reason: photo
- Bisky
15 Mar 2018 19:33 #68106
by Bisky
Ok, this sounds promising, but difficult to set up in the *.ini files...
would the ultimate 7e boot loader worked if I changed CPU?
- Moeder
15 Mar 2018 19:58 #68107
by Moeder
In theory, yes, but you'd need a custom build. What is wrong in using the emulator to set up the ini files? But I won't hold you off from unsoldering and soldering yet another LQFP64 package
Bisky wrote: Ok, this sounds promising, but difficult to set up in the *.ini files...
Time to create page: 2.084 seconds
Builds
- Voice alerts test build
