XK K110 (S-FHSS) build for Devo 7E and Devo 10
- SeByDocKy
19 Mar 2016 08:09 #44820
by SeByDocKy
Replied by SeByDocKy on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Demo flight
- victzh
19 Mar 2016 22:46 #44842
by victzh
Replied by victzh on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Where is the "Like" button?
- FlipRide1
20 Mar 2016 16:25 #44872
by FlipRide1
Replied by FlipRide1 on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
victzh, Your hard work is very much appreciated! Thank you.
- Fernandez
20 Mar 2016 19:41 #44881
by Fernandez
Replied by Fernandez on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Could we list it to the origin of the protocol; Futaba S-FHSS ?
I assume many more models will use it, than XK K110
- victzh
20 Mar 2016 19:47 #44882
by victzh
You mean here, in forums? I plan to release it really soon now, so we can make an announcement. I used XK and Orange equipment to implement it, and they behave slightly differently. So I think it would be only fair to mention it, not Futaba until someone confirms it works with real Futaba S-FHSS receivers.
- Babay
21 Mar 2016 09:07 #44908
by Babay
Replied by Babay on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
I did a simple test receiver for quadcopter NE Galaxy Visitor 2 (MASF11 FTR) - work fine! Assembled quadcopter without camera I will test in the near future.
- victzh
21 Mar 2016 17:49 #44930
by victzh
What kind of receiver it uses? Futaba's original?
- Babay
21 Mar 2016 18:02 - 21 Mar 2016 18:06 #44932
by Babay
No, not original. But marked "FTR" - Futaba Transmitter Ready. Here is a link to this quadcopter. First page of user manual contains this string: "This model is compatible with FUTABA FHSS 2.4GHz Transmitter".victzh wrote: What kind of receiver it uses? Futaba's original?
Last edit: 21 Mar 2016 18:06 by Babay.
- Leon
27 Mar 2016 11:47 - 28 Mar 2016 07:55 #45263
by Leon
Replied by Leon on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
HI Victzh
I USE FUTABA R2008SB AND DEVO10,SFHSS IS WORKING ON THE R2008SB
GOOD JOB!!
GOOD JOB!!
Last edit: 28 Mar 2016 07:55 by Leon.
- dc59
28 Mar 2016 00:14 #45311
by dc59
I was a really good news,Thanks Leon.
Replied by dc59 on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Leon wrote: HI Victzh
I USE FUTABA R2008SB AND DEVO10,SFHSS IS WORK ON THE R2008SB
GOOD JOB!!![]()
- victzh
28 Mar 2016 01:20 #45315
by victzh
Great! Thanks for reporting it, Leon.
- Slammer
28 Mar 2016 17:34 - 28 Mar 2016 18:26 #45347
by Slammer
Replied by Slammer on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Victzh/all,
just wanted to give you a heads up on the XK X350 power board and receiver board. I recently lost signal to my x 350 with the stock tx and it crashed upside down onto the only piece of concrete around cracking the power board...
Ordered all new PB, RB and 4 new ESC's to do a rebuild...this is the part i wanted you guys to hear....the new power board and receiver board are REV. 4 now. The receiver board looks a little different from the REV. 3....if you would like i could post a few close up pics later, just let me know..
I was also waiting for the S-FHSS build for 12S, do you think the change from Rev.3 to Rev. 4 will effect anything with the build?
Last edit: 28 Mar 2016 18:26 by Slammer. Reason: added video clip
- victzh
28 Mar 2016 19:01 #45349
by victzh
Thanks for the info. I don't expect changes in the behavior, it's a third party protocol, XK just implemented it. I never held X350 in my hands (true for the majority of models
), nevertheless it flies OK. That's the wonder of standards
I believe that last nightly builds should already have it. Check out the last one: www.deviationtx.com/downloads-new/catego...s-nightly-2016-03-19
- Slammer
29 Mar 2016 13:28 #45378
by Slammer
Thanks for your response, time and effort Victzh.... Hey quick question, How and where would i install a model config. file? I do not know much about this portion. Say i wanted to install a model config file for a walkera runner 250 on my 12s with deviation, how and where do i put that file? Guess you can tell i am new to this....
I have to say i was very excited to see SeByDocky fly the XK X350 with Deviation....
- victzh
29 Mar 2016 14:55 #45381
by victzh
It is probably described in the documentation and it is always good to read docs before using this. But as a shortcut:
1. switch your Deviated Devo to USB mode - easiest is to turn in on holding ENT key,
2. Open the Devo's drive on your computer and look for 'models' folder. You'll see many modelXX.ini files which represent individual models.
3. Copy over SeBy's file into one of them
4. Turn off Devo and turn it back on
5. Find your model among your models and select it.
6. Enjoy!
6. Enjoy!
- Slammer
29 Mar 2016 14:59 #45382
by Slammer
Thank you very much...That's kinda of what i figured but wanted to make sure....thanks again..
- Fernando
01 Apr 2016 09:52 #45548
by Fernando
Hi victzh!, the CC2500 module arrives before than expected from Banggood. I already got it and maybe today or tomorrow will make the mod to my transmitter Devo 8s. Is the protocol already included in the latest nightly on this wesite? Can you (or someone) provide me a Devo8S XK-K120 model?
Thank you
Replied by Fernando on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
victzh wrote: I hope by the time you get your module it would be propagated to the main build.
Thank you
- dc59
01 Apr 2016 12:16 - 01 Apr 2016 12:16 #45556
by dc59
You can find my DEVO10 config file for K120 as below,it should be used on 8S.
www.deviationtx.com/forum/builds/5569-xk...vo-10?start=20#44758
Thank you
Last edit: 01 Apr 2016 12:16 by dc59.
- Fernando
01 Apr 2016 12:18 #45558
by Fernando
Thank you, I will try it.
But I still do not know if the latest nightly for 8S includes already the F-SHSS protocol support. I hope so....
- Fernandez
05 Apr 2016 21:36 #45869
by Fernandez
For people looking for cheap S-Bus receiver with diversity, it should work with deviation?
www.banggood.com/CORONA-CR4SF-S-FHSS-2_4...itter-p-1006324.html
Time to create page: 0.720 seconds
Builds
- XK K110 (S-FHSS) build for Devo 7E and Devo 10
