Deviation v5.0.0 build with latest protocols
07 Mar 2018 15:03 #67959
Replied by vlad_vy on topic Deviation v5.0.0 build with latest protocols
I can avoid full page redraw after close dialog window. Now "Main layout edit" page is perfect!!!
Test builds updated.
08 Mar 2018 15:47 - 10 Mar 2018 06:07 #67972
Just for testing:
By the way, 128x64x1 GUI also use this feature, but it difficult to see the difference.
Now I can't find any GUI problems, tested with devo8, devo12-XMS, T8SG and devof12e-XMS.
Test builds for transmitters with color GUI:
Files deleted, see below...
1) Avoid full page redraw for any scrollable object for color GUI. It looks much more naturally if updated the scrollable area only, but not the full page.2) Avoid full page redraw with every item position change at "Main layout edit" page.3) Avoid full page redraw after close any dialog window.4) Fix bug with items delete at "Main layout edit" page.5) Fix "Standard" GUI "Travel adjust" page.I would like to get response from users: Is it worth to implement this feature?Now I can't find any GUI problems, tested with devo8, devo12-XMS, T8SG and devof12e-XMS.
Last edit: 10 Mar 2018 06:07 by vlad_vy.
- Stavross118
09 Mar 2018 08:18 #67975
by Stavross118
Replied by Stavross118 on topic Deviation v5.0.0 build with latest protocols
Hi vlad_vy
Which of these for the F12e
Many thanks vlad_vy for all your hard work
Stavross
Stavross
09 Mar 2018 08:36 #67976
For Devo F12E will you have to use nightly builds.
- Stavross118
10 Mar 2018 00:53 #67987
by Stavross118
Many thanks
10 Mar 2018 06:14 - 13 Mar 2018 04:25 #67988
"Deviation v5.0.0 build with latest protocols" (based on v5.0.0 release core)
* Avoid full page redraw for any scrollable object change. It looks much more naturally if updated the scrollable area only, but not the full page.
* Avoid full page redraw with every item position change at "Main layout edit" page.
* Avoid full page redraw after close any dialog window.
* Fix bug with items delete at "Main layout edit" page.
* Fix "Standard" GUI "Travel adjust" page.
* Optimize redraw objects after close dialog window, redraw underlying objects only.
Emulators:
www.deviationtx.com/forum/builds/6407-de...cols?start=340#68035
(10.03.2018)
Emulators:
(10.03.2018)
Last edit: 13 Mar 2018 04:25 by vlad_vy.
10 Mar 2018 06:16 - 13 Mar 2018 04:26 #67989
I can't attach more than 10 files, and so XMS builds attached with separate message
(10.03.2018)
(10.03.2018)
Last edit: 13 Mar 2018 04:26 by vlad_vy.
- M8A4X
- M8A4X
10 Mar 2018 07:55 - 10 Mar 2018 07:55 #67990
by M8A4X
Replied by M8A4X on topic Deviation v5.0.0 build with latest protocols
Hello vald_vy!
Just flashed your latest build onto Devo 12S and F12E (both XMS), all went well and response esp. on the Devo 12S is very good.
One question: on the 12S at homescreen (after power on), is it supposed to need a long-press ENT in order to get the "cursor" onto the configuration icon?
If I remember correct earlier it was just a short press which brought you to the TX-main menu (selection of TX confic, Model config, etc., etc.) which is now gone. This is no problem at all, I am just curious.
Last edit: 10 Mar 2018 07:55 by M8A4X.
10 Mar 2018 08:39 - 10 Mar 2018 08:49 #67991
I change nothing with buttons and touch processing. Just tested 25.02.2018 v5.0.0 build, it has the same behaviour. The short press ENT works with 128x64x1 GUI, and with nightly builds that has different menu system and different buttons and touch processing.
The code also show it has to be long press ENT button:
if(! GUI_GetSelected()) {
if ((flags & BUTTON_LONGPRESS) && CHAN_ButtonIsPressed(button, BUT_ENTER)) {
mp->ignore_release = 1;
GUI_SetSelected((guiObject_t *)&gui->optico);
Last edit: 10 Mar 2018 08:49 by vlad_vy.
- M8A4X
- M8A4X
10 Mar 2018 09:23 #67993
by M8A4X
Thank you for your clarification.
Admittedly I rarely use the hardware buttons on the 12S, only touch, therefore it was not clear to me if this is normal or not.
13 Mar 2018 04:13 - 14 Mar 2018 05:29 #68035
Fresh emulator builds
(13.03.2018)
(13.03.2018)
Last edit: 14 Mar 2018 05:29 by vlad_vy.
13 Mar 2018 04:27 - 14 Mar 2018 05:32 #68036
* Cosmetic fix at color GUI "Main layout edit" page.
* Code clean up.
Emulators:
(13.03.2018)
* Code clean up.
Emulators:
(13.03.2018)
Last edit: 14 Mar 2018 05:32 by vlad_vy.
13 Mar 2018 04:29 - 14 Mar 2018 05:37 #68037
(13.03.2018)
(13.03.2018)
Last edit: 14 Mar 2018 05:37 by vlad_vy.
14 Mar 2018 05:30 - 16 Mar 2018 04:51 #68053
(14.03.2018)
(14.03.2018)
Last edit: 16 Mar 2018 04:51 by vlad_vy.
14 Mar 2018 05:35 - 16 Mar 2018 04:52 #68054
* Fix 128x64x1 "Channel monitor->Stick input" page. Labels input name and value overlapped.
* Fix color GUI "Toggle select" page.
Emulators:
www.deviationtx.com/forum/builds/6407-de...cols?start=360#68053
(14.03.2018)
Emulators:
(14.03.2018)
Last edit: 16 Mar 2018 04:52 by vlad_vy.
14 Mar 2018 05:38 - 16 Mar 2018 04:52 #68055
(14.03.2018)
(14.03.2018)
16 Mar 2018 04:53 - 17 Mar 2018 10:50 #68119
(16.03.2018)
(16.03.2018)
Last edit: 17 Mar 2018 10:50 by vlad_vy.
16 Mar 2018 05:00 - 17 Mar 2018 10:50 #68120
* Fix screen redraw after close startup warning.
* Fix vertical alignment at devo12 mixer page.
Emulators:
www.deviationtx.com/forum/builds/6407-de...cols?start=360#68119
(16.03.2018)
Emulators:
(16.03.2018)
16 Mar 2018 05:01 - 17 Mar 2018 10:51 #68121
(16.03.2018)
(16.03.2018)
Last edit: 17 Mar 2018 10:51 by vlad_vy.
- kaligola
16 Mar 2018 09:20 #68124
by kaligola
Replied by kaligola on topic Deviation v5.0.0 build with latest protocols
i was out for a while, does this builds have 16 channel frskyx protocol to get rssi on last channel?
thanks
thanks
Time to create page: 0.443 seconds
Builds
- Deviation v5.0.0 build with latest protocols
