Ultimate Devo F12E (devof12e-XMS) builds
20 Feb 2017 13:24 - 20 Feb 2017 17:55 #59366
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4Mb) builds
Last edit: 20 Feb 2017 17:55 by vlad_vy.
- Artus
20 Feb 2017 13:33 #59367
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Ultimate Devo F12E (devof12e-4Mb) builds
Based on the idea of Vlady i have ordered now the SST25VF032B -But i want to have it switchable back so i decide to order some SOIC adapter boards - and i hope i am able to switch with the VDD connection from the original to the "ultimate"-version.
(I have the walkera 350 premium and i will bring this little bird step by step to Deviation)
20 Feb 2017 15:00 #59372
20 Feb 2017 17:30 - 20 Feb 2017 17:37 #59378
Last edit: 20 Feb 2017 17:37 by vlad_vy.
20 Feb 2017 18:28 #59382
21 Feb 2017 05:36 #59395
21 Feb 2017 08:26 - 21 Feb 2017 08:29 #59403
At the moment not done three menu items: "D/R & Exp", "Throttle curves" and "Pitch curves". If you have unmoded Devo F12E or Devo F7, you can test all implemented fixes with today Nightly Build. Do not touch "D/R & Exp" menu item, transmitter will reboot.
Last edit: 21 Feb 2017 08:29 by vlad_vy.
21 Feb 2017 14:14 - 21 Feb 2017 14:15 #59407
*Fixed XY-graph placeholder overlay "Splash" page for Devo F12E
At boot time empty XY-graph placeholder overlay "Splash" and "Safety Warning" pages and cut off portion of image.
vlad_vy wrote: It looks like empty placeholder (window) for model icon and graphs partially overlay Splash dialog and Safety dialog.
Last edit: 21 Feb 2017 14:15 by vlad_vy.
22 Feb 2017 13:00 #59452
22 Feb 2017 13:21 - 23 Feb 2017 12:39 #59453
DevoF12E and DevoF12E-4MB, with fixes, based on Nightly Builds:
Files deleted, see below...
Last edit: 23 Feb 2017 12:39 by vlad_vy.
- M8A4X
- M8A4X
23 Feb 2017 04:35 #59498
by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-4Mb) builds
You have made a lot of progress, can't wait to give it a try!
Finally the 4MB flash chip arrived, a quick comparison with the soldered in flash chip showed the difference in chip size you mentioned.
Well, steady hands for the win
23 Feb 2017 06:03 - 23 Feb 2017 06:13 #59500
I could not find why Mixer GUI "Standard" - "D/R & Expo" page crashes with "text" GUI, though it has the same code with Devo 10, so be careful. Perhaps someone else will be able to fix it.
Other known bug: model "Icon" load/change page doesn't display icon image.
Last edit: 23 Feb 2017 06:13 by vlad_vy.
- Moeder
23 Feb 2017 08:46 - 23 Feb 2017 08:48 #59506
by Moeder
Replied by Moeder on topic Ultimate Devo F12E (devof12e-4Mb) builds
I made it accessible again, pull request placed. Be aware the layout is still uncorrected, I leave that to you.
Since I have no write access to the repo, I cannot merge the pull request.
Last edit: 23 Feb 2017 08:48 by Moeder.
23 Feb 2017 08:59 #59507
Replied by FDR on topic Ultimate Devo F12E (devof12e-4MB) builds
I've merged, and sent you an invitation, so later you can merge pull requests after they were approved...
23 Feb 2017 11:15 - 23 Feb 2017 11:29 #59512
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
Last edit: 23 Feb 2017 11:29 by vlad_vy.
23 Feb 2017 12:40 - 23 Feb 2017 16:02 #59518
Last edit: 23 Feb 2017 16:02 by vlad_vy.
23 Feb 2017 13:22 - 23 Feb 2017 15:47 #59522
At first glance all pages fixed.
Known bugs:
* Model "Icon" load/change page doesn't display icon image.
* D/R can't be greater 100%, with 102% transmitter freeze and reboot. Probably it can be related to XY-graph.
* At "Throttle curves" and "Pitch curves" pages, value fields for inactive YX-graph points have not any visible highlight or cursor.
P.S. Advanced mixers have XY-graphs
Known bugs:
Last edit: 23 Feb 2017 15:47 by vlad_vy.
23 Feb 2017 15:41 #59528
23 Feb 2017 16:03 - 24 Feb 2017 16:22 #59530
Last edit: 24 Feb 2017 16:22 by vlad_vy.
- M8A4X
- M8A4X
23 Feb 2017 18:38 #59534
by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-4MB) builds
I just installed the 4MB chip, all went well.
I followed your advice to bend the chip pins pretty straight, put fresh solder at the pads and the chip pins, pretty easy soldering it in. I Just "securded" it with a bit of hot glue.
After installing deviation the "unusual way" for a F12E with formatting the tx drive in windows and putting the files on deviation booted fine
Also copying my models over went well, 4in1 modules is working!
I will test now a few "bugs" that occured to me on former nightlies.
Thank you for your work, vlad!!
Time to create page: 1.613 seconds
Builds
- Ultimate Devo F12E (devof12e-XMS) builds
