Ultimate Devo F12E (devof12e-XMS) builds
- Artus
03 Mar 2017 17:28 #59815
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic Ultimate Devo F12E (devof12e-4MB) builds
It's not not cheap 70 Euro for this board - but i have paid 150 Euro for one of my F12E - the other is the "B" version - and i have ordered now 2 Boards "A". If am was so silly to damage 2 boards in one night - than i can not prevented from loosing some money :/
I have found one person via "Ebay - Kleinanzeigen" who have a look on the my ruined boards - maybe he is able to repair - and he seems to be able to solder/unsolder the new boards - if its possible to repair one of the old boards i can decide what to to with the new ones.
03 Mar 2017 18:28 - 04 Mar 2017 17:23 #59816
Replied by vlad_vy on topic Ultimate Devo F12E (devof12e-4MB) builds
* Mostly cosmetic fixes. Alignment and resize a pages items.
DevoF12E and DevoF12E-4MB, with fixes, based on Nightly Builds:
Files deleted, see below...
Last edit: 04 Mar 2017 17:23 by vlad_vy.
04 Mar 2017 17:26 - 05 Mar 2017 09:46 #59844
* Cosmetic fix for "Main page config". It looks like cosmetic fixes finished.
Last edit: 05 Mar 2017 09:46 by vlad_vy.
- DIGGIDY
05 Mar 2017 09:23 #59867
by DIGGIDY
Replied by DIGGIDY on topic Ultimate Devo F12E (devof12e-4MB) builds
Hi, I've been looking at doing this mod, but I'm finding various different versions of the SST25VF032B chip in my search, 66mhz or 80mhz, SOIC or WSON?
I think this chip is the correct one, could someone confirm this please.
SST25VF032B
SST25VF032B
05 Mar 2017 09:43 #59868
It looks like correct one. I can't say about frequency, since I can't see such small numbers by my old eyes.
05 Mar 2017 09:45 - 05 Mar 2017 16:19 #59869
* Fixed bug on Load/Save page. Also, now Load/Save page show correct default icon for corresponding model type, not always heli icon.
Last edit: 05 Mar 2017 16:19 by vlad_vy.
- M8A4X
- M8A4X
05 Mar 2017 10:01 - 05 Mar 2017 10:01 #59870
by M8A4X
Replied by M8A4X on topic Ultimate Devo F12E (devof12e-4MB) builds
@DIGGIDY:
The SOIC version is the one you need, it has legs for soldering. The WSON version has solderpads on its side/underside (not BGA), so depending on its fit on the solderpads of the transmitter it could be a nicer finish. But I think this is for very experienced soldering skills and tools.
For clock frequency, the original flash chip has a maximum frequency of 33Mhz, so as long as the new chip has an equal or higher maximum frequency it will be ok.
Last edit: 05 Mar 2017 10:01 by M8A4X.
- DIGGIDY
05 Mar 2017 11:49 #59871
by DIGGIDY
Thanks for the info, that clears things up for me, also the SST25VF032B chip is no longer being manufactured and looks to be superseded by the SST26VF032B version according to the Microchip.
SST25VF032B
SST26VF032B
The later chip has a higher Clock Freq @ 104mhz, so this should still work, I may just buy them both and try the later chip first.
SST25VF032B
SST26VF032B
- M8A4X
- M8A4X
05 Mar 2017 12:16 #59872
by M8A4X
That one looks good, as it also is announced by microchip as the official successor of the previous one.
Please let us know if it worked! (or didn't.. hopefully not^^)
05 Mar 2017 12:52 - 05 Mar 2017 13:13 #59873
I don't think it will work, status register is different.
"Microchip SST26VF032B - not fully supported, block protection needs work"
At any case, different flash memory will need different build.
Last edit: 05 Mar 2017 13:13 by vlad_vy.
- DIGGIDY
05 Mar 2017 14:11 #59875
by DIGGIDY
Would this be a simple code change? Would it not be better to support the newer SST26VF032B rather than the obsolete SST25VF032B ?
I'm struggling to find any in the UK, all major component suppliers are out of stock and quoting the SST26VF032B as the replacement item. I've managed to find some on eBay, but I can image them becoming more difficult to source.
05 Mar 2017 15:06 #59877
Most of Devo transmitters use SST25VF032B.
05 Mar 2017 16:18 - 12 Mar 2017 12:37 #59878
Sorry, forget to add default icons to filesystem. Not very nice icons, but better than nothing.
Last edit: 12 Mar 2017 12:37 by vlad_vy.
- Moeder
05 Mar 2017 20:39 - 06 Mar 2017 06:45 #59881
by Moeder
Replied by Moeder on topic Ultimate Devo F12E (devof12e-4MB) builds
Indeed, SST25VF032B is depreciated and the successor is
not register compatible
From scanning through code and plenty of data sheets I think we should recommend a different replacement flash memory which also comes in 150 mil SOIC packaging eliminating the pin bending:
Since code for flash type auto-detection OS already written we could also recommend any of the three and add the small code changes necessary for Cypress and Adesto chips .
- ISSI IS25LQ032B : It should be compatible to IS25CQ032 which is already supported in the current code: Unfortunately it seems not to easy to get, the only bigger distributor who has it in stock is Mouser
- Adesto AT25SF321 : very small code addition necessary, but still the same problem of availability
- Cypress S25FL132K : very small code addition necessary, seems to be widely available (Mouser, DigiKey, RS components, Farnell to name a few)
Last edit: 06 Mar 2017 06:45 by Moeder. Reason: Precision of auto detect statement
06 Mar 2017 05:33 - 06 Mar 2017 05:44 #59889
Yesterday I've installed to DevoF12E-4MB 4in1 module, so now I have a fully fledged DevoF12E-4MB. It was the difficult task to solder wire to MCU pin (pin 89, B3). But as always it was successfully.
Instruction for soldering points for 4in1 module updated:
www.deviationtx.com/forum/7-development/...dule?start=940#55157
Last edit: 06 Mar 2017 05:44 by vlad_vy.
06 Mar 2017 11:51 #59895
Replied by FDR on topic Ultimate Devo F12E (devof12e-4MB) builds
I've made a category for these type of icons:
www.deviationtx.com/forum/font-based-icons-for-devo-f12e
Do you want me to move your posts with these icons there?
06 Mar 2017 13:49 #59899
Will be nice if you can move post with icons.
They are not font based and not BPM. "BW icons for Devo F12E". It is PBM (P4) "Portable Bit Map" monochrome file format.
06 Mar 2017 14:24 #59900
Sorry, I wrote it by heart...
Corrected the category:
www.deviationtx.com/forum/bw-icons-for-devo-f12e
What pixel dimensions do they have?
06 Mar 2017 16:20 #59905
Max 72x72 pixels
- Artus
06 Mar 2017 16:58 #59909
by Artus
Digg - there is one in Ireland - i have ordered 1 Lot (2pcs) 7 Euro shipping cost 6 Euro to Germany with tracking ...
Time to create page: 1.785 seconds
Builds
- Ultimate Devo F12E (devof12e-XMS) builds
