iRangeX iRX-IR8M builds no more?!
03 Apr 2018 09:14 #68476 by mchaves
Replied by mchaves on topic iRangeX iRX-IR8M builds
Banggood send to me IR8M V2, its ok? Gimbals ok? What do you say?!
03 Apr 2018 09:28 #68478 by vlad_vy
Replied by vlad_vy on topic iRangeX iRX-IR8M builds
I have not any IR8M, so can't say anything. But I think firmware will work for both version.
03 Apr 2018 09:39 #68479 by mchaves
Thank you. first version had several hardware problems, so I would like to know if someone has already received the V2 or if I am going to be a guinea pig, kkk
09 Apr 2018 05:38 #68567 by Alvarez
Replied by Alvarez on topic iRangeX iRX-IR8M builds
This person have tested the second version
13 Apr 2018 03:02 #68633 by orval
Replied by orval on topic iRangeX iRX-IR8M builds
Hello, to answer at Mchaves, I just received this Monday my Ir8m (purchase on Ebay delayed 7 days witch some problem's quality ...). In the end it's a "V2", good neutral with the gimbals and immediate power on-off.
I was able to update the firmware with the version of 2018-03-25 and install some models (E010, F36, Vtail, ...). I'm running in mode 1 and everything works fine.
Thank you for your work and the help provided by your forum.
24 Apr 2018 23:27 #68840 by bazzy80
Replied by bazzy80 on topic iRangeX iRX-IR8M builds
I am hoping someone can help me.
I have had this radio about 3 months and everything was working with deviation ir8m-v5.x.x-2018-01-31.
Now when I try to turn it on all I get is a USB icon on the screen. and the day before it workd fine,
Connecting it to windows 10( It sees it as a usb drive but then wont open anything)
I download deviation ir8m-v5.x.x-2018-03-25. and flacht it.
I checked if button ENT was stuck with a multimeter(it,s not)
Battery,s are oke.
But now i don,t see it any moor.
If anyone can help I would greatly appreciate it.
Sebastiaan
25 Apr 2018 03:38 #68847 by vlad_vy
It's frequent case with IR8M. Try format transmitter USB drive and copy filesystem from firmware archive. Use "Safely Remove Hardware" after writing filesystem.
26 Apr 2018 18:26 #68873 by bazzy80
It took some effort to even get it to formatted, but it finally did. Uploaded the firmware again and looks like it worked. Thanks. :)
28 Apr 2018 19:06 #68911 by souza
Replied by souza on topic iRangeX iRX-IR8M builds
I'm having a problem with the new version (deviation-t8sg-v5.0.0-9864d0d) is making the display look dark and I can not change it can someone help me please could I send a new version or one that works (This email address is being protected from spambots. You need JavaScript enabled to view it.)
28 Apr 2018 19:27 - 28 Apr 2018 19:27 #68912 by vlad_vy
What transmitter do you use? If it is iRangeX iRX-IR8M you need use the build from current topic.
www.deviationtx.com/forum/builds/7605-ir...uilds?start=60#68341
Last edit: 28 Apr 2018 19:27 by vlad_vy.
02 May 2018 20:43 #68980 by AlxG
Replied by AlxG on topic iRangeX iRX-IR8M builds
Where I can find the source code for iRangeX iRX-IR8M. I can't find a target IR8M in deviation git.
03 May 2018 03:49 #68986 by vlad_vy
I can provide you current IR8M source target based on nightly builds:
File Attachment:
File Name: ir8m.zip
File Size:11 KB
03 May 2018 05:39 #68988 by AlxG
Thanks a lot
03 May 2018 13:56 #68994 by souza
Good morning anyone could send me the tutorial of how to install on the board the cable system treiner? thank you
05 May 2018 05:12 #69054 by sfjuocekr
Replied by sfjuocekr on topic iRangeX iRX-IR8M builds
4IN1_FLASH can be used to flash newer firmware to the module:
github.com/pascallanger/DIY-Multiprotocol-TX-Module/releases
05 May 2018 07:41 - 05 May 2018 07:41 #69055 by Alvarez
But it's a hardware problem
I think the solution its change the module
Last edit: 05 May 2018 07:41 by Alvarez.
08 May 2018 06:12 - 10 May 2018 10:18 #69107 by vlad_vy
Since iRangeX iRX-IR8M (t8sg-v5.x.x-2017-09-19) is somewhat different from Jumper T8SG I will place here the builds for iRangeX iRX-IR8M.
Previous changes:
* RUD and AIL reversed to comply with common direction for Deviation.
* AUX4 and AUX5 reversed to comply with common direction for Deviation.
* All switches reversed to comply with common direction for Deviation.
* batt_critical set to 3900 since iRX-IR8M can use 4xAA battery.
* LCD Internal Resistor Rate (Rb/Ra) set to 4 (0x24).
* Add support for 6 independent trims set.
* Add protocol for Corona V1/V2 and Flydream V3, from hexfet
* Support 16 channels for FrskyX and 14 for AFHDS-2A, from hexfet
* Fix Corona protocol, from hexfet
Changes:
* More reliable and beep only once "beep" mux
(2018-05-08)
iRangeX iRX-IR8M based on Nightly Builds:
File deleted, see below...
Last edit: 10 May 2018 10:18 by vlad_vy.
09 May 2018 17:09 #69142 by Habasek
Replied by Habasek on topic iRangeX iRX-IR8M builds
hi, i have a transmitter-IR8M 8CH Multi-Protocol - where I will find the PPM for the second external module ? (Jeti Duplex TU)
10 May 2018 10:19 - 14 May 2018 04:40 #69158 by vlad_vy
Previous changes:
Changes:
* More reliable and sound only once "voice" mux
(2018-05-10)
Last edit: 14 May 2018 04:40 by vlad_vy.
Time to create page: 0.425 seconds
