Jumper T8SG V2 builds
- Moeder
17 May 2018 07:07 #69271
by Moeder
Replied by Moeder on topic Jumper T8SG V2 builds
I have started to really like the yellow
- Binnekamp
19 May 2018 11:58 #69316
by Binnekamp
Replied by Binnekamp on topic Jumper T8SG V2 builds
Hi everyone,
I am new to this forum so I don't know if this is the right topic for the reply.
I recently received my Jumper T8SG plus V2 and was testing it with the DSMx protocol, which apperrently uses the cyrf6936 part of the 4in1 transceiver.
I was able to bind the Inductrix tiny whoop, but had a lot of problems with the range being no more than about 6 meters with the output power set to 150mW.
I did some investigation on the Deviation forum and found out that the 4in1 transceiver uses the pins PE1 and PE2 to swith the rigth transmitter to the antenna according to the table below.
status PE1 PE2
A7105 RF signal to antenna 0 0
CC2500 RF signal to antenna 0 1
NRF24L01 RF signal to antenna 1 0
CYRF6936 RF signal to antenna 1 1
I decided to open up the transmitter and started measuring the levels of PE1 and PE2.
When powering up the radio (DSMx protocol) the first two seconds I saw a value of 3,3V on both the PE1 and PE2 pins, which according to the table is correct. However after the Jumper booted and the RF indicator LED at the front of the radio comes on, the value of PE1 dropped back to 0V and the value of PE2 stayed at 3.3V.
With this information I started testing some other protocols using a spectrum analyzer to measure the RF signals and found out that PE1 after the boot procedure of the radio always falls back to 0V, making both the NRF24L01 and the CYRF6936 radio parts and protocols useless.
Regards,
Tom
status PE1 PE2
Regards,
Tom
19 May 2018 12:37 #69318
Replied by vlad_vy on topic Jumper T8SG V2 builds
PE1 PE2 lines is not software controlled, there is a proprietary chip on mainboard that control these lines.
- Binnekamp
19 May 2018 12:57 - 20 May 2018 12:38 #69319
by Binnekamp
I can imagine, but who or what is telling that chip what tx to select when a certain protocol is selected from the menu?
Because the right one is selected when powering on for about two seconds based on protocol selection.
Edit: Created a video describing the test to show what happens with the RF signal two seconds after starting the T8SG.
Also visible on the spectrum analyzer when using the "Bind" option.
Jumper T8SG Plus V2 0 4in1 TX Range Problems
Last edit: 20 May 2018 12:38 by Binnekamp.
- PortosDoc
23 May 2018 12:04 #69375
by PortosDoc
Replied by PortosDoc on topic Jumper T8SG V2 builds
For rewrite the filesystem for try this night builds how can doing? im noob of this... I'm sorry
Thx for Your patience!
- SeByDocKy
23 May 2018 12:13 #69376
by SeByDocKy
Replied by SeByDocKy on topic Jumper T8SG V2 builds
Stupid question, no problem to flash th V2+ with the classic Walkera Dfuse ?
- PortosDoc
23 May 2018 12:20 - 23 May 2018 12:22 #69377
by PortosDoc
Deviation v5.0.0 build with latest protocols : deviation-t8sg_v2_plus-v5.0.0-2018-05-08
I have used this with dfuse. The first time i have wrong the frimware and with a lucky i have resolve re-install this brand of firmware.
I have looking and find this other night build and i was try ... I have read i need use other flasher deviation upload 09. i try this flasher, but without success (the icon layer of icon very large and the menu is unreadable)... using the latest night build deviation-t8sg_v2_plus-v5.x.x-2018-05-14.
Vlad_vy says i have wrong filesystem maybe... Any suggestion?
Last edit: 23 May 2018 12:22 by PortosDoc.
- PortosDoc
23 May 2018 13:21 - 23 May 2018 13:23 #69378
by PortosDoc
Resolved
I have try to find into youtube. i have find one same upgrade for the devo 7.. I have used this.
I have reinstall the firmware. Enter in usb mode and cancel all with format. After i have copy all file the nightbuild(dfu and zip nope). After i have reflashed the firmware deviation tx night build 5.14. Now all work!
Thx anyway for the support!
P.s.
calibrate the stick and now work good
P.s.
Last edit: 23 May 2018 13:23 by PortosDoc. Reason: Update
- Ask1me
23 May 2018 14:55 #69382
by Ask1me
Replied by Ask1me on topic Jumper T8SG V2 builds
For upgrade latest firmware t8sg v2+,
Im using windows 10, what program should I install?
is it deviation uploader 0.9 or Dfuse USB upgrade tools 2.31?
- PortosDoc
23 May 2018 22:20 #69394
by PortosDoc
Dfuse USB upgrade tools. I gotta me too windows 10
- flagadajones
27 May 2018 05:57 #69429
by flagadajones
Replied by flagadajones on topic Jumper T8SG V2 builds
hi,
could you add more trim for this target in target_defs.h
toRegards
#define NUM_TRIMS 6to
#define NUM_TRIMS 10- Moeder
28 May 2018 13:12 #69445
by Moeder
@Vlad_vy: I don't know if you saw my comment in your PR, but why do we havein T8SG builds? The switches are not labeled as such so it doesn't make sense to make these available in the build. They are probably leftovers from moving stuff over from the devo7e-256 (where they do make sense, as these are factory built-in switches and also labeled as such).
CHANDEF(HOLD0)
CHANDEF(HOLD1)
CHANDEF(FMOD0)
CHANDEF(FMOD1)- vlad_vy
28 May 2018 14:20 #69446
I don't see sense to rework channel.c, tx_buttons.c and capabilities.h in order to delete HOLD and FMOD switches and "nostock" option.
- flagadajones
28 May 2018 16:27 - 28 May 2018 16:27 #69448
by flagadajones
Hi @Vlad_vy,
i think (or it's my mistake) but there is a problem with buttons mapping (LEFT, RIGHT,UP,DOWN)
when i try to create a trim like this :
it always respond only on LEFT key press
thanks for your great job
[trim5]
src=Virt4
pos=RIGHT ====> Or DOWN,etc...
step=193
value=-100,0,0it always respond only on LEFT key press
Last edit: 28 May 2018 16:27 by flagadajones.
28 May 2018 18:34 #69449
I havn't problem with LEFT, RIGHT, UP, DOWN. I think "step" can't be more than 100. Probably you try to edit model.ini manually.
- flagadajones
28 May 2018 19:41 - 28 May 2018 19:41 #69450
by flagadajones
@Vlad_vy,
step=193 is the value for momentary trim. edited with TX GUI
I join a full model for your test
in this model Timer1 is reset on Right press.
But when i test it not reset by right but by left press.
the test procedure :
1 : up THR to start timer
2 : press Right ==> nothing append
3 : press Left ==> timer is reset.
if you change pos value in trim5 to Down like this :1 : up THR to start timer
2 : press Right ==> timer is reset
then why timer is reset by LEFT key ?
thanks for your help
pos=Down2 : press Right ==> timer is reset
Last edit: 28 May 2018 19:41 by flagadajones.
29 May 2018 03:38 - 29 May 2018 03:40 #69453
If you use 128x64 GUI, on the main page by default LEFT reset timers, RIGHT stop timers. So, don't use custom LEFT and RIGHT on the main page. For color GUI, on the main page EXT button reset timers.
Last edit: 29 May 2018 03:40 by vlad_vy.
29 May 2018 04:27 #69455
Now you can download Jumper T8SG V2 builds from Nightly builds section.
- flagadajones
29 May 2018 06:50 #69456
by flagadajones
ohh!! sorry i doesn't see that in the manual
- xalex75
23 Jul 2018 10:25 #69932
by xalex75
Replied by xalex75 on topic Jumper T8SG V2 builds
Hi.
Is the v2 now compatible with MJX (Bugs 3) protocol?
Time to create page: 1.097 seconds
Builds
- Jumper T8SG V2 builds
