7e/Ultimate7e, adding the devo version 4in1
- qprhooligan
22 Jun 2019 18:48 #74590
by qprhooligan
Looks like pin 9 and 13 are connected to the wrong place. Pin 13 of the 4 in 1 module goes to pin 9 on the TX board and pin 9 on the 4 in 1 module goes to pin 13 on the TX board.
Replied by qprhooligan on topic Ultimate7e, adding the devo version 4in1
HappyHarry wrote: next up is wiring in the actual module, I removed the 10pin header and soldered directly to the board, following the wiring diagram shared by cmPang (I've copied to this post) hook up the 4in1 to the 7e's pads
wiring guide and module hookup pics
(note that I had to use an alternate point to source 5v, it would usually be taken from pin6 of the rf board pins)
and that's the difficult part done, all that's needed now is to modify the hardware.ini to suit the wiring points, fit an antenna and go fly. though as I'm not keen on the rf path used on this daughterboard I'm going to modify it slightly, I'll be doing that tomorrow so I'll post details on that when it's completed.
- ebtex
29 Nov 2019 20:09 #75495
by ebtex
Replied by ebtex on topic Ultimate7e, adding the devo version 4in1
I made the 4-in-1 modification all perfect. I have a problem the devo 7E and do not verify it when I buy it, after a few minutes running the menu buttons do not do their functions. Where i have the problem ???????
It is a problem of the transmitter or the modification ??????
- Fernandez
03 Dec 2019 19:17 #75515
by Fernandez
Replied by Fernandez on topic Ultimate7e, adding the devo version 4in1
If you use extra switches, in a matrix, did you use the proper glass 1n4148 diodes (and not the bigger higher current black 1n4001 etc)
- ebtex
03 Dec 2019 19:53 #75516
by ebtex
If I put additional switches. Use 4 diodes 1N4004 on both switches.
In middle position it should not affect.
- Fernandez
04 Dec 2019 12:50 #75517
by Fernandez
probably you are right, however I would really recommend to replace diodes anyway (the 4004 I think are rectifier diode, and remember there have been reported issues before)
Otherwise you could put some fresh flux around CPU and reflow, to ensure there is not a tiny soldering crack. My both U7E with the the new CPU run perfectly fine.
- RobC62
04 Dec 2019 15:24 #75518
by RobC62
Replied by RobC62 on topic Ultimate7e, adding the devo version 4in1
Yes - use copious amounts of flux (flux is the key!) reflow the processor leads. I had the same symptoms with the 3rd one I did - and no bridges were visible to the naked eye.
- ebtex
04 Dec 2019 19:34 #75519
by ebtex
Thank you very much for the support received.
I will follow your advice.
- philphil
12 Jan 2020 15:19 #75692
by philphil
Replied by philphil on topic Ultimate7e, adding the devo version 4in1
- ebtex
23 Sep 2020 18:35 #76819
by ebtex
Replied by ebtex on topic 7e/Ultimate7e, adding the devo version 4in1
I have a problem, I made the 4in1 modification and only the CYRF6936 module works.
The other modules, when you choose a protocol and link to it, do nothing.
I have checked the wiring and it is correct.
I don't know what to do
24 Sep 2020 04:09 #76820
Replied by vlad_vy on topic 7e/Ultimate7e, adding the devo version 4in1
Do you enable chips and related ports in "hardware.ini"? If not, all protocols for these chips will have asterisk in front of protocol name.
- ebtex
25 Sep 2020 13:40 #76826
by ebtex
I probably didn't do this step, hardware.ini.
Thank you
Thank you
- ebtex
16 Aug 2021 13:02 #77523
by ebtex
I have my Devo 7e, with the multiprotocol module. I have a problem, I want to access the channel order, but I can't find the way to configure Wltoys 912. What are the steps to access that page and change the channel order.
Time to create page: 0.128 seconds
