Devo-10 basic config for servo on ch10
- Giubelli
25 Apr 2020 09:48 #76203
by Giubelli
Devo-10 basic config for servo on ch10 was created by Giubelli
Hi everyone, I'm very newbie and I need help, I have a DEVO-10 radio (last deviation firmware) with the RX002 receiver, I would like to connect a servo on the receiver's ch9 and control it with the radio's AUX5 potentiometer, is this possible?
Thanks!!!
Thanks!!!
- -=Hubi-Dirk=-
25 Apr 2020 19:51 #76204
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo-10 basic config for servo on ch10
Yes. The receiver is a RX 1002, right?
- Giubelli
26 Apr 2020 10:40 #76205
by Giubelli
Replied by Giubelli on topic Devo-10 basic config for servo on ch10
Hi Hubi thanks for the quick answer! Now I'm able to move the servo but I can't rotate it 180 degrees, only about 40 degrees ... I set the channel on Simple mode but I can't find a curve that turns the servo in the full range... Yes the receiver is the RX1002.
Thanks!!
Marco
Thanks!!
Marco
- -=Hubi-Dirk=-
26 Apr 2020 15:33 #76206
by -=Hubi-Dirk=-
Take a look at the Mixer "Ch9" on the left row. There you can modify the Values for "Max/Min Limit" and "Scale - / +". Try what happen when you change the values.
What Servo do you use?
- Gerry
- Bbrad
27 Apr 2020 08:01 #76207
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Devo-10 basic config for servo on ch10
Also make sure pots on Devo are calibrated properly in tx menu.
- Giubelli
27 Apr 2020 18:48 #76210
by Giubelli
The servo is the small towerpro sg90 9G, I have try with limits and scale, the only result is about 40 ° in different positions but never 180°
-=Hubi-Dirk=- wrote: Take a look at the Mixer "Ch9" on the left row. There you can modify the Values for "Max/Min Limit" and "Scale - / +". Try what happen when you change the values.
- -=Hubi-Dirk=-
28 Apr 2020 09:49 #76211
by -=Hubi-Dirk=-
Right Calibration done like Gerry wrote?
- Giubelli
28 Apr 2020 18:36 #76212
by Giubelli
Yes, calibration is OK and the ch9 in mixer output monitor change from - 250 to 250, the movement of the servo is linear with the pot position but the range is about 90° not 180°...
- Gerry
- Bbrad
28 Apr 2020 23:24 #76213
by Gerry
Interesting, just hooked up a SG90 servo to an RX1201 receiver and Devo 12e, servo on channel 10 and Aux5 pot and get the same result.
I don't know if my servo is 180 deg. on servo tester I get the same travel as on devo 12e.
Try sevo tester to make sure servo is 180 deg.
Time to create page: 2.089 seconds
