need config for solo pro model 260
27 Dec 2012 17:22 #4304 by jdowdle
need config for solo pro model 260 was created by jdowdle
have tried, using heli template, cant get it to bind.
anyone have a working file, or one close I might try?
thx.
27 Dec 2012 17:34 - 27 Dec 2012 17:35 #4306 by rototophe
Replied by rototophe on topic need config for solo pro model 260
Solo Pro 260 Protocol is not supported by Deviation.
You can only bind to Nine Eagles models using a "J" series Tx atm.
Last edit: 27 Dec 2012 17:35 by rototophe.
27 Dec 2012 18:22 #4307 by jdowdle
Replied by jdowdle on topic need config for solo pro model 260
ok, thx. I was hoping it would work.
Can you tell me if the V911 series will work, or is it the same?
thx.
27 Dec 2012 19:23 - 27 Dec 2012 19:24 #4308 by rototophe
Yes the V911 (and the WLToys quadcopters as well) are supported.
However you need to perform a small hardware mod in order to use the FlySky protocol.
See here:
deviationtx.com/repository/Documentation/
and look for the "Flysky_To_Devo.pdf" document.
Hope this helps.
Last edit: 27 Dec 2012 19:24 by rototophe.
28 Dec 2012 00:09 #4315 by jdowdle
thanks, I see.
Time to create page: 0.377 seconds
