blade 120sr config?
28 Dec 2012 15:49 #4322 by quikster
blade 120sr config? was created by quikster
does anyone have a working blade 120sr config.
28 Dec 2012 17:18 #4325 by coaster
Replied by coaster on topic blade 120sr config?
here we are ...
cheers
Coaster
28 Dec 2012 17:32 #4326 by quikster
Replied by quikster on topic blade 120sr config?
28 Dec 2012 17:36 #4327 by quikster
is the type supposed to be a plane or does it even matter?
28 Dec 2012 18:03 #4328 by sbstnp
Replied by sbstnp on topic blade 120sr config?
quikster wrote: is the type supposed to be a plane or does it even matter?
Type only matters if you do CCPM on the TX. 120SR is a FP flybarred so no CCPM.
But, it is safe to change it to heli, even if it doesn't matter, just to be semantically correct.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
28 Dec 2012 18:57 #4330 by quikster
Thanks. what about throttle hold? i've tried to play around with the settings and compared them to other settings like Tomz's minicp settings which has a working throttle hold but i can't seem to get it to work on the 120 regardless of what i do.
Is it just not supported with other protocols?
28 Dec 2012 19:02 - 28 Dec 2012 19:03 #4331 by sbstnp
Again, TH has nothing to do with the protocol, but with the Throttle channel itself.
On Devo10, I do this:
1. Go Model setup/Mixer
2. Select THR channel
3. Select from Safety entry a switch to act as TH.
4. Make sure Safety value is -100.
Done.
Should be similar on the 8 or 6, maybe easier.
I really recommend that you read the manual, even multiple times if needed, you will be doing yourself a favor.
Devo 10 + 4in1
Spektrum Dx9
Last edit: 28 Dec 2012 19:03 by sbstnp.
28 Dec 2012 19:05 - 28 Dec 2012 19:21 #4332 by Joshua
Replied by Joshua on topic blade 120sr config?
i can upload a config with throttle hold, flite modes and with different dualrate/expo with mix and RUDD/DR switches.
Here we go:
Throttle hold with Gear switch.
DR/Expo for ELE, AIL with MIX 0/1/2 switch
DR/Expo for RUD with RUD D/R switch
Timer stop on "Hold"
Throttle curve on FMODE0-FMODE2
(Blade120.bmp is from this forum)
ciao, Bernd
Last edit: 28 Dec 2012 19:21 by Joshua. Reason: Upload files
28 Dec 2012 19:32 #4336 by quikster
Done.
awesome, thanks I got it now. still learning the setup for deviation
Time to create page: 0.286 seconds
