Settings Parkzone F27-Q Stryker Micro Ultra needed
10 Jan 2013 20:04 #4906 by harald.doerr
Somehow I can not manage to set this model. Anybody a settings file or a proxy?
Thanks a lot
11 Jan 2013 06:56 #4917 by Sunwalker
Morning
I have made a Delta DSM 2 File . I will order a Mini Stryker in the Next Time.
For this i have make this File but it´s only a Test File . For Ohter question´s contact me via Pn (gerne auch in Deutsch) or in The Rcline Forum
File Attachment:
File Name: deltadsm2.ini
File Size:4 KB
23 Jan 2013 11:02 #5430 by harald.doerr
Replied by harald.doerr on topic Settings Parkzone F27-Q Stryker Micro Ultra needed
Thanks for the file.
Was not really able to test it yet in full detail.
The Elevation seem to need a Reverse.
In addation some Dual Rate and Expo may be needed.
Other than that the file is great!
Thanks a lot.
Will upload my final versions, once its done and tested.
13 Feb 2013 13:47 #6356 by man
Hello.
I also look for the .ini file for the UMX strycker F27-q, have you reussis to find the good solution for this model?
Thank you in advance.
Cordially.
15 Feb 2013 13:30 #6402 by harald.doerr
Was still not able to fly my Stryker yet :( . But attached is the file which is working with the plane.
Have used 40% Expo on Elevator and Aileron.
Both are limited to 60%.
Shall be good enough for the first flights :woohoo:
No Expo or Dual Rate on the Rudder.
Regards, Harald
24 Feb 2013 01:43 #6915 by man
Safety(Salute).
Thank you for the file, I am going to test, we shall see good, if the base(basis) is, ca will be deja well, I would refine the apres regulations.
Thank you.
24 Feb 2013 16:39 #6964 by harald.doerr
Have used the settings with the plane yesterday.
Frankly: :-) Its just great fun.
Be careful. Use D/R and Expo.
Plane is very much effected by wind.
11 Oct 2013 21:19 #14508 by EduardS
harald.doerr wrote: Hi,
Regards, Harald
Harald, could you post the stryker.bmp in the Icon forum?
07 Dec 2013 08:14 #16354 by harald.doerr
Just saw your note. Will do that now.
01 May 2014 18:59 #22838 by Sero
Both posted configs have a nasty flaw, if the mix-switch is in any other position than 0, the elevons are not controlled at all.. :huh: Flick the switch by accident while flying, and bang, lawn dart...
If there is need for a corrected version, please make yourself heard here.
Time to create page: 0.137 seconds
