Searching for a V450D01 - WK2801 setting
13 Jan 2013 06:58 #4957 by fassla
For sure some of you own a V450D01 using the 2801PRo on your Devo.
Can you please send me your ini as a reference for me.
This is my fist attempt to find out all the settings.
I have 3 V450D01 (old version) and all of them have a Semiscale Fuselage.
So lateron I can provide my files for all friend of V450 Scale Helis
THX
andi
QR X350
Blade QX3 AP CGO2
Devo 8s
13 Jan 2013 10:01 - 15 Jan 2013 22:41 #4961 by domcars0
Replied by domcars0 on topic Searching for a V450D01 - WK2801 setting
Hi
I think you may try this model.ini which is for my TRex 250 with the RX2702V RX.
Most important in this case is the RX. You will probably have some minor adjustments to do.
Hope it helps.
Last edit: 15 Jan 2013 22:41 by domcars0.
15 Jan 2013 20:43 #5047 by fassla
Replied by fassla on topic Searching for a V450D01 - WK2801 setting
THANK YOU
I copied the file and now i'm finetuning to my needs.
Most of the settings are close to my settings in the TX 2801Pro.
You saved me a lot of time ;-)
QR X350
Blade QX3 AP CGO2
Devo 8s
15 Jan 2013 22:47 - 15 Jan 2013 22:53 #5049 by domcars0
Take care of channels 1, 2 & 6 subtrims which are probably not good for your servos.
Last edit: 15 Jan 2013 22:53 by domcars0.
16 Jan 2013 12:54 #5061 by Hexperience
Replied by Hexperience on topic Searching for a V450D01 - WK2801 setting
Why do you have the swash type as 120? Does the 2702 not do the ccpm mixing for you? I will be installing one on a trex clone soon but was not going to use a swash type. Just straight channels like any other fbl.
16 Jan 2013 16:17 - 16 Jan 2013 16:18 #5068 by domcars0
Hexperience wrote: Why do you have the swash type as 120? Does the 2702 not do the ccpm mixing for you?
Yes, it doesn't do the ccpm mixing.
Hexperience wrote: I will be installing one on a trex clone soon but was not going to use a swash type. Just straight channels like any other fbl.
Not with the RX2702V ....
Last edit: 16 Jan 2013 16:18 by domcars0.
16 Jan 2013 17:18 #5069 by Hexperience
Wow.. Thanks for that info. Im surprised by that....
Cheers
16 Jan 2013 20:55 #5073 by domcars0
You can see that by reading the V450D01 with RX2702V manual :
16 Jan 2013 21:31 #5079 by RandMental
Replied by RandMental on topic Searching for a V450D01 - WK2801 setting
The Genius and V120D02s are using "1 servo/Normal". As domcars0 confirmed the RX2702V-D on the V450D01 (V1) uses 120'.
16 Jan 2013 21:36 #5080 by Hexperience
Interesting. So you can sub trim the 3 servos separetly?
16 Jan 2013 21:54 - 16 Jan 2013 21:56 #5082 by RandMental
Yes you can, set the little slide switch to sw.set to go into the mech setup mode and press the pushbutton once. This disables the gyros, bypasses the RX algorithms and you can do the subtrims.
Last edit: 16 Jan 2013 21:56 by RandMental.
16 Jan 2013 21:58 - 16 Jan 2013 22:02 #5083 by domcars0
Hexperience wrote: Interesting. So you can sub trim the 3 servos separetly?
???? :huh: ?? I think that in all cases (module that make ccpm or not) you can "subtrim" the 3 servos separetly... subtrims are for servos (not for functions)
[EDIT] Oups sorry I understand what you means ...
But some cppm FBL modules allow subtrims (for example my Helicommand allow that)
Last edit: 16 Jan 2013 22:02 by domcars0.
04 Apr 2013 23:09 #8543 by mwp
Fassla, is that you could release the settings that you made ​​in your V450D1? I have one like yours and I'm having the same problem as you passed.
Thank you.
07 Apr 2013 06:24 - 07 Apr 2013 07:02 #8676 by fassla
Dear all,
For all users setting up the RX2702V the fist time I recommend to use the new version V3. Thumbs up to the team !!! B)
Please start with setting: Mixer GUI: STANDARD !!!
Then start with the swash setting 3x120
Then you can easily set all parameters as per your needs.
I tested yesterday almost all settings and I'm very happy with the new layout and usability.
Later on you can switch to andvanced if you have the feeling something is missing.
Regarding my settings - as you can see I fly only scale heli - so my settings are tailored to my models. Even my settings of the models differ a lot as I really "fly" my settings.
But if some of you would like to send me your settings and your problem I can check and give you some advice. :)
QR X350
Blade QX3 AP CGO2
Devo 8s
Last edit: 07 Apr 2013 07:02 by fassla.
07 Apr 2013 12:46 #8679 by mwp
Fassla friend, I'm new to the hobby, currently have multiple walkera helis, (02 120d02 with rx 2610, new120d02s 01, 01 v450d1 a minicp a hm83 # and a ladybird, my problem is that I miss a lot in this new system programming the tx because in some cases has to change channels and turn and move I do something wrong then I started to get ready and go settings trying to understand the same by making small changes to some things I've learned.
I'm currently with 3 problems, the first is to get a beginner to setup with my 450d1 rx 2702v (I do not know how to upgrade to this rx update this if there is such) is to get another one for my setup with hm83 # rx 2801 and lastly also more important to me, whether you can put a receiver on my D-RX2637H hm83 # and configuration for the same.
I'm really enjoying this community, helping staff to see here, I live in Brazil and here we have a lot of shortage in this hobby besides being very expensive (our income is small compared to developed countries) and the government punishes us when we do taxes with many imports (taxam our purchases in the final "product and freight" abroad in 100% + 16% iof adding 116% tax on the total value of each purchase) and usually have to wait more than 60 days to receive the goods, I mean it in order to understand and can not ask me to change the rx and see how this hobby is expensive for us Brazilians.
I apologize for English using a translator because I'm more grateful to all the help you can give me.
Thanks and a great weekend.
07 Apr 2013 12:50 #8680 by mwp
just remember that my ex is walkera series and not devolution
07 Apr 2013 16:41 #8692 by fassla
If you use STANDARD GUI it is very easy for V450D01.
Setting swash 3x120 and reduce all 3 values below to 40%. Then the heli is less agressive.
if you already have some setting let me know I can check and give some advice.
QR X350
Blade QX3 AP CGO2
Devo 8s
11 Apr 2013 01:00 #8840 by mwp
sorry to leave the forum by now, had a problem with my v450d1, the tail servo is failing and narrowly missed an accident happened, I'm waiting for a tail servo from futaba I bought there and get back the settings the same, thank you anyway time wasted by me and so I will continue to get the servo my doubts.
Thank you and good flights.
Time to create page: 0.895 seconds
