Align T-Rex 150 DFC - 3D Settings
- Tom Z
10 Jan 2014 17:07 - 22 Apr 2014 21:47 #18323
by Tom Z
Align T-Rex 150 DFC - 3D Settings was created by Tom Z
This model is for use with the Spektrum DSM2/DSMX Satellite Receiver.
NORM - 0% 30% 50% 55% 60%
ST- 1 - 100% 90% 80% 90% 100%
ST- 2 - 100% 90% 80% 90% 100%
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain - These are the values I used then converted them to the deviation values.
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -6%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
- 7 Point Throttle and Pitch Curves
- Throttle hold on the RUDD D/R switch
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Model 22 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 22-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 22 instead.
Set your ESC Li-po Cell Count setting to "AUTO". Default setting is 2 CELL.
ESC Settings
Functions
6. Li-Po Cell Count - Make sure to set this to "Auto".
Do not use the "2S" setting. You will have an extreme power/headspeed loss using the default "2S" setting.
Pitch Curve
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
DR/EXPO
Switch Position
Switch Position
Last edit: 22 Apr 2014 21:47 by Tom Z.
- micro
15 Jan 2014 15:25 - 15 Jan 2014 15:34 #18537
by micro
Replied by micro on topic Align T-Rex 150 DFC - 3D Settings
Will this work on v3 with 7e or must the upgrade be performed first. Are there any tutorials to walk through the switching of output channels ?
Last edit: 15 Jan 2014 15:34 by micro.
- Tom Z
16 Jan 2014 14:13 - 16 Jan 2014 14:16 #18563
by Tom Z
Replied by Tom Z on topic Align T-Rex 150 DFC - 3D Settings
I tried some v4 models in the v3 emulators (Devo 7e, 8, 10).
See this post for more information.
deviationtx.com/forum/model-configs/2578...er-settings?start=20
Last edit: 16 Jan 2014 14:16 by Tom Z.
- Tom Z
23 Feb 2014 23:44 #20821
by Tom Z
Model updated (4).
I just found out the Align manual was incorrect on the gyro values.
The model first posted gyro settings were:
Mix Switch
Pos 0: 55%
Pos 1: 65%
Pos 2: 75%
Updated model gyro settings are now:
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
70% to 75% is the most common values used on the internet. Fine tune the gyro gain to meet your needs.
Mix Switch
Pos 0: 55%
Pos 1: 65%
Pos 2: 75%
Mix Switch
Pos 0: 65%
Pos 1: 70%
Pos 2: 75%
- Waterfly
21 Mar 2014 19:29 #21710
by Waterfly
Replied by Waterfly on topic Align T-Rex 150 DFC - 3D Settings
Tom: will this work with Devo7? I am currently using your standard model; but I would like to see if I can fly the 3d.
- Tom Z
24 Mar 2014 00:05 #21775
by Tom Z
I think you mean Devo 7e as the Devo 7 is not supported by the Deviation firmware.
My models will bind and work with the Devo 7e.
My custom GUI in the model file is also made to use with the 7e.
The issue is that the 7e has less switches. So you will only have one stunt mode plus you will not have DR/EXPO 1 and 2.
See my post here for an example:
deviationtx.com/forum/model-configs/2686...tings?start=20#20940
Time to create page: 1.581 seconds
Model Configs
- Align T-Rex 150 DFC - 3D Settings
