Nine Eagles Solo Pro 125 - Standard Settings
- Tom Z
04 Feb 2014 23:29 - 15 Feb 2014 23:39 #19842
by Tom Z
Nine Eagles Solo Pro 125 - Standard Settings was created by Tom Z
Nine Eagles Solo Pro 125 (125A)
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Normal: Custom Curve
ST-1: 100% Flat Across
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Hover at about half throttle.
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
- Low dual rates and positive expo to tame the heli down
- Throttle hold on the RUDD D/R switch
- 7 Point Throttle and Pitch Curves
- TX Power=100mW
- Channels=6
- Protocol=J6Pro
- No Fixed ID
Model 46 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gear Switch
Pos 0: 38%
Pos 1: 75%
Throttle Curve
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:39 by Tom Z.
- jm2cau
11 Feb 2016 11:59 #42997
by jm2cau
Replied by jm2cau on topic Nine Eagles Solo Pro 125 - Standard Settings
I do not understand why it is not stable with this file it turns left
thank you for helping me
Time to create page: 0.193 seconds
Model Configs
- Nine Eagles Solo Pro 125 - Standard Settings
