What low voltage on Hbsan 107C
- redjet
01 Sep 2014 21:42 #25456
by redjet
What low voltage on Hbsan 107C was created by redjet
Hi
. This gets asked over and again but I've not found a clear answer.
What low voltage value are you setting for your Hubsan?
I'm flying a 107C. I've set to 3.5v but this is drawn voltage so goes off quite early into a flight.
I get another minute or so before the Hubsan LEDs start to flash.
(Also seems my 6x 380mah are shot
- only getting 180-200mah after 10 cycles - because I've been relying on the LEDs rather than low voltage maybe?)
What's people's experiences please?
- Arakon
02 Sep 2014 18:17 #25469
by Arakon
Replied by Arakon on topic What low voltage on Hbsan 107C
Same as any other LiPo. 3.3V at the lowest if you land immediately when it goes off. 3.4V if you want to be safer.
- mikemacwillie
02 Sep 2014 23:40 #25474
by mikemacwillie
Replied by mikemacwillie on topic What low voltage on Hbsan 107C
I have mine set at 3.3v as well. The LEDs seem to blink around 3.2V, which is a bit low.
- redjet
04 Sep 2014 19:42 #25506
by redjet
Replied by redjet on topic What low voltage on Hbsan 107C
Thanks. I've got mine set around 3.4 but that beeps very quickly.
Problem I have then is the brand new Overlander 380mah batteries are only giving 2mins
flightime! Going just off the flashing lights I could get around 5 minutes. Do you get the same?
- redjet
07 Sep 2014 08:28 - 07 Sep 2014 08:28 #25534
by redjet
thanks for replies. Seems go with low voltage warning for better batteries or flashy lights for decent flight times..
Last edit: 07 Sep 2014 08:28 by redjet.
- mikemacwillie
09 Sep 2014 21:38 #25592
by mikemacwillie
Yeah, if you want the alarm to sound around the same time as the flashy lights, the point is 3.1v.
- redjet
10 Sep 2014 22:25 #25609
by redjet
thank you. Really appreciated.
Time to create page: 0.291 seconds
Model Configs
- What low voltage on Hbsan 107C
