Quad throttle curve suggestions
30 Aug 2015 23:25 #37316 by jacklscott3
Quad throttle curve suggestions was created by jacklscott3
Hey there
Does anyone have any suggestions for the best way to set up a throttle curve for my quad that would make hovering easier?
Im currently working with a 7 point curve
1(-100)
2(10)
3(32)
4(42)
5(52)
6(60)
7(65)
The curve didn't work as well as I was hoping, so any suggestions for making the ol' quad hover with more stability would be greatly appreciated:)
-Jack
05 Dec 2015 14:13 - 05 Dec 2015 14:16 #40600 by MasterRC_sTudenT
Replied by MasterRC_sTudenT on topic Quad throttle curve suggestions
@DigitalMD I'd like to setup a throttle curve that does what you suggest (Hover at 50%) The Flight Controller I'm working with (Scisky Brushed) Skyrockets as soon as I move the stick well below the 50% mark. And is not flyable indoor. I would like extra-to-max throttle above 50% and again, hover and tame at 50% and below.
On your recommendation, do the above 50% points (65 90) max out the throttle at 90? Meaning throttle all the way up/maxed will not reach 100% +?
Also, how/where would I incorporate it into my existing model.ini file?
Thank you in advance
Last edit: 05 Dec 2015 14:16 by MasterRC_sTudenT.
18 Feb 2016 18:56 - 18 Feb 2016 19:09 #43248 by mjsnosk8
Replied by mjsnosk8 on topic Quad throttle curve suggestions
Here is my scisky / shark .ini config for devo 7e. I had the opposite problem as @MasterRC_sTudenT, struggled to get hover down to 50% throttle from 80ish. I set all tx-channels min/max to +/-250 and use (tx) scale+\- to get ranges to 1000 - 2000 in Cleanflight. Used CF's motors tab to find min throttle and set that value in settings tab.
My 7pt curve:
-100
-22
15
44
68
84
100
File Attachment:
File Name: microshk.ini
File Size:4 KB
Last edit: 18 Feb 2016 19:09 by mjsnosk8.
Time to create page: 0.209 seconds
