Xinxun X39 config
03 Sep 2015 04:24 - 03 Sep 2015 04:25 #37394 by 187
Xinxun X39 config was created by 187
I slapped a x39 xinxun board on a 120mm frame with 8.5mm motors.
It is flying great after a bit of playing however...
it will randomly do a high speed flip if I do a high speed run and try to slow down to a hover... only some times.
also the yaw is slow but no adjustment seems to effect it.
has anyone had any luck with this yd /xinxun protocol and setting this up well?
edit - I need to figure out where the rates and flip is more specifically.
Last edit: 03 Sep 2015 04:25 by 187.
04 Sep 2015 10:29 #37436 by 24inwork
Replied by 24inwork on topic Xinxun X39 config
Hello dude i have seted up module from my XinXun Tx to devo 10 today and be able to bind my quad but the control is a bit crazy.
I am not sure how it is called correctly Aileron? When I pull right stick full forward it takes a huge angel and go down how to decrease it ?
Also i am not sure but it looks like i do not have full throttle is there any way to check this?
05 Sep 2015 04:43 #37458 by 187
Replied by 187 on topic Xinxun X39 config
Try this one see if it works.
05 Sep 2015 05:11 #37459 by 187
If anyone here is familiar with this model could you add the rates and the flip to the above config as it only contains the first four channels so far.
thank you
08 Sep 2015 16:37 - 08 Sep 2015 16:43 #37573 by 24inwork
Guys plz help with this one
Lights turn on/off not working but flip is turned on and not turning off with this code wich i wanted to trigger on GEAR switch
[channel5]
template=simple
max=100
min=0
[mixer]
switch=RUD DR0
dest=Ch5
curvetype=min/max
points=0
[channel6]
max=100
min=0
template=simple
[mixer]
src=GEAR0
dest=Ch6
curvetype=min/max
points=0
File Attachment:
File Name: model2.ini
File Size:12 KB
Hovering flight mode Fmode0,
Sport mode Fmode1
Experimental Fmode2
Last edit: 08 Sep 2015 16:43 by 24inwork.
08 Sep 2015 21:44 #37575 by 24inwork
The last flying build
15 Sep 2015 08:23 - 15 Sep 2015 08:24 #37775 by 24inwork
The last stable config for XinXun 39 or any other models wich you want to fly, just replace the protocols,
config for Devo 10 but it will work for most Devos with devention software.
My XinXun39 frame is dead a little bit, so i am waiting for spare parts that's why config a little bit ugly, i will make it more optimized in code and style when i will fix my xinxun.
3 Flight Modes support on FMODE (Right Switch)
0 - Begginers mode, very soft, responsive and nice to fly for beginners.
1 - Advanced mode more aggressive and responsive.
2 - Advanced mode testing.
AUTO FLIP TURN ON/OFF ON GEAR SWITCH
NOTES: XINXUN39 has only 5 channels to control. There is no way to turn on/off lights ;((
File Attachment:
File Name: model1.ini
File Size:16 KB
Last edit: 15 Sep 2015 08:24 by 24inwork.
16 Sep 2015 03:18 #37797 by 187
nice going to test this now
16 Sep 2015 16:20 #37806 by 24inwork
How it is going ?
16 Sep 2015 21:43 #37808 by 187
Its good, auto flip on and off on channel 5 HOLD0 and 1 is working
I had to disable the 1st mode and just use the 2nd and 3rd as I have a Devo7e
In both advanced flight mode 1 and 2 it is responding very nicely, I didn't bother with flight mode 0
17 Sep 2015 03:10 #37813 by 187
I forgot to mention, when I used your config, ELE and AIL are swapped, needed to change this and it was ok.
19 Nov 2015 19:35 #40222 by Gazono
Replied by Gazono on topic Xinxun X39 config
For lights control try to move both sticks in the bottom-right corner for 2-3 sec. I have X30 board with Devo7e. It works.
Time to create page: 0.264 seconds
