elevon setting
20 Apr 2016 23:12 #46906 by chaos1
elevon setting was created by chaos1
:S hello im firley new been at this for awhile trying to get it right can use some help i have devo7e with devo rx and the pnf slope sorer wing from hobbyking all working exsept can not get elevon setting to work right been over and over videos and other sources for help with no luck im losing it smeone help/i.e anothr issue that i am also having is finding the correct settings for my redbull heli to fly right working with other models but cant seem to grasp this one
21 Apr 2016 05:49 - 21 Apr 2016 05:52 #46916 by Alexandro
Replied by Alexandro on topic elevon setting
Hello chaos1,
it is not to hard with your Wing.
1. Plug the Servos into the Channels Ele and Ail ( Elevator and Aileron )
2. Watch the moving Way of the Servos ( if they do Work at the contrary way , try to change Ele with Ail at the RX Connectors )
3. If they are moving wrong Way after thad ,then change the Menu to reverse ( left Buttons at Mix Menu )
-> Elevator has to move up and Aileron has to move the right way
4. Go into the Mix Menu and switch from Simple to Complex ( right side Buttons at Mix Menu )
5. Open the Aileron mix and switch the Pages to 2
6. Goto Page 2 and add: Src -> Elevator, MUX -> add ( always use add on the other Pages, only the 1st Page is replace )
-> if your Mixed Elevator is doing wrong Way , try to highlight the Src -> Ele Box and press Enter, this change the Stick input to reverse ( a ! comes up on the Name to show the reverse )
the same at Elevator, here use the Aileron on 2nd Page.
Then test the Trims if they working the right Way all is ok ( Trims are a bit tricky to get right )
greetings Alex
Last edit: 21 Apr 2016 05:52 by Alexandro.
21 Apr 2016 15:25 #46947 by czindrick
Replied by czindrick on topic elevon setting
I am in the same boat. I am working on setting up my FT Arrow.
I just have not sat down and worked on getting this configured. A simple two servo setup should be rather simple to get mixed.
My other main concern is a failsafe. When I turn off my tx the motor goes to 100%. I have tried to configure it and was not able to get it working.
If I figure something out I will be glad to share my findings. I am brand new to this, probably should have gone with a simpler TX but I enjoy the problem solving side of things. :cheer:
21 Apr 2016 17:34 #46954 by Alexandro
@czindrick
what system do you use ?
Spektrum, Flysky,Frsky,.......... ?
all have his one setting for Failsave
greetings Alex
21 Apr 2016 17:47 - 21 Apr 2016 17:50 #46956 by Fernandez
Replied by Fernandez on topic elevon setting
Here some different files I am using devo 7e with 2x3 switches added for flying wings.:
Model7, Skyfun jet with an orange RX dsm rx stabilizer, the stabilization gyro can be switched of with most right switch.
Model9, EPP Swift epp wing, Frsky
Model 10, EPP Hobbyking red eagle, Frsky
Dual rates for aileron and elevator (throw %) can be set with the 3 step switches.
The most left switch is set as throttle cut, or engine stop/disable..
Hope it helps you!
Last edit: 21 Apr 2016 17:50 by Fernandez.
21 Apr 2016 17:52 #46957 by czindrick
Devo 7e and a rx701.
7e has Deviation on it.
MY FT Arrow is just driving me insane trying to get this mixed...Left side is plugged in with the AIL and right side has the ELE..obviously these can be switched easily.
Left and Right was going up and down. Then I was able to move 1 up and 1 down.
Obviously I need to work on it more.
21 Apr 2016 21:19 - 21 Apr 2016 21:22 #46962 by Alexandro
You can reverse it with clicking on the Src box with Enter there comes a ! Up at the name of the Src Stick.
If this do not help , then go from 100 to -100 at Scale. This reverse the servo movement
The failsave:
Try to do a new bind with throttle at 0, most rx saves this.
If this do not work, then try to find a manual for this rx.
There are many ways to set it , it depends on the Rx Version
www.deviationtx.com/forum/3-feedback-que...afe-doesn-t-engauged
Last edit: 21 Apr 2016 21:22 by Alexandro.
Time to create page: 0.401 seconds
