Eachine E010 ini Devo 7E
25 Apr 2017 15:17 #61762 by Tally44xz@hotmail.com
Replied by Tally44xz@hotmail.com on topic Eachine E010 ini Devo 7E
I'm trying to bind an E010 to my devo 7e, I've installed the ini file posted here, and nothing. Do I have to install a module to do this? It looks like after deviation is installed the E010 should be supported, am I wrong about that? Devo ver 5.0
25 Apr 2017 15:25 #61764 by RNM75
Replied by RNM75 on topic Eachine E010 ini Devo 7E
You will need a NRF24L01 or 4-in-1 module to bind.
25 Apr 2017 15:33 #61767 by Tally44xz@hotmail.com
thank you, recommendations?
25 Apr 2017 16:54 #61769 by ltlethel
Replied by ltlethel on topic Eachine E010 ini Devo 7E
Works with the Devo 7e this the module for the protocol you need NRF24L01.
After you install it go into you model profile and pick the protocol I can't remember the name but then choose E010.
Scroll down the page and read some of the other post I'm at work and I can't look it up now. Search or click on my name 'ltlethel" and read my post these guys are good ppl they took care of my issue. I had the same problem at first this module is minimal soldering, four pins and on the link in the descriptions they have pictures. Good Luck!
m.banggood.com/CC2500-NRF24L01-A7105-CYR...dApp&android_share=1
25 Apr 2017 17:57 - 25 Apr 2017 17:58 #61771 by CesiumSalami
Replied by CesiumSalami on topic Eachine E010 ini Devo 7E
I think you may need one of the nightly builds for the E010 protocol - just and FYI.
Any nightly after maybe 2016/08/30
The protocol is MJXq - Select “E010” format option. If you don't see E010, you probably just need a more recently nightly.
The link above is for the 4-in-1 module, which i think is the best option. But it's expensive and the installation is a bit challenging (if you're using a Devo 7e. If you're using one of the larger Devo's it's supposed to be very easy).
The NRF module alone will get you in the air, but the 4-in-1, if installed properly - will give you access to all sorts of protocols and be a bit tidier.
Here's an NRF that works: www.banggood.com/DEVO-Transmitter-Tuner-...ys-V922-p-89812.html
Last edit: 25 Apr 2017 17:58 by CesiumSalami.
26 Apr 2017 03:46 - 06 May 2017 01:21 #61786 by Texacate
Replied by Texacate on topic Eachine E010 ini Devo 7E
Thank you. I was using the standard v5.0.0 release, and could not select the MJXq-E010 protocol format option... Good to know.
Edit: installed the 2017-04-21 nightly, and alias-hendrik's model.ini (from the 1st post in this thread), and everything worked beautifully! Thanks y'all.
Edit: Also work well this build: (v5.0.0 w/ updated protocols)
www.deviationtx.com/forum/builds/6407-de...cols?start=180#60667
BTW, loved the layout of the MainPageConfig in your model config, alias-hendrik. Very nice.
Last edit: 06 May 2017 01:21 by Texacate.
26 Apr 2017 13:09 #61797 by Tally44xz@hotmail.com
Thank you I appreciate the help!
26 Apr 2017 15:12 #61802 by Tally44xz@hotmail.com
Just curious, has anybody taken the module from the stock e010 transmitter and installed it into their devo 7e? Is it possible?
26 Apr 2017 15:35 #61803 by RNM75
I haven't opened up an e010 tx, but I'm guessing it's all integrated into a single board.
27 Apr 2017 01:23 - 27 Apr 2017 05:50 #61812 by Texacate
I'll tear mine apart when I get home. Now that my tx (7E) can talk to the quad (do flips, blink lights, etc), I have no use for the stock tx.
Edit: Yes, E010 tx is most definitely a single board. So no, one cannot re-purpose the RF section for a Devo tx.
Last edit: 27 Apr 2017 05:50 by Texacate.
27 Apr 2017 12:50 #61818 by Tally44xz@hotmail.com
Too bad that could have been fun
09 Nov 2017 09:40 - 24 Nov 2017 02:19 #65646 by Caerus
Replied by Caerus on topic Eachine E010 ini Devo 7E
Here's a very slightly modded version of the OP's E010 7E model.ini. His throttle curve is unusual and aggressive (likely tailored to his style and experience level), so I changed it to a simple linear 'curve'.
When I was a beginner it made the E010 MUCH easier to control. I was doing funnels and maneuvers I had no hope of doing with the original curve. Otherwise, all credit goes to Alias_Hendrik. I think it's one of the most well designed model files out there and I use it as the template for almost all my toy quads.
Last edit: 24 Nov 2017 02:19 by Caerus.
Time to create page: 0.697 seconds
