Help!! Devo7E V977 Pitch Jumping around Zero Pitch
17 Sep 2016 13:39 #53959 by TF824
Please take a look my video first.
As you can see, when I switch to 3D mode (Hold1), pitch started to jump around zero pitch.
Please check my model ini and let me know how to fix this issue.
18 Sep 2016 03:04 - 18 Sep 2016 03:09 #53988 by Thomas.Heiss
Replied by Thomas.Heiss on topic Help!! Devo7E V977 Pitch Jumping around Zero Pitch
I do not own the V977 or have experience with that model or KN protocol programming...
AIL scalar=50: Should that be DualRate?
Elev Subtrim -85: Subtrim on FBL?
IU1 on Hold switch? What??? F-Mode should be used for N, IU1/ST1/FM1 and hold for motor off.
I do not see any pitch curve e.g 5 or 9 pint curve.
Whole model ini seems somehow weird to me.
Would have to test later...
Well you would need either F-Mode or Mix for 3 axsis vs 6 axis switches as well as.
Try either the advanced mixer GUI NONE or FBL template of my heli summary developer thread and adjust for KN/V977: www.deviationtx.com/forum/6-general-disc...eased?start=60#53953
In the link list there is the Howo write FBL heli model file linked as well as.
Aren`t there any ready to use V977 model files on Wiki or model config forum
- with correct switch assignment (e.g safety hold)
- some DualRate/Expo mixers
- proper 5-9 point pitch curve mixers (both 0% mid point for N+IdleUp1)
Thomas
Last edit: 18 Sep 2016 03:09 by Thomas.Heiss.
18 Sep 2016 03:11 #53990 by TF824
It flies good except pitch jump at zero pitch area.
Idle up is FMOD1 of course.... Hold switch is for 3D/6G mode change....
I need help from someone actually have Devo7E + V977 combination.
Just for you know I have other V977 config works good but just want to fix this ini coz I like head speed and agility.
Thx.
18 Sep 2016 03:34 - 18 Sep 2016 03:42 #53993 by Thomas.Heiss
Then just copy over the section of 5-point pitch curves from the provided heli templates to your model.ini :-)
Well, noone needs the V977 heli as there are emus or transmitter / channel monitor :)
You would have to see the pitch jumping already on pitch channel (on monitor) when Fmode does not use same 0% values at mid point.
Last edit: 18 Sep 2016 03:42 by Thomas.Heiss.
18 Sep 2016 05:22 #53994 by TF824
Didn't work.
Anybody else?
18 Sep 2016 11:07 - 18 Sep 2016 11:08 #54006 by Thomas.Heiss
May I ask you what Deviation version number you are exactly on?
What 4.0.1-nightly-build?
5.0.0 release?
5.0-nightly-build?
Gerhard wrote about a similar "pitch jumping issue around mid stick" on version deviation-devo10-v5.0.0-b28961 (5.0 nightly-build).
German RCL forum explanation: www.rclineforum.de/forum/board35-helicop...seltsam/#post3972245
Last edit: 18 Sep 2016 11:08 by Thomas.Heiss.
18 Sep 2016 11:30 - 18 Sep 2016 11:59 #54008 by TF824
5.0.0 release.
I have no issue at all other 15 models. Only this model ini. jumps mid stick.
I have other ini for V977 which is great data so I really don't have to use this ini.
But I want to find the reason for curiosity and learning purpose.
Last edit: 18 Sep 2016 11:59 by TF824.
  • BirdBarber
  • BirdBarber's Avatar
  • Hummingbird Assassin
19 Sep 2016 03:56 - 19 Sep 2016 05:39 #54024 by BirdBarber
You have the 'Safety' on channel 8 (3D/6G) set to 'THR' it should be 'None'. What is happening is that as soon as you get to +1 throttle or above it is engaging the safety and switching your 3D/6G mode, which have different pitch curves. Safety is normally only used for throttle hold on the throttle channel.
Last edit: 19 Sep 2016 05:39 by BirdBarber.
19 Sep 2016 08:18 - 19 Sep 2016 10:20 #54027 by TF824
BirdBarber
That change (CH8 safety NONE) solved issue. :cheer:
No more pitch jumping at all.
Thanks a lot!!!
BTW I have absolutely no idea about Advanced GUI mixer, Can you please teach me more?
1, How to change head speed both 3D and 6G mode?
2, How to change gyro gain if I can?
3, How to change pitch range? (I know V977 can't set throttle and pitch curve separately but just want to change pitch range)
4, How to change pirouette speed (Rudder)?
5, How to change amount of cyclic range (Dual rate)
Attached is Model ini after changed CH8 safety to NONE
Thanks in advance.
Last edit: 19 Sep 2016 10:20 by TF824.
  • BirdBarber
20 Sep 2016 03:03 - 20 Sep 2016 03:25 #54048 by BirdBarber
One of the best ways to learn this transmitter is to load somebody else's working model file in your transmitter and then experiment with mixers settings and use the transmitter's 'channel monitor' function to see what the transmitter is outputting without having to fly the heli. You get to channel monitor by pressing ENT -> Transmitter Menu -> Channel monitor. Load 2 copies of the model file you want to play around with, one to experiment on and a second one you can use to restore over your modified one if you mess it up beyond repair.
The V977 is the hardest heli there is to program because the KN protocol is very screwy. You might want to learn on a more standard heli first (most any non WL Toys) because they are easier to program. Below is a link to a V977 model file that I created. The post documents the V977 channel layouts and the switch assignments that I set up. It has most of the functions you wanted in your previous post, but uses switches that you don't have. You will need to either only implement a couple of features at a time on your 7E switches or re-assign them to buttons or trim switches on the 7E. This would probably be good practice to learn your way around.
www.rcgroups.com/forums/showpost.php?p=35301156&postcount=6989
Note: gyro gain is not adjustable on this heli
Last edit: 20 Sep 2016 03:25 by BirdBarber.
20 Sep 2016 07:53 - 20 Sep 2016 09:11 #54054 by Thomas.Heiss
Howto set up a complex mixer or complex template: www.deviationtx.com/forum/how-to/2987-ho...-or-complex-template
Howto set up FBL helis:http://www.deviationtx.com/forum/how-to/1226-how-to-set-up-fbl-helis-on-custom-firmware
Mikes RC blog tutorials on Deviation: www.deviationtx.com/forum/how-to/3948-tu...el-config-file#28548
German Deviation intro: www.deviationtx.com/forum/how-to/2987-ho...-or-complex-template
Suggestion of heli standard GUI to advanced GUI mixer learning process: www.deviationtx.com/forum/6-general-disc...6308-i-gave-up#53142
Loading heli templates from templates directory: www.deviationtx.com/forum/7-development/...blem-spots-templates
I would say a model.ini setup for FBL with a good explanation may help you further instead of having to go thru “unknown templates“ on yourself.
For my given new 3rd 6ch_heli_FBL.ini (advanced GUI) FBL template: I copied it over from provided 6ch-heli.ini template and removed cyclics/virtual channels.
Its a start / draft. Has to be develped further. It may not have proper gyro gain channel setup.
Not sure about any proper FBL model.ini`s.
Last edit: 20 Sep 2016 09:11 by Thomas.Heiss.
22 Sep 2016 07:29 #54124 by TF824
BirdBarber
Thanks for your help again!
I finished adding 2x3 position Switches and checked function by the channel monitor.
It's working good.
Now I want to make V977 model.ini similar to your Devo8S V977 ini.
I'm trying to figure out which one can convert to added switch A0, A1, A2 and B0, B1, B2 from your Devo8S model ini.
If you can help, please let me know your suggestion.
Thanks.
22 Sep 2016 07:33 #54125 by TF824
Thomas.Heiss
Thanks a lot for all the info.
I will learn little by little.
  • BirdBarber
22 Sep 2016 11:54 - 22 Sep 2016 11:56 #54126 by BirdBarber
I see you have the input monitor displayed, that's good for checking your switches, and the separate channel monitor is used for checking what is output from the mixer to your heli, make sure you know how to use it as well.
To change a switch assignment in the mixer I will give an example for Rud D/R in my V977 8s model file listed above..
ENT button -> scroll to '1 Model Menu' and ENT -> scroll to '2 Mixer' and ENT -> scroll down to the right 'Expo&DR' box beside '4-Rud' and press ENT
The mixer for the Rudder dual rates is now displayed, it goes way beyond the bottom of the display.
Scroll down using DN until 'Switch1 / ELE DR1' is highlighted and then just toggle the switch on the transmitter you would like to use instead of the ELE DR1 switch. The new switch name should display. You can also select a switch by scrolling thru the list using the R and L buttons. Now just scroll up using the 'UP' button until the 'Save' box is highlighted and press ENT. Thats it, just press EXT multiple times to exit all the way out.
The most common problem when using the mixer is forgetting to 'Save' your changes.
Last edit: 22 Sep 2016 11:56 by BirdBarber.
Time to create page: 0.214 seconds
