Horizon Hobby X-Vert VTOL
- bugman72
14 Jul 2017 02:33 #63430
by bugman72
Horizon Hobby X-Vert VTOL was created by bugman72
I posted this a few days ago in the Model Request section, but was hoping to try and get some insight on setting this up. I am having a great deal of issue in getting this craft setup properly in my Devo 7E (older 4.0.1 Nightly, two 3-way switches). I initially tried to go through the tutorial that MWM has on his blog page. Had little luck.
This craft requires one 3-position switch and one momentary switch. Flight modes are controlled by Channel 5 and motor arming/disarming is controlled by Channel 6.
I had Switch B set up for the 3 flight modes and that all works properly. I can see the LED on the flight control board turn from green (multirotor mode) to red (stability mode) to red/green (acro mode). I had throttle cut set for HOLD switch, but was unable to figure out what I needed to do for the motor arm/disarm momentary switch. I have also been having issues with getting only part of the control to work properly.
At this point, I'm lost and about ready to either take the craft back or see if I can buy a cheap DX6 so I can fly this thing.
Does anyone own one of these and can give me some assistance in getting a proper model INI set up? It's frustrating that my brand new craft is just sitting in the box because I can't figure out how to program my radio.
- Moeder
14 Jul 2017 09:48 #63436
by Moeder
Replied by Moeder on topic Horizon Hobby X-Vert VTOL
From reading the X-Vert manual it should be a pretty simple setup:
1.) I advise you not to use the older 4.0.1 build as it probably yet has some DSM2/X issues. Go with a current nightly (it is stable to my knowledge).
2.) Program the model (DSMX, 6 channel):
Channel1: Mixer simple THR 1-to-1, Safety HOLD1, Safe Val -100
Channel2: Mixer simple AIL 1-to-1
Channel3: Mixer simple ELE 1-to-1
Channel4: Mixer simple RUD 1-to-1
Channel5: SWB like you did, as it seems to work (flight modes).
Channel6: Mixer simple FMODE1 1-to-1
You can add Expo&DR to channels 2-3 later on when everything is working.
To arm the X-Vert you need to have your throttle stick at minimum and then flick FMODE down and up again to arm (it should start spinning motors at idle speed if you are in Multirotor mode).
- Ariete
19 Jul 2017 15:26 #63521
by Ariete
Replied by Ariete on topic Horizon Hobby X-Vert VTOL
I had the same problem with my Devo 8S.
I had started from a model that I use for all SAFE receivers and the X-Vert changed modes. I even got it to arm but when I tried to take off the X-Vert jumped a meter o so and suddenly stopped falling down.
At the end all I had to do was reverse channel 6 (the one that arms).
I attach the file for X-VERT with Devo 8s.
FMOD switch changes between all the flying modes:
0-Multirotor (Green led)
1-Stable (Red led)
2 acro (Green and red leds)
Switch GEAR to 1 for a second or so and take it back to 0: the motors ARM
DANGER the motors spin even at 0 throttle
it is supposed to do that.
Once armed when you give throttle, at 50% aprox. the X-Vert gets in the air and you can control it like a multirotor. Know that the cockpit is the back and the belly is the front.
Rudd D/R to 1 is motor hold but only works when the throttle is at zero. Maybe someone can figure why.
1-Stable (Red led)
- Ariete
02 Aug 2017 11:15 #63682
by Ariete
Replied by Ariete on topic Horizon Hobby X-Vert VTOL (Throttle cut help)
Hello, I have a problem with throttle cut.
I changed the throttle channel:
.And RUD DR1 cuts the throttle but not entirely.
When the motors are armed the X-Vert starts with an "idle" throttle and that is what remains when I cut throttle.
I have tried to make RUD DR1 replace GEAR 1 which is the switch that arms and disarms but I don't think I am doing it OK.
This arms and disarmsThis was intended to disarmWhat am I doing wrong?
[channel1]
safetysw=RUD DR1
failsafe=-125
safetyval=-150
template=simple
[mixer]
src=THR
dest=Ch1When the motors are armed the X-Vert starts with an "idle" throttle and that is what remains when I cut throttle.
[channel6]
reverse=1
template=simple
[mixer]
src=GEAR1
dest=Ch6
curvetype=min/max
points=0
[virtchan1]
name=Virt1
template=complex
[mixer]
src=GEAR1
dest=Virt1
switch=RUD DR1
usetrim=0
curvetype=min/max
points=0- dobosatti
30 Apr 2018 19:30 #68938
by dobosatti
Replied by dobosatti on topic Horizon Hobby X-Vert VTOL
What does X-vert do when you do not get a Tx signal?
Fall down? Fly away? Will you land as a multicopter?
- eraf
15 May 2018 17:00 #69244
by eraf
Replied by eraf on topic Horizon Hobby X-Vert VTOL
Hello, here is my setup to
Horizon X-Vert Vtol on Devo 12:
Hold 1= Motor cut off, Hold 0= Motor cut on, Countdown Timer and Stop Timer on,
TRN 1 switch Motor on ,
F-Mode 0= Multirotor Mode
F-Mode1= Stabillity Mode, Forward Flight
F-Mode2= Acro Mode, Forward Flight
Channel 1-4: +- 100% Expo: 0%
- Frankie500
26 Jun 2018 00:56 #69717
by Frankie500
Replied by Frankie500 on topic Horizon Hobby X-Vert VTOL
Hi, I'm new to this site. I was looking for an INI file for the x-vert that will work with the DEVO 10.
I tried some of the suggestions that have been discribed, but not working.
thanks in advance
thanks in advance
- alfvv12
25 Feb 2020 22:13 #75968
by alfvv12
Replied by alfvv12 on topic Horizon Hobby X-Vert VTOL
@frankie500
i have the same problem with devo10
gr.
gr.
Time to create page: 1.473 seconds
Model Configs
- Horizon Hobby X-Vert VTOL
