Hubsan H122D Devo 10 Model ini
30 Aug 2018 17:59 #70559 by GermanDroneGuy
Replied by GermanDroneGuy on topic Hubsan H122D Devo 10 Model ini
Hi!
I just flashed this to my Jumper V2+ and gave it another shot.
I don't have the problem here and I suspect that maybe my Model-Ini got corrupted. I tried a deleted the model ini on the old jumper and created a new one - the problem was not there. So all I can say is:
Flip: Works
On the H122D Normal / Sport / Acro: Works
OSD on the other hand does not. I forgot that there is some kind of binding procedure involved.
If you use the H501S TX for the H122D telemetry (Pitch / Roll / Battery etc.) is sent to the H501S TX too. If you're using a second monitor, you only see the Video and Photo icons on it.
I think it's the same with the Jumper. And since telemetry works there, there is no need for the OSD anymore.
As stated before: You guys are awesome!
30 Aug 2018 20:56 #70561 by goebish
Replied by goebish on topic Hubsan H122D Devo 10 Model ini
Ok, OSD is generated in the Tx, not by the quad, and the osd flag that's sent is probably useless, I'll remove it and move flip to channel 13 then.
30 Aug 2018 21:10 #70563 by goebish
I've just created a pull request, it should be available in the nightly builds soon.
Flip has been moved to channel 13 (H122D), OSD has been removed.
github.com/DeviationTX/deviation/pull/420
30 Aug 2018 21:40 - 30 Aug 2018 21:42 #70564 by planger
Replied by planger on topic Hubsan H122D Devo 10 Model ini
I'll remove OSD as well then...
Last edit: 30 Aug 2018 21:42 by planger.
03 Sep 2018 09:30 #70623 by fynn00
Replied by fynn00 on topic Hubsan H122D Devo 10 Model ini
Hi GermanDroneGuy,
in my setup CH12 does not change flight modes (using Jumper T8SG V2 Plus and Hubsan H122D).
Can you please share your model.ini?
Thanks a lot
Flow
Time to create page: 0.411 seconds
