WL Toys V950 - Devo10
16 Dec 2016 08:22 - 16 Dec 2016 10:52 #56878 by Gerhard
WL Toys V950 - Devo10 was created by Gerhard
Hi guys is it possible to build a WL Toys V950 helicopter model for Devo 10. I am not sure what protocol this model uses. (KN?)
Regards
Gerhard
Last edit: 16 Dec 2016 10:52 by Gerhard.
16 Dec 2016 12:28 #56882 by Babay
Replied by Babay on topic WL Toys V950 - Devo10
WLToys V950 use KN-protocol and same configuration as V977. I just copy config from V977, bind and test fly in the room.
17 Dec 2016 06:49 #56908 by Gerhard
Replied by Gerhard on topic WL Toys V950 - Devo10
Hi Babay,
Thank you for your response. I tried exactly what you suggested (using the V977 as a template) but I cannot get the V950 to bind with my Devo 10. The V977 has no problem binding with the Devo 10.
What is the procedure that I need to follow to get the V950 and Devo 10 to bind?
Regards,
Gerhard
18 Dec 2016 08:21 #56936 by Babay
On the heli press and hold bind button about 5 seconds. Red LED will blinking. On the transmitter press ENT, select Model Menu - Model Setup - Bind.
18 Dec 2016 10:22 #56939 by Gerhard
Thank you Babay it worked. Now I can start testing, crashing and rebuilding!
Regards,
Gerhard
04 Mar 2017 11:55 #59834 by KingHoover
Replied by KingHoover on topic WL Toys V950 - Devo10
Hi Gerhard,
i have also an V950 and a Devo 10 and searching for a Model config file.
find a few v977 files and i am pleased to know wich one you are using? can you tell me a download source or maybe share your file?
Best Regards
Nuno
04 Mar 2017 12:54 #59835 by Gerhard
Hi Nonu,
I tried two of the V977 config files and both bombed out. I realized that it is cheaper using the Wl Toys remote supplied with the V950. The repair cost that I had incured was jut not worth the effort for me.
Regards
Gerhard
Time to create page: 0.485 seconds
