Furibee F36 Needs Deviation
- RakelJamz
18 Dec 2016 15:32 #56946
by RakelJamz
Furibee F36 Needs Deviation was created by RakelJamz
Anyone out there thinking of deviating the newish Furibee F36? Could be an excellent Tiny Whoop with Deviation.
- Cereal_Killer
18 Dec 2016 16:56 #56954
by Cereal_Killer
Replied by Cereal_Killer on topic Furibee F36 Needs Deviation
Have you confirmed it doesnt work with the E010 protocol?
- RakelJamz
19 Dec 2016 00:09 #56963
by RakelJamz
Replied by RakelJamz on topic Furibee F36 Needs Deviation
I have tried binding with the 010 protocol, using multiple combinations of transmitter output power, number of channels, and I.D.s. No luck as of yet. Many have also said the same on the rcgroups forums.
- jboehm
10 Jan 2017 18:11 #57796
by jboehm
Replied by jboehm on topic Furibee F36 Needs Deviation
Mine arrived this past weekend. Looking forward to its Deviation.
- MiSKLaCH
11 Jan 2017 13:35 #57813
by MiSKLaCH
Mine will arrive shortly... this chinywhoop seems a good deal, we all hope it will be deviated sooner or later!
Replied by MiSKLaCH on topic Furibee F36 Needs Deviation
jboehm wrote: Mine arrived this past weekend. Looking forward to its Deviation.
- RakelJamz
11 Jan 2017 13:45 #57814
by RakelJamz
I decided to jump the gun. I took my Eachine 010 brain and simply swapped it with the f36 brain. Lighter frame, more punchy motors, deviated protocol. Flies quite nicely!
- HappyHarry
11 Jan 2017 15:03 #57817
by HappyHarry
Replied by HappyHarry on topic Furibee F36 Needs Deviation
why doesn't one of you make some captures and help get it into deviation? seby has a great howto video showing the process if you don't know how
- MiSKLaCH
11 Jan 2017 15:10 #57820
by MiSKLaCH
I would if only I had a logic analyzer...
- RakelJamz
11 Jan 2017 16:54 #57831
by RakelJamz
Same here
- HappyHarry
11 Jan 2017 17:57 #57832
by HappyHarry
buy one, £5/$6 with free shipping >>
www.ebay.co.uk/itm/271716215743
- shahidali55
22 Jan 2017 08:18 #58296
by shahidali55
Replied by shahidali55 on topic Furibee F36 Needs Deviation
I've got a Devo 7e with 4in1 and a new F36. I've also got a logic analyzer. But there is no seperate radio chip on the F36 receiver board. The TX also uses a single chip for everything, so no sniffing on the SPI bus. Anything else I can try to help contribute to the efforts ?
- HappyHarry
24 Jan 2017 07:00 #58338
by HappyHarry
that's not good news, the only option now afaik is to use an sdr setup and pull the data from the air. that's a much more expensive setup and again afaik a more involved procedure
- shahidali55
25 Jan 2017 18:31 #58382
by shahidali55
Tossed out the F36 fc and replaced it with a E010 fc. Works brilliantly well. At some point in time I was actually thinking of buying a HackRF One. Not worth the time and money.
- shahidali55
27 Jan 2017 09:18 - 27 Jan 2017 09:21 #58427
by shahidali55
Could this be the chip used in the TX and RX ? It is available in SSOP16 and SSOP24 packages.
m.1688.com/offer/538862337474.html?spm=0.0.0.0.KBgf2c
Last edit: 27 Jan 2017 09:21 by shahidali55.
- shahidali55
28 Jan 2017 07:26 #58461
by shahidali55
E010:
Channels 33 - 38, 3a - 3f, 43 - 48, 4a - 4f
5 + 5 + 5 + 5 = Total 20 Channels
F36:
Channels 3a - 3f, 41 - 52
5 + 17 = Total 22 Channels
(Attached scanner data produced by example @ maniacbug.github.io/RF24/scanner_8pde-example.html )
F36:
- shahidali55
28 Jan 2017 08:54 - 28 Jan 2017 09:31 #58463
by shahidali55
Last edit: 28 Jan 2017 09:31 by shahidali55.
- kabo
08 Apr 2017 03:26 #61257
by kabo
Replied by kabo on topic Furibee F36 Needs Deviation
If u watch the video we seen to attack the controller, ie transmitter to grab data, not the quad, or did I see the video wrong?
Time to create page: 1.068 seconds
Model Configs
Model Requests
- Furibee F36 Needs Deviation
