Simple Elevons mix with dual rate please!!
- Donthemon
24 Mar 2020 09:42 #76097
by Donthemon
Replied by Donthemon on topic Simple Elevons mix with dual rate please!!
Hi - knowing Deviation, there must be a way of doing this but I've never found it! I'd also be very interested as after getting the crackingly good elevon mix (see above), I now have it on 5 models.
- danskis
24 Mar 2020 14:03 #76099
by danskis
Replied by danskis on topic Simple Elevons mix with dual rate please!!
Thanks Gerry - I guess I fat fingered it and turned off trim on one of the pages.
Next I want to try and load your ini file for a virtual channel but my setup is fairly different.
Once I load the file and set up a new model I assume that I can use the transmitter menu to change receiver protocols. Or, is my only option to do it in the ini before its loaded.
- Gerry
- Bbrad
25 Mar 2020 04:44 #76102
by Gerry
FFS (Forever Fixing Stuff)
Replied by Gerry on topic Simple Elevons mix with dual rate please!!
Loading and then changing the protocol should work, but the channel order (aetr vs taer) could change as well which could cause problems like tx warning of throttle not at zero.
Try it, if it works good, if not post your ini and describe what you want to achieve I'll see if I can fix it.
Time to create page: 0.188 seconds
Model Templates
- Simple Elevons mix with dual rate please!!
