throttle setup
- walter56
11 Jan 2023 18:15 #78168
by walter56
throttle setup was created by walter56
I am a biginner and I would like a template about ESC motor control.
I try to setup it, but my CH3 stick works only from the center to the full throttle
From the down position to the center of the stick the montor don't run.
many thank in advance
- -=Hubi-Dirk=-
12 Jan 2023 12:33 #78169
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic throttle setup
what can you see when you look up "Transmitter menu" / "Channel Monitor"? Is the value of CH3 rising from -100% to +100% when you move the Throttle Stick?
What is your TX Type?
Greeting
Dirk
Greeting
Dirk
- walter56
12 Jan 2023 17:03 #78170
by walter56
Replied by walter56 on topic throttle setup
Hi ,
i confirm that channel monitor CH3 is - 100% to +100%.
My TX type is V3
Channel configuration CH3
safe val = 0
min limit = -150
max limit = 150
scale - = 100
scale + = 100
subtrim = 0.0
speed = 0
Simple MIX type
curve = 1 a 1
scale = 100
offset = 0
thanks
Walter
My TX type is V3
safe val = 0
min limit = -150
max limit = 150
scale - = 100
scale + = 100
subtrim = 0.0
speed = 0
Simple MIX type
curve = 1 a 1
scale = 100
offset = 0
thanks
Walter
12 Jan 2023 20:56 #78171
Replied by hexfet on topic throttle setup
What heli are you flying?
What's the receiver and flight controller setup?
If it's a collective pitch heli with throttle on channel 3 you most likely have a "smart" flight controller with its own ideas about throttle curves.
Could also be the same with a fixed pitch or maybe just ESC endpoints.
- walter56
13 Jan 2023 11:23 #78173
by walter56
My model is a simple airplane with a brusheless motor and ESC
- -=Hubi-Dirk=-
13 Jan 2023 11:34 - 13 Jan 2023 11:35 #78174
by -=Hubi-Dirk=-
Maybe it would be good to test the output of the receiver first, if it is delivered the whole way. You could simply connect a servo there.
If on the channel 3 the servo works properly, then I would try to reprogram the ESC with the entire throttle travel.
BTW: The ESC is not from the RC-Car or Ship?
Last edit: 13 Jan 2023 11:35 by -=Hubi-Dirk=-.
- walter56
14 Jan 2023 18:39 #78177
by walter56
I try to put a servo on CH3 and it works properly.
My ESC is a new one.
- -=Hubi-Dirk=-
14 Jan 2023 19:29 #78178
by -=Hubi-Dirk=-
Walter if you need further help, then you should also give us some more information.
Now that it is clear that it is neither the TX, and its programming for CH3, nor the RX that is the problem and we can also rule out a problem with deviation.
So it would be good to know which ESC you are using, regardless of whether it is new. It would be best to tell us the name of the manufacturer and the type of ESC.
- walter56
15 Jan 2023 10:45 #78180
by walter56
My ESC is a FullPower PRO 6A BEC.
But my doubt is: if the regulation curve is negative with the stick in the down position, how can the ESC/motor run ?
The motor will run starting only with the stick in the central position, increasing to full speed with the stick in the uper position.
In my opinion the current recgulation curve is only suitable for endothermic engines.
Walter
Walter
- -=Hubi-Dirk=-
15 Jan 2023 11:17 #78181
by -=Hubi-Dirk=-
Hi Walter,
You are starting from the wrong premises. The ESC does not get a negative control value from the TX.
The ESC gets a pulse width modulated signal (PWM) between 1000ms - 2000ms from the RX, the center position corresponds to 1500ms. From this the ESC generates a rotating field for the connected brushless motor.
Exactly with this PWM the servo on the RX on Throttle CH 3 works perfectly.
Would you like to send us a link with a manual of the ESC, then we could see how the throttle travel must be taught into the ESC. Under the name of the ESC "FullPower PRO 6A BEC" I find different variants of an ESC. Which one is it exactly?
Greetings
Dirk
Greetings
Dirk
- -=Hubi-Dirk=-
15 Jan 2023 13:07 #78182
by -=Hubi-Dirk=-
The YT video describes a similar problem as you have and shows the calibration of an ESC.
- walter56
17 Jan 2023 10:42 #78185
by walter56
Hi Dirk,
I have solved my pronblem with your help.
The error was the ESC calibration.
Many tanks
Walter
Many tanks
Walter
- -=Hubi-Dirk=-
17 Jan 2023 11:25 #78186
by -=Hubi-Dirk=-
You're welcome!
- walter56
17 Jan 2023 13:49 #78187
by walter56
Dear Dirk,
I found another problem, Can you help me ?
If I turn off the transmitter the motor continues to run.
Thanks in advance.
Walter
Thanks in advance.
Walter
- -=Hubi-Dirk=-
18 Jan 2023 15:33 #78192
by -=Hubi-Dirk=-
Hi Walter,
Fail Safe is the name of the function that should ensure that Throttle is switched off when no receive signal arrives. You can find a short information in the documentation here under 8.8.11
deviationtx.com/user-manual/user-manual-6-8-12
In the mixer: Have a look in the settings of the throttle channel. There you will find the item Fail Safe depending on the RX and the protocol.
- walter56
19 Jan 2023 18:10 #78193
by walter56
Hi Dirk,
With your help I solved the fail safe problem.
You are always very kind.
Many thanks
Walter
Many thanks
Walter
- -=Hubi-Dirk=-
20 Jan 2023 06:24 #78195
by -=Hubi-Dirk=-
Hi Walter,
I'm glad to hear that the fail safe is now working.
Dirk
Dirk
Time to create page: 0.299 seconds
Model Templates
- throttle setup
