DSM Telemetry support
- linux-user
05 Mar 2015 14:58 - 05 Mar 2015 15:12 #29354
by linux-user
Replied by linux-user on topic DSM Telemetry support
Sorry,
devo10-v4.0.1-8d9113c isn't the solution.
Telemetry monitor shows strange values:
either:
Temp1=Temp2=Temp3=Temp4=29C
Volt1=Volt2=Volt3=4.8V (1s Lipo)
RPM1=RPM2=5760
or even:
some other values:
should I write down them?
... and some more bugs:
- Channel-Monitor is messed up
(Ch1 Ch2 are missing, but it shows Virt1, Virt2 Virt3)
- there is am menu for "3. USB" - but not working
either:
RPM1=RPM2=5760
or even:
some other values:
Last edit: 05 Mar 2015 15:12 by linux-user. Reason: more Bugs
- Indigo
05 Mar 2015 15:48 - 05 Mar 2015 16:03 #29355
by Indigo
Replied by Indigo on topic DSM Telemetry support
Oops sorry. Ok, it's now fixed. Also zero values for Volts and RPM are shown in error colour.
I just tried USB mode and it is working. You might need the file system for latest nightly, so I have uploaded the 3 file system (fs) zips as separate downloads.
RE: Channel Monitor
Would it make sense if title "Channel output" was changed to "Mixer output".
RE: Channel Monitor
Last edit: 05 Mar 2015 16:03 by Indigo.
05 Mar 2015 16:16 #29356
I still think that would make sense
Replied by mwm on topic DSM Telemetry support
Indigo wrote: Would it make sense if title "Channel output" was changed to "Mixer output".
- linux-user
05 Mar 2015 16:29 - 05 Mar 2015 16:36 #29357
by linux-user
Yes, that is true, but none of the values displayed are valid.
I don't think it is necessary to change the name. "Virtual channels" are also sort of channels.
Channel Monitor:
does not work with small fonts. (/media/config.ini)
USB:
is working, sorry might have been my fault.
Telemetry monitor:
no valid values as described above. (MiniCP only supports Temp1 and Volt2)
Indigo wrote: Oops sorry. Ok, it's now fixed. Also zero values for Volts and RPM are shown in error colour.
Indigo wrote: RE: Channel Monitor
Channel Monitor:
USB:
Telemetry monitor:
Last edit: 05 Mar 2015 16:36 by linux-user.
- Indigo
05 Mar 2015 17:02 #29358
by Indigo
Ok, that could only be one thing. New version will be uploaded within 5 mins.
- linux-user
05 Mar 2015 17:44 - 05 Mar 2015 17:47 #29364
by linux-user
Sorry,
Telemetry Monitor:
now all "0" in "error color" (=inverted), no matter if RX is bound or not.
Channel Monitor:
still does not like small fonts
Telemetry Monitor:
Channel Monitor:
Last edit: 05 Mar 2015 17:47 by linux-user.
- Indigo
06 Mar 2015 08:03 #29390
by Indigo
Ok, new version addressing those 2 issues
Telemetry Monitor - unable to test myself but should be fixed
Channel Monitor - fixed *
* Old bug, previously 2nd page "Stick Inputs" with small fonts would crash, but since my update to scrollable both pages would crash. It took some time to find the cause and just as long to fix.
Datalog not working - I'll look into it.
- linux-user
06 Mar 2015 09:03 - 06 Mar 2015 09:43 #29393
by linux-user
Hi, Indigo
deviation-devo10-v4.0.1-de99565
Channel Monitor - fixed - confirmed
Telemetry Monitor:
still showing all 0, no matter if model bound or not. (inverted)
To clarify: This is not only the "Telemetry monitor" but TX doesn't display any telemetry-values in text-box as well.
Edit:
I left the previous version (deviation-devo10-v4.0.1-8d9113c.dfu) powered on over night, and got locked out. (RX not binding automatically)
- switched telemetry off => RX is binding.
- switched telemetry on => RX binds again.
This was done without power-cycling anything.
Indigo wrote: Telemetry Monitor - unable to test myself but should be fixed
Hi, Indigo
Telemetry Monitor:
Edit:
Last edit: 06 Mar 2015 09:43 by linux-user. Reason: clarification
- Indigo
06 Mar 2015 11:52 #29394
by Indigo
Ok, Telemetry Monitor wasn't updating the display, it should now work.
Thanks for testing this.
- linux-user
06 Mar 2015 12:14 #29395
by linux-user
telemetry still only shows "0"
deviation-devo10-v4.0.1-c05d8ac (I only updated the dfu)
- Indigo
06 Mar 2015 12:46 #29396
by Indigo
Ok, it should work now.
- linux-user
06 Mar 2015 13:07 #29398
by linux-user
deviation-devo10-v4.0.1-4dc1002 still displays only 0
- Indigo
06 Mar 2015 13:35 - 06 Mar 2015 13:48 #29399
by Indigo
Sorry.
If this doesn't work, I'll have it update all display values to make sure it's actually reading data ok.
Edit: I've added 2 more just for you.
* display non-zero
* display all values
* display non-zero
Last edit: 06 Mar 2015 13:48 by Indigo.
- linux-user
06 Mar 2015 14:04 #29401
by linux-user
Sorry still all "0"s
What I am not understandig: this has been working before your merge with the nightly. Is there something fundamental different now?
At this point I am thinking, if I am doing something wrong.
- linux-user
06 Mar 2015 14:17 - 06 Mar 2015 14:41 #29402
by linux-user
neither is working for me.
I am thinking of going back to the last one that was working to crosscheck if I am doing something wrong.
Edit:
to crosscheck I flashed the nightly "deviation-devo10-v4.0.1-a4e6135.dfu"
Only the dfu; file system unchanged.
- telemetry is working as expected
Indigo wrote: Edit: I've added 2 more just for you.
* display non-zero
Edit:
Last edit: 06 Mar 2015 14:41 by linux-user.
- Indigo
06 Mar 2015 14:55 #29403
by Indigo
It could be the merge with the nightly, but unlikely.
I've uploaded some more.
Try -disp_all_values_v2 first because if that doesn't work the other 2 won't work either.
- linux-user
06 Mar 2015 15:03 - 06 Mar 2015 15:22 #29404
by linux-user
disp_all_values_v2 isn't working either.
When trouble-shooting it is always the same question:
What was the last change before the error occured?
If I remember correct:
after the merge it did display some values, but totally invalid ones.
Then while trying to eliminate the invalid values we ended up that no values at all are displayed. #29357 and #29354
Last edit: 06 Mar 2015 15:22 by linux-user.
- Indigo
06 Mar 2015 15:43 #29406
by Indigo
I've gone back to before merge.
Try all_values_v3 first. If working try non_zero_v3 next.
- linux-user
06 Mar 2015 16:09 #29408
by linux-user
all_values_v3 didn't work
- Indigo
06 Mar 2015 18:15 #29410
by Indigo
In that case it could only be one thing,
Try this one
Try this one
Time to create page: 0.424 seconds
- DSM Telemetry support
