Alarme Devo when not used
- heliaddict
20 May 2013 21:05 #10173
by heliaddict
Replied by heliaddict on topic Alarme Devo when not used
Have tested on my Devo 8s as well and works fine so perhaps there is a bug on Devo 7e? Be nice if it could be louder but I guess would need a better speaker/buzzer? Should be better on the Devo 7e with the vibration as well.. This is a great feature for deviation! Thank you!
- domcars0
20 May 2013 21:09 - 20 May 2013 22:07 #10174
by domcars0
Replied by domcars0 on topic Alarme Devo when not used
Did you made the Devo7e 4 switches mod ? Because I just test again my new Devo7e .. and it seems that since I made the 4 switches mod, powerOn alarm does not work anymore ?... I have to confirm it ...
[EDIT]: Nothing to do with the switches mod, I had probably tested it on the emu_devo7enot on my real Devo7e.. sorry.
Last edit: 20 May 2013 22:07 by domcars0.
- heliaddict
20 May 2013 21:24 #10175
by heliaddict
No haven't done any switch mods. Using latest nightly build deviation-devo7e-v3.0.0-285a82
- domcars0
20 May 2013 22:03 - 20 May 2013 22:04 #10176
by domcars0
OK bug found.. I have create a new bug report on PB repo...Hope you will have
the corrected nightly build soon.
Last edit: 20 May 2013 22:04 by domcars0.
- heliaddict
20 May 2013 22:16 #10177
by heliaddict
Great thank you!
- heliaddict
25 May 2013 13:30 #10292
by heliaddict
Replied by heliaddict on topic Alarm Devo when not used
Have just tried new nightly build deviation-devo7e-v3.0.0-fd346b but alarm still not working for me on Devo7E.
- domcars0
25 May 2013 15:23 - 25 May 2013 15:28 #10295
by domcars0
Strange ? It works for me now (but I'm using my own release cause I've the 2 switches patch) .. Could you please try the following. You will see 2 new toggle switches in the config pages, just never select them if you don't have it.
This is just the dfu file and the protocols dir, the filesystem is the same as yours.
Last edit: 25 May 2013 15:28 by domcars0.
- heliaddict
26 May 2013 10:04 #10316
by heliaddict
Just tried your file and it works well thank you, guess there is still a bug in the nightly build?
- domcars0
26 May 2013 18:58 - 26 May 2013 18:59 #10327
by domcars0
I've just looked diff between my repo and the PB one and there is nothing which can make a difference for this feature ? I do not understand? Could you reinstall the nightly build please to be sure that it does not work?
Last edit: 26 May 2013 18:59 by domcars0.
- heliaddict
27 May 2013 22:10 #10350
by heliaddict
I reinstalled nightly build and found it's working! Not sure what I did wrong here but all seems good now thanks!
- domcars0
28 May 2013 06:09 #10353
by domcars0
Nice to hear and happy that it works! Thanks.
Time to create page: 1.292 seconds
- Alarme Devo when not used
