JD 395 cx-10
- goebish
- NRF Weirdo
08 Oct 2015 10:07 - 08 Oct 2015 10:08 #38569
by goebish
Replied by goebish on topic JD 395 cx-10
DM007 already has video (ch 8 ), snapshot (ch 7) and headless (ch 9) features implemented, have you tried them ?
Last edit: 08 Oct 2015 10:08 by goebish.
- IKKI
08 Oct 2015 10:14 - 08 Oct 2015 21:47 #38570
by IKKI
Replied by IKKI on topic JD 395 cx-10
Yes, i have try it, but work only with Mould King. I haven't camera on it, but headless mode is turn on with channel 9!
Juncheng don't work.
Last edit: 08 Oct 2015 21:47 by IKKI.
- goebish
- NRF Weirdo
08 Oct 2015 10:40 - 08 Oct 2015 10:43 #38571
by goebish
Ok, so we've nothing to do for Mould King, it's just a DM007 clone and it's using the same protocol.
Here's a test firmware for Juancheng, select Green protocol, then there are 2 extra options in protocol options, P13 and P14, ranging from 0 to 7.
Try each values, check if it activates a feature, then report
www.dropbox.com/s/q4o3lpwi750uuv2/deviat...0.1-2cde795.zip?dl=0
Last edit: 08 Oct 2015 10:43 by goebish.
- IKKI
- vasiliy_gr
08 Oct 2015 11:40 #38575
by vasiliy_gr
I will try this build with manual bit-test in few hours on 33041.
Replied by vasiliy_gr on topic JD 395 cx-10
Can't completely agree. Both camera controls are unresolved. Headless is not working on ch9 (of DM007 protocol) here is useless RTH, not headless. And if we will find camera and headless - there will be a good idea to reverse AIL/ELE also.goebish wrote: Ok, so we've nothing to do for Mould King, it's just a DM007 clone and it's using the same protocol.
- goebish
- NRF Weirdo
08 Oct 2015 11:45 #38576
by goebish
Ok, waiting for your report then
- IKKI
08 Oct 2015 12:04 #38577
by IKKI
EUREKA!!!!
Juncheng 3015-1 -Juncheng 3015-2
P14/3 activate shot camera - activate led
P14/4 activate recording - double flip
Thank you!
Now how do I associate the signal to one of swich 3x2? : D
Thank you!
- goebish
- NRF Weirdo
08 Oct 2015 12:06 #38578
by goebish
Nice, now I've to assign that to channels, I'll wait for vasiliy_gr report first.
Did you have to reverse some channels ? (AIL / ELE / RUD ?)
- IKKI
08 Oct 2015 12:14 #38579
by IKKI
Yes CX 10 GREEN board, Ail inverted.
Cool! And remember with the two stick down and external I actives the headless... But I can do it it it's flying... Can you understand and help me? After this model are better than original, because increase pitch and jaw!
- goebish
- NRF Weirdo
08 Oct 2015 12:16 - 08 Oct 2015 12:16 #38580
by goebish
I think this is a RX side feature, it can't be implemented in the protocol, just use the sticks as on the stock radio.
Last edit: 08 Oct 2015 12:16 by goebish.
- IKKI
08 Oct 2015 12:19 #38581
by IKKI
There is no way through the mixer to associate this function to the key DN- so that a fast pressure gives the same combination of signal?
- goebish
- NRF Weirdo
08 Oct 2015 13:15 - 08 Oct 2015 13:16 #38584
by goebish
I'll see if I can implement it in the protocol...
How much time do the sticks need to be in this position to enable headfree ? And what's the sticks combination to disable it ?
Last edit: 08 Oct 2015 13:16 by goebish.
- IKKI
08 Oct 2015 13:18 - 08 Oct 2015 13:21 #38585
by IKKI
Credo meno di un secondo, probabilmente mezzo.
Per accedere e disattivare sempre uguale. All'interno è per la calibrazione.
Sorry my mistake!
I think less than a second, probably the middle. To access and disable the same. Inside it is for calibration.
Sorry my mistake!
Last edit: 08 Oct 2015 13:21 by IKKI.
- goebish
- NRF Weirdo
08 Oct 2015 13:19 #38586
by goebish
Sorry, I can't read Italian
- goebish
- NRF Weirdo
08 Oct 2015 13:25 #38587
by goebish
Ok, so it seems complicated to implement it reliably, better use the stick commands.
- vasiliy_gr
08 Oct 2015 13:35 #38588
by vasiliy_gr
Replied by vasiliy_gr on topic 33041 flags bits
Ok, here is my report on 33041. Everything seems to be straight forward.
P13.7 - make a snapshot.
P14.0 - start/stop video (every transition from 1 to 0 starts or stops video recording).
P14.5 - headless mode.
Also ch9 of DM007 turns on RTH (so it is P13.4). To cancel - move right stick.
All other channels (ch5, ch6 for rate and flips) act the same as on DM007.
- IKKI
08 Oct 2015 14:02 - 08 Oct 2015 18:00 #38590
by IKKI
Great!
For your "pleasure" this is the 3015-1 model =24.84 dollars
www.eachbuyer.com/2015-new-camera-drones...or-kids-p367946.html
and my video test!
The video quality is painful and is directed downward. But at least registers and uses 8mm motors with some modifications for fpv is great!
and my video test!
Last edit: 08 Oct 2015 18:00 by IKKI.
- goebish
- NRF Weirdo
08 Oct 2015 14:19 #38591
by goebish
Ok, thank you for the reports, I'll implement the 3 protocols formats option tonight or tomorrow
- sledgehammer1570
08 Oct 2015 18:21 #38599
by sledgehammer1570
Replied by sledgehammer1570 on topic JD 395 cx-10
I have a Juncheng Mini Drone 3015-2. I tried your build. CX-10 and green protocol option but it won't bind. I've heard that there are two protocols for this quad. I believe i have the early one. Happen to know which one you got? I mean did I do something wrong or is it just different protocol.goebish wrote: Here's a test firmware for Juancheng, select Green protocol, then there are 2 extra options in protocol options, P13 and P14, ranging from 0 to 7.
- goebish
- NRF Weirdo
08 Oct 2015 18:27 #38600
by goebish
If it doesn't bind with green format option then it's another protocol.
I suppose you've tried Blue/A format too ?
Get a logic analyzer and dump the stock TX if you want me to have a look ...
Time to create page: 0.691 seconds
- JD 395 cx-10
