WLToys V912/V915/? protocols
- goebish
- NRF Weirdo
21 Mar 2015 18:17 - 21 Mar 2015 18:23 #30002
by goebish
Replied by goebish on topic WLToys V912/V915/? protocols
Ok, so that's not this simple... I think we need some RX captures (ah, you have the new version, it would have been easier with the older, I hope both are using the same protocol
), along with the fixed IDs used on the TX side.
Should be easy to figure out with that ... But don't attempt to solder wires here if you don't have the equipment or experience. I wouldn't want you to fry your RX.
Last edit: 21 Mar 2015 18:23 by goebish.
- goebish
- NRF Weirdo
21 Mar 2015 18:29 - 21 Mar 2015 18:42 #30004
by goebish
I just understood that you already did it
but those captures are kinda useless (or just more hard to exploit
) without knowing which TX ID you were using
edit: I'm stupid... tx id is in the capture (0x44871654).
Will have a look and crack that...
Last edit: 21 Mar 2015 18:42 by goebish.
21 Mar 2015 19:22 - 21 Mar 2015 19:35 #30006
Replied by PhracturedBlue on topic WLToys V912/V915/? protocols
I checked your latest data, and it shows that data came from row0 but the last 2 values are swapped.
To figure out the proper table, you need to capture the Rx after binding for 16 txids. It doesn't matter what you do with the tx other than achieve binding with the rx and then start the capture.
These are the TxIDs to use. Theoretically we only need every other one (only eight of the 16) but as the table seems hosed up, it would be safest to grab captures for all 16.
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
EDIT: I read the table wrong, number should be sequential, not multiples of 16. the above table is now correct
256
257
258
259
260
261
262
263
264
265
266
267
268
269
270
271
Last edit: 21 Mar 2015 19:35 by PhracturedBlue.
- goebish
- NRF Weirdo
21 Mar 2015 19:41 - 21 Mar 2015 19:42 #30007
by goebish
there might be another trick then, because 0x44871654 % 16 = 4, not 0.PhracturedBlue wrote: it shows that data came from row0
Last edit: 21 Mar 2015 19:42 by goebish.
21 Mar 2015 20:05 - 21 Mar 2015 20:09 #30010
which data were you looking at? I used this:
V912 RX Bind move collective.logicdata
The data I see has an id of 0x46746841 % 16 = 1 and offset = 4
However, I was only at the binding data (which uses row 0)
For the data section though, I can see it using:
69, 19, 5f, 0f, 55, 05, 9b, 4b, 91, 41, 87, 37, 7d, 2d, 73, 23
There is something weird with the A7105 where the rx listens one channel down, so assume the offset is instead 5:
adjusting for 5 gives:
6e, 1e, 64, 14, 5a, 0a, a0, 50, 96, 46, 8c, 3c, 82, 32, 78, 28
and resetting the starting point:
a0, 50, 96, 46, 8c, 3c, 82, 32, 78, 28, 6e, 1e, 64, 14, 5a, 0a
which is what we expect (note the '1e', and it is consisteltly misisng data on 0x19 (which is 0x1e) which is expected since you changed it to 0x2e.
Anyhow, my above statement stands. please run captures at the 16 txids requested. also, I recommend using the firmware without goebish's hack because it is easy to then see which channels are missing data. It may well be that the 'bug' noticed previously is only in the tx, and there is something else going on
Last edit: 21 Mar 2015 20:09 by PhracturedBlue.
- goebish
- NRF Weirdo
21 Mar 2015 20:12 - 21 Mar 2015 20:12 #30011
by goebish
Hmmm I've been staring at too much hex numbers, you're right
Last edit: 21 Mar 2015 20:12 by goebish.
- Deal57
21 Mar 2015 21:27 #30012
by Deal57
Replied by Deal57 on topic WLToys V912/V915/? protocols
I only have the one V912 TX but I have two receivers if you need more RX captures. No solder needed thanks to these little grippers for my Salea.
- goebish
- NRF Weirdo
21 Mar 2015 21:41 - 21 Mar 2015 21:43 #30013
by goebish
Make 16 rx captures with the fixed tx ids PB stated (with your devo7e as tx), with the firmware attached which has the necessary bits for v912, but "standard" rf channels table:
Last edit: 21 Mar 2015 21:43 by goebish.
- Deal57
21 Mar 2015 22:58 - 21 Mar 2015 22:59 #30016
by Deal57
OK. They all bound with no problem from the 7e. Let me know if I didn't get something right. Movie night tonight
dl.dropboxusercontent.com/u/31578062/V912%20RX%20256.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20257.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20258.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20259.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20260.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20261.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20262.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20263.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20264.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20265.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20266.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20267.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20268.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20269.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20270.logicdata
dl.dropboxusercontent.com/u/31578062/V912%20RX%20271.logicdata
Last edit: 21 Mar 2015 22:59 by Deal57. Reason: Bind details
21 Mar 2015 23:32 #30020
Thanks, The data looks good
Here is the result:
Here is the result:
file: row: sequence
256: 00: 0a 5a 14 64 1e 6e 28 78 32 82 3c 8c 46 96 50 a0
257: 01: a0 50 96 46 8c 3c 82 32 78 28 6e 1e 64 14 5a 0a
258: 02: 46 96 1e 6e 3c 8c 28 78 32 82 0a 5a 50 a0 14 64
259: 03: 6e 1e 96 46 64 14 a0 50 5a 0a 82 32 78 28 8c 3c
260: 04: 14 64 1e 6e 3c 8c 32 82 46 96 28 78 0a 5a 50 a0
261: 05: 6e 1e 64 14 a0 50 5a 0a 78 28 96 46 82 32 8c 3c
262: 06: 1e 6e 3c 8c 32 82 46 96 14 64 50 a0 28 78 0a 5a
263: 07: 8c 3c 6e 1e 5a 0a 78 28 a0 50 64 14 96 46 82 32
264: 08: 50 a0 46 96 3c 8c 28 78 0a 5a 32 82 1e 6e 14 64
265: 09: 96 46 a0 50 64 14 6e 1e 82 32 5a 0a 78 28 8c 3c
266: 0a: 64 46 96 3c 8c 50 a0 28 78 0a 5a 1e 6e 32 82 14
267: 0b: 8c 3c 96 46 64 14 82 32 6e 1e 5a 0a 78 28 a0 50
268: 0c: a0 28 78 1e 6e 32 82 46 96 0a 5a 3c 8c 14 64 50
269: 0d: a0 50 64 14 8c 3c 5a 0a 96 46 82 32 6e 1e 78 28
270: 0e: 32 82 14 64 46 96 0a 5a 50 a0 3c 8c 28 78 1e 6e
271: 0f: 5a 0a 96 46 64 14 82 32 6e 1e 78 28 8c 3c a0 50- PhracturedBlue
21 Mar 2015 23:45 #30022
The table matches the offiicial table so whatever is wrong doesn't seem to be the jump sequence.
I don't see any cases where more than one frame was missed in reception so far, so it looks like the 7e has a good connection and you shouldn't see any loss of signal. So I am not sure what is going on. I'll let goebish chime in if he sees anything odd here.
- goebish
- NRF Weirdo
22 Mar 2015 01:38 - 22 Mar 2015 13:38 #30027
by goebish
As you said, maybe this 1e->2e is just a TX bug, and that's not what makes the RX have an inconsistent link.
Deal57, just to try, here's a firmware with official table but with your stock tx id hardcoded.
www.dropbox.com/s/akluzw7i11rha51/deviat...0.1-fixedid.zip?dl=0
( gist.github.com/goebish/6bff17530af44dc1d698 )
Last edit: 22 Mar 2015 13:38 by goebish.
- goebish
- NRF Weirdo
22 Mar 2015 01:55 #30028
by goebish
SeByDocKy, maybe a capture from your V913 TX could help, looks like they're the same.
- goebish
- NRF Weirdo
22 Mar 2015 02:06 - 22 Mar 2015 02:13 #30030
by goebish
At least we know packet[17] & [18] (
what looked like a weird sequence of 10 words
) are not important because the RX reads only 17 bytes from the 21 bytes sent.
Last edit: 22 Mar 2015 02:13 by goebish.
- Deal57
22 Mar 2015 13:25 #30038
by Deal57
Binds and functions great. No hesitation or stuttering. Do you need a capture of this?
goebish wrote: As you said, maybe this 1e->2e is just a TX bug, and that's not what makes the RX have an inconsistent link.
- goebish
- NRF Weirdo
22 Mar 2015 13:28 - 22 Mar 2015 13:32 #30039
by goebish
Soooo.... it's like if this RX works well only with particular tx ids ?
Sounds weird, I think we need captures from other TXs to better understand now...
Note that this firmware should be safe, you can use it, but it's using your stock TX id, not a good idea to push that to the repo
Last edit: 22 Mar 2015 13:32 by goebish.
- goebish
- NRF Weirdo
22 Mar 2015 13:34 #30040
by goebish
Out of curiosity, make a rx capture with this working firmware ...
- Deal57
22 Mar 2015 13:38 - 22 Mar 2015 13:39 #30041
by Deal57
I don't think I mentioned it so I noticed that when I tested the 16 FixedIDs, the hesitation wasn't noticeable. I just went back and reloaded the same DFU that I used to check those TXIDs, and the collective moves perfectly. No hesitation or stutters.
So we actually have my TXID and 16 fixed IDs.
I'll get a capture of the latest one.
Last edit: 22 Mar 2015 13:39 by Deal57.
- goebish
- NRF Weirdo
22 Mar 2015 13:43 #30042
by goebish
Of course we should have asked that first
Are you just updating the dfu ? because only the .mod changes with my hacks...
So, you're saying that firmware from post #30013 is working well with fixed IDs ? Can you try it with "automatic" id ?
- Deal57
22 Mar 2015 14:11 #30045
by Deal57
The firmware from post #30013 worked fine with fixed IDs. I did not try it with an empty one. I'll do that now. If it gives us the stutters I will capture the details.
Here are two captures from the latest DFU "deviation-devo7e-v4.0.1-fixedid". The first is just the bind, and the second is bind then moving the collective. This version seems to work great, no hesitation or stutters. I checked it both with and without a fixedID and it works great.
Each update I've replaced the DFU and replaced the protocol folder contents with the accompanying .MOD files.
dl.dropboxusercontent.com/u/31578062/V91...Collective.logicdata
dl.dropboxusercontent.com/u/31578062/V91...ind%20TXID.logicdata
Time to create page: 0.289 seconds
- WLToys V912/V915/? protocols
