wk2603 help
- alba1
13 May 2015 07:52 #32485
by alba1
wk2603 help was created by alba1
hello, are a new user, I do not know if' this and the right section to ask for help, I have a radio wk-2603 and I have a receiver devo wk-rx-601, I wanted to ask if you can change the firmaware protocol in the module on radio wk2603, so I can bind with receiver ..... is possible ? thanks
13 May 2015 09:29 #32490
Replied by FDR on topic wk2603 help
Your question is a bit confusing. Are you talking about the DEVO RX601 receiver?
If so, that is a DEVO receiver and cannot be used with the WK-2603.
The old WK-2603 transmitter is not supported by deviation (none of the old Walkera transmitters are), and you can't replace it's fw to support the DEVO (or DSM, etc) receivers...
- alba1
13 May 2015 15:48 #32497
by alba1
Replied by alba1 on topic wk2603 help
but if I install magic cube, it should work right? but if I changed the firmware module walkera putting firmware module devo 7, it does not work?
13 May 2015 16:23 #32500
Yes the magic cube should work, but it has low output power.
The firmware of the WK2603 is not upgradable at all.
- alba1
13 May 2015 16:54 #32507
by alba1
you have the firmware module devo 7, I want to try to load the module wk 2603, i program with avr usb programmer, I think it is only the module firmware and not the radio devo 7
13 May 2015 18:20 #32516
It wouldn't work, because the WK2603 doesn't have the same hardware as the DEVO 7...
- alba1
13 May 2015 18:51 #32519
by alba1
ah ok , sin, I had taken the RX 601 by mistake, I thought it went well for wk 2603, I now have a radio receiver and a different ......
- alba1
13 May 2015 18:55 #32520
by alba1
and upgrade firmware on rx 601 ? firmware rx walkera on rx devo ...is possible? , i see rx 26xx and rx devo rx 601 have identical chip atmega
13 May 2015 18:56 #32521
Now is a good time to buy a DEVO transmitter for your already existing DEVO receiver!
Then you could use deviation to control almost everithing, including your existing 2603 compatible Walkera stuff...
- alba1
13 May 2015 19:14 #32522
by alba1
another radio? nooooooooooo , i have 4 radio , turnigy 9x , wlakera 2603 , wltoys for v666 , dx7 , and fryshy .......sorry five
13 May 2015 19:36 - 13 May 2015 19:36 #32523
Well, with a few additional RF modules you might have one radio instead of that four sorry five...
Last edit: 13 May 2015 19:36 by FDR.
- alba1
13 May 2015 20:15 #32526
by alba1
the strange thing that I ask is that the firmware supports deviation walkera rx and rx d evo, but I can not load the firmware on the radio, I opened the module and chip and cyrf6936
13 May 2015 20:22 #32527
Yep, the RF chip is the same, that's why a DEVO radio with deviation fw can control the old WK stuff, but the rest of the electronics are completely different.
Even the microcontroller is different, so no wonder you can't run deviation on it.
- alba1
13 May 2015 20:28 #32528
by alba1
ok FRD , very thanks for your support ...... i shop new radio devo ......or new rx walkera ......but devo 7 old version support rx 601? no devo 7e but devo 7
13 May 2015 20:55 #32529
Replied by PhracturedBlue on topic wk2603 help
yes, the devo7 will support a rx601, but it will not support anything else. You cannot run Deviation on a Devo7. If you are thinking of buying a Devo radio, I strongly recommend staying away from the Devo7.
- alba1
13 May 2015 21:11 #32530
by alba1
what do you recommend to buy radio or the devo? do not spend a lot .....
13 May 2015 21:21 #32531
sadly there aren't many options at the moment. Walkera has moved primarily to support the F12E and Devo12E and seems to have little interest in anything else. The Devo7e is the cheapest of the Walkera Devo radios that can support Deviation. It is a good choice for a tight budget or for someone who wants a small/light-weight transmitter.
Time to create page: 0.309 seconds
- wk2603 help
