MoonTop M9916
- goebish
- NRF Weirdo
28 Jul 2015 03:40 - 28 Jul 2015 04:59 #36220
by goebish
Replied by goebish on topic MoonTop M9916
Test firmware (should also work with EAchine H7 & MoonTop M9912):
7e: www.dropbox.com/s/ubu9wpe4o1idclk/deviat...v4.0.1-mt99.zip?dl=0
10: www.dropbox.com/s/q4cp5muri3lsbp9/deviat...v4.0.1-mt99.zip?dl=0
sources: bitbucket.org/goebish/deviationtx/branch/EAchine_H7#commits
Protocol name: MT99
Ch 5: rate (3 positions)
Ch 6: flip
Ch 7: snapshot
Ch 8: video
Ch 11: pitch trim
Ch 12: roll trim
Note that if Ch 11 & 12 are not configured, neutral trim values are used
Protocol name: MT99
Ch 6: flip
Ch 7: snapshot
Ch 8: video
Ch 11: pitch trim
Ch 12: roll trim
Last edit: 28 Jul 2015 04:59 by goebish.
- belowtheradar
16 Aug 2015 14:34 #36946
by belowtheradar
Replied by belowtheradar on topic MoonTop M9916
I was not able to make this version bind with an H7.
The one you've posted about 6 weeks ago (with Protocol H7) works.
Would you mind posting your model.ini?!
Thank you very much!
- goebish
- NRF Weirdo
16 Aug 2015 16:16 #36949
by goebish
Ok, I have an idea why it wouldn't work, Ill check tonight.
Maybe I'll remove mt99xx as nobody seems to really be interested (nobody has tested in 6 weeks ...)
- belowtheradar
16 Aug 2015 16:39 - 16 Aug 2015 16:42 #36950
by belowtheradar
Probably too few know about it. Perhaps you should crosspost it to rcgroups?!
www.rcgroups.com/forums/showthread.php?t=2412599
There is actually a link to your other/previous thread on here, the one about H7 support.
It was posted by SeByDocKy about 6 weeks ago:
www.rcgroups.com/forums/showthread.php?t=2412599&page=16
Last edit: 16 Aug 2015 16:42 by belowtheradar.
- SeByDocKy
17 Aug 2015 05:42 #36964
by SeByDocKy
Sorry, I didn't see your answer
I will test asap
Replied by SeByDocKy on topic MoonTop M9916
goebish wrote: Ok, I have an idea why it wouldn't work, Ill check tonight.
- SeByDocKy
17 Aug 2015 06:12 #36965
by SeByDocKy
Ok I tested with my devo7E .... and I got a "bas/missing protocol modules"... no problem for other nRF24L01 protocols ...
- belowtheradar
17 Aug 2015 06:54 #36967
by belowtheradar
I also get the 'missing protocol' message.
Also, please don't forget to add your model.ini
so we can see how you've configured the 3-way switch for ch.5
- goebish
- NRF Weirdo
17 Aug 2015 11:57 #36972
by goebish
Thanks for the reports ... I'll check what I did wrong, probably just a typo somewhere or forgot to replace H7 with MT99xx module name as it works on my Devo 10.
- Durete
17 Aug 2015 12:29 #36973
by Durete
Replied by Durete on topic MoonTop M9916
Same problem here. A few days ago I merged your protocol with my local repo. I got the same missing module error but since I'm not expert, and nobody report the error, I guessed was my mistake
- goebish
- NRF Weirdo
17 Aug 2015 14:32 #36979
by goebish
I had a quick look and I don't understand what's wrong... Note that if you're using an old .ini from the first H7 version it won't work because I changed the protocol name from H7 to MT99 (you can even delete h7.mod from your protocol folder, it's not used anymore), can you check that you selected the MT99 protocol ?
@belowtheradar, your nickname makes me think of that vid.carbuzz.com/this-is-how-things-roll-...e-ukraine-right-now/
- goebish
- NRF Weirdo
17 Aug 2015 15:16 #36982
by goebish
Or maybe that's because I named the protocol MT99 and the Devo 7e module file is named mt99xx (I had to remove 2 characters or it wouldn't build before last PB code size optimization).
Check that you've the right protocol selected first, if you're still having the same issue I'll rename it.
- belowtheradar
17 Aug 2015 15:33 #36983
by belowtheradar
Since there is no H7 protocol in this version, I changed it to MT99.
But the H7 does not bind.
Nice video by the way.
- goebish
- NRF Weirdo
17 Aug 2015 15:34 #36984
by goebish
Do you have the "bad/missing protocol modules" message ?
- belowtheradar
17 Aug 2015 15:39 #36985
by belowtheradar
I get it once I have installed this firmware image.
Since I've replaced it again with your H7 version from six weeks ago, I am not sure
if I still get it once I've changed the protocol to MT99. But binding is not possible.
- SeByDocKy
17 Aug 2015 16:19 #36986
by SeByDocKy
Bingo
goebish wrote: Or maybe that's because I named the protocol MT99 and the Devo 7e module file is named mt99xx (I had to remove 2 characters or it wouldn't build before last PB code size optimization).
Bingo
- goebish
- NRF Weirdo
17 Aug 2015 16:46 #36989
by goebish
You mean you manually renamed the .mod then it works ?
SeByDocKy wrote: Bingo
- SeByDocKy
17 Aug 2015 17:30 #36990
by SeByDocKy
Yes .... it's binding but .... behaviour so so eratic..... throttle do nothing after sometimes yes ... Maybe some delay
There is modulo to give ?
- goebish
- NRF Weirdo
17 Aug 2015 17:31 - 17 Aug 2015 17:34 #36991
by goebish
Ok, so I'll rename this file (or protocol, that will be simpler
)... are you testing with the mt9916 or h7 ?
Can you check with both please ?
Last edit: 17 Aug 2015 17:34 by goebish.
- belowtheradar
17 Aug 2015 18:17 #36992
by belowtheradar
Just tried it again on the H7:
After renaming the protocol to mt99 (removing the xx) I can bind.
Then I had to switch Aileron with elevator.
There are two issues however:
Aileron works only to the right.
Moving the stick to the left makes almost no difference from the middle position.
When switching to USB-Mode it hangs when turning USB Mode off again.
I have to turn the 7e off and on again.
- goebish
- NRF Weirdo
17 Aug 2015 18:21 #36993
by goebish
Maybe this has something to do with protocol trims, check if Ch11 & 12 are in middle position.
No idea for the USB issue, I doubt this has something to do with this protocol.
belowtheradar wrote: Just tried it again on the H7:
Time to create page: 0.371 seconds
- MoonTop M9916
