SPI capture guide
- C0ckpitvue 777
17 Apr 2016 21:23 #46720
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic SPI capture guide
Can someone please confirm if this capture is flawed or correct,all feedback and help is well appreciated.
www.mediafire.com/download/a7jftawe9s11y...On+Capture.logicdata
I'm capturing spi for the sj x300-2 quadcopter
www.mediafire.com/view/b38895fz888pe97/sj%20x300-2.JPG#
Inside of the quad
www.mediafire.com/view/9dg6m9j3kqsbmr0/image%282%29.jpeg#
www.mediafire.com/view/gtfaj4z2rz5jak9/image.jpeg#
www.mediafire.com/view/rp1oihm8o5pezow/image%283%29.jpeg#
Inside of the quad
- wukong
- Caerus
24 Dec 2016 01:00 - 24 Dec 2016 01:12 #57182
by Caerus
Replied by Caerus on topic SPI capture guide
Ok, first capture ever. MOSI, MISO and GND were clearly marked. There were only 2 viable options left for CLK and CS, and from what I've read and seen here they are visually very different. I think I differentiated them correctly. Would someone mind checking this first one before I continue? Goebish, do you want this straight in the H20 thread? Cheers
www.mediafire.com/file/dsd8l2m4hds5zxe/J....Then.Bind.logicdata
Last edit: 24 Dec 2016 01:12 by Caerus.
- goebish
- NRF Weirdo
24 Dec 2016 01:06 - 24 Dec 2016 01:10 #57183
by goebish
Replied by goebish on topic SPI capture guide
Looks fine
Yes, you can post directly in the H20 thread.
Last edit: 24 Dec 2016 01:10 by goebish.
- Caerus
24 Dec 2016 01:20 #57184
by Caerus
Ahhh, that warm and fuzzy feeling
. K, thanks goebish. I've been up forever, so I'll do all the other captures when I wake up next year
- lani
22 Mar 2017 13:24 #60521
by lani
Replied by lani on topic SPI capture guide
I'd like to share a small piece of python proven useful for processing the Saleae hex CSV exports to a form where each packet is on separate row instead of each byte.
Opening the resulting CSV into excel can be then used e.g. for plotting the different bytes in the frame upon time. Very handy IMO.
#!/usr/bin/env python
import csv
# open file and create reader
with open('input.csv', 'rb') as f:
with open('output.csv', 'w') as o:
reader = csv.reader(f, delimiter=',', quotechar='"', skipinitialspace=True)
# read header
header = reader.next()
printstr = ""
current_packageid = 0
bytecount = 0
for row in reader:
new_packageid = row[1]
new_time = row[0]
new_byte = row[2]
if new_packageid != current_packageid:
o.write(str(bytecount) + "," + printstr + "\n")
printstr = new_time + "," + str(new_packageid)
current_packageid = new_packageid
bytecount = 0
#print in decimal so excel understands
printstr += "," + str(int(new_byte, 16))
bytecount += 1
# print last line
if printstr != "":
o.write(str(bytecount) + "," + printstr + "\n")- mwm
22 Mar 2017 16:41 #60540
Replied by mwm on topic Sigrok nrf decoder?
Anyone tried out the sigrok nrf24l01 decoder module?
sigrok.org/wiki/Protocol_decoder:Nrf24l01
- goebish
- NRF Weirdo
22 Mar 2017 16:44 #60541
by goebish
Replied by goebish on topic Sigrok nrf decoder?
Yes it works, but I still prefer our good old python scripts
- Fernandez
02 Mar 2018 21:01 #67857
by Fernandez
Replied by Fernandez on topic Sigrok nrf decoder?
Hi I tried my chinese salae logic 8 clone but have difficulties getting it to work, can someone confirm, that it still works? Is it a driver issue, or salae did damaged my clone ?
I tested different versions, device is detected as "logic", when starting a capture, it mentions it can't keep up with the selected sample rate.
Anybody can give some hints to get it work, I rarely use it......
- goebish
- NRF Weirdo
02 Mar 2018 21:03 #67858
by goebish
Can you try with another computer and/or with another USB cable ?
- 52dgj
03 Mar 2018 10:03 #67875
by 52dgj
Replied by 52dgj on topic SPI capture guide
dc59大大,请问你知道mc6的协议吗?如果知道可以告诉一声吗?谢谢了
- dc59
03 Mar 2018 12:28 #67878
by dc59
很抱歉,我沒有買MC6所以對它使用的協定不是很清楚!
I'm sorry, I don't know about the protocol of MC6 TX due to I didn't buy it.
Replied by dc59 on topic SPI capture guide
52dgj wrote: dc59大大,请问你知道mc6的协议吗?如果知道可以告诉一声吗?谢谢了
- manotroll
05 May 2018 14:31 #69066
by manotroll
Replied by manotroll on topic SPI capture guide
can i use the oscilloscope to debug the spi?
Hantek 6022BE
Hantek 6022BE
06 May 2018 00:29 #69070
Replied by hexfet on topic SPI capture guide
Not with that one. A logic analyzer is the best tool for this.
- manotroll
16 May 2018 00:41 #69249
by manotroll
right
I had a protocol that works, I'll see if I can make funsionar and test others
Bayang X16 AH
Bayang X16 AH
- Bangdc
20 Apr 2022 04:33 #77948
by Bangdc
Replied by Bangdc on topic SPI capture guide
Dear Goebish,
could you help me take a look at this thread when you have time? www.deviationtx.com/forum/protocol-devel...tx-use-xn297lbw-chip
Thank you.
Thank you.
Time to create page: 0.099 seconds
- SPI capture guide
