JJRC H20 Hex Quad
23 May 2017 20:34 #62512 by goebish
Replied by goebish on topic JJRC H20 Hex Quad
Nice, glad it works !
Are controls reversed for H20 mini and H30 mini or only the H30 ? Also, which channels, pitch/roll/yaw ?
I'll fix that in code.
23 May 2017 21:00 #62514 by Caerus
Replied by Caerus on topic JJRC H20 Hex Quad
Just the H30... pitch and roll. Yaw is normal.
So what's next on the list? :)
23 May 2017 23:09 #62516 by goebish
Ok, I'll add different protocol options for H20 mini and H30 mini then.
Next on the list are Hubsan (I have to work on H502S, and it seems their latest H501 firmware update wreaks havoc when used with deviation). Then I told I would have a look at Mjx Bugs 3.
But as summer is here I spend more time flying than hacking ;)
24 May 2017 10:27 #62522 by goebish
@Caerus, I updated the test build, it has H20 Mini and H30 Mini format options now, please check both, I'll make a pull request once you confirm they're fine.
www.dropbox.com/sh/d1v07zxqop6w0gi/AAB5k...wIUPRPq-47TzAra?dl=0
27 May 2017 08:17 #62598 by Caerus
goebish wrote: @Caerus, I updated the test build, it has H20 Mini and H30 Mini format options now, please check both, I'll make a pull request once you confirm they're fine.
Yup, perfecto. Flips (blergh) work. I don't know if headless mode or the generally useless RTH is ever implemented. If it is I can check.
Enjoy your summer. Don't stop too much to work for us nerds ;). GO FLY!
27 May 2017 08:43 #62600 by goebish
Thanks for testing !
And yeah, I'll enjoy my latest build ;)
imgur.com/a/sSn0R
imgur.com/a/kRIsH
30 May 2017 13:51 #62701 by wasp09
Replied by wasp09 on topic JJRC H20 Hex Quad
What is that FC?
BTW, thank you for adding the yaw deadzone for H20H. It is in the stream now.
30 May 2017 13:52 #62702 by goebish
The FC is a Piko BLX (20x20 holes), by Furious FPV.
01 Jun 2017 00:59 #62733 by goebish
... and yet another one, I swear I'm not addicted, I can stop whenever I want :whistle:
imgur.com/a/kblWf
3D printed frame
Motors: 0703 20000KV
tinyPEPPER 4in1 4A/1S ESC
tinyFISH FC (F3, built-in FrSky Rx)
01 Jun 2017 13:59 #62745 by wasp09
Impressive, your scale shows 2 decimal digits and less than 50g for a FPV BL quad. :cheer:
It is about the same weight as my brushed Q90s with lemon sats. My BL multirotors are 300g and over.
20 Mar 2019 20:01 #73454 by SilbernerSurfer
Replied by SilbernerSurfer on topic JJRC H20 Hex Quad
I have bought a JJRC H20 from BG.
I have tried to bind it with my Taranis and a iRange module.
I have used the H8 3D protocol.
It doesnt work! The JJRC H20 binds immedistely to the stock Tx, so there shouldnt be a problem with the quad itself.
Any ideas?
21 Mar 2019 00:56 #73461 by wasp09
Mime is a H20H. If I remember correctly, it is an auto hold hexa. Do you have the same thing?
We have to keep the stick at centre at the start.
21 Mar 2019 03:59 #73465 by SilbernerSurfer
No, mine is the H20 without height hold.
21 Mar 2019 23:22 #73498 by wasp09
Can't help you then.
Time to create page: 0.216 seconds
