The New Hubsans
- delta75
20 Jan 2016 06:33 - 20 Jan 2016 06:37 #41964
by delta75
Replied by delta75 on topic The New Hubsans
i have question
i didn't connect RXEN to GND on a7105 chip
( www.deviationtx.com/forum/how-to/1228-fl...th-pics-devo-8s#4423 )
Do you need to connect it to the telemetry data received? ?
www.deviationtx.com/forum/3-feedback-que...4-will-not-fly#37950
and.. can you make devo F12e firmware?
Last edit: 20 Jan 2016 06:37 by delta75.
- goebish
- NRF Weirdo
20 Jan 2016 09:11 - 20 Jan 2016 09:13 #41968
by goebish
Ok, I'll revert my last changes and try to make a F12e build later today.
Replied by goebish on topic The New Hubsans
This is the old wiring, now you've to connect RXEN > GIO2 and TXEN > GIO1 for better telemetry range.delta75 wrote: i didn't connect RXEN to GND on a7105 chip
Last edit: 20 Jan 2016 09:13 by goebish.
- goebish
- NRF Weirdo
20 Jan 2016 10:12 - 20 Jan 2016 12:08 #41970
by goebish
Here's a test build for Devo F12e, based on ebed853, note this is the first time I build for this system, I was able to build the .dfu but I've no idea if it does work or it's stable or not ...
www.dropbox.com/s/x0rjuiddtfpn9yk/Devof12e_ebed853.zip?dl=0
Last edit: 20 Jan 2016 12:08 by goebish.
- delta75
- goebish
- NRF Weirdo
21 Jan 2016 11:14 - 21 Jan 2016 13:22 #42033
by goebish
Perfect, that's how it's supposed to be connected
New test build, with some telemetry data:
Devo 7e
Devo 10
Devo F12e
source
Note that I'm using FrSky telemetry model, so I couldn't fit all the data (distance, roll and pitch are missing) and I doubt the values will be displayed correctly, but let's see if we're receiving some data ...
Maybe the Hubsan protocol would deserve his own telemetry model (we only have Devo, DSM and FrSky right now), but I've to check what has to be done, and this could be an issue for 7e because of restricted flash size.
Devo 7e
Devo 10
Devo F12e
source
Last edit: 21 Jan 2016 13:22 by goebish.
- delta75
21 Jan 2016 16:11 - 21 Jan 2016 16:29 #42037
by delta75
how to view telemetry data
376eb99 version bind connection ok
telemetry voltage not change ,
devo10 shown only 0 v , not change , not work telemetry voltage , i changed newer wiring type (TXEN -> GPO1 , RXEN -> GPO2)
devo7e telemetry voltage data ok! , i don't change wiring , it use old wiring type (TX EN -> VDD)
Last edit: 21 Jan 2016 16:29 by delta75.
- goebish
- NRF Weirdo
21 Jan 2016 16:14 #42038
by goebish
You can't for now, that's what I explained in the previous post
- delta75
21 Jan 2016 16:26 #42039
by delta75
ok~
this version has no bind connection problem
- delta75
22 Jan 2016 10:23 - 22 Jan 2016 10:40 #42063
by delta75
devof12e firmware don't work
i use deviation uploader 0.8.0
can not upload firmware file
F12e firmware file list different to Nightly Builds firmware
your firmware file not included model, layout ... many directorys and files
i update Nightly Builds 2016-01-16 version
Last edit: 22 Jan 2016 10:40 by delta75.
- goebish
- NRF Weirdo
22 Jan 2016 15:41 #42079
by goebish
Sorry, but I'm not sure what to do for the F12e, I've some errors during build, at least the .dfu is generated, but no filesystem...
(it complains about f7 stuffs ?)
I'll see what I can do for telemetry values ...
- tommet
26 Jan 2016 00:37 - 26 Jan 2016 00:38 #42219
by tommet
I'm using this with a H107c Plus with Devo 7e and it appears to be working well.
Replied by tommet on topic The New Hubsans
AndyRC wrote: I have modded my model.ini file for the devo 7e for the x4 plus
headless is now on Hold switch. Flip on Fmod
video record is on up button
snapshot is on down button
cheers
Last edit: 26 Jan 2016 00:38 by tommet.
- delta75
28 Jan 2016 01:23 #42299
by delta75
hello, long time no see
can you make GPS number telemetry?
it need gps hold function and RTH.
because necesery gps number bigger than 6.
- goebish
- NRF Weirdo
28 Jan 2016 01:48 #42301
by goebish
I'll see what I can do in the week-end
- delta75
11 Feb 2016 06:01 #42982
by delta75
hello~
if you make newer firmware?
- goebish
- NRF Weirdo
11 Feb 2016 09:10 #42994
by goebish
Yes, I remember I've to complete telemetry
Are you sure you can't get sat count ?
I'm not sure where it should be displayed, but I already set GPS info and it's supposed to be there.
- HappyHarry
24 Mar 2016 16:06 #45098
by HappyHarry
Replied by HappyHarry on topic The New Hubsans
hi guys, been out of the loop for a while and the missus just bought me a new toy, so does this protocol now support the newest hubsan h107d+ FPV >>
www.hubsan.com/productinfo_20.html
if so is this protocol in the latest nightly (f5d851e) as i've just upgraded but i'm unable to bind to the quad
- goebish
- NRF Weirdo
24 Mar 2016 16:10 - 24 Mar 2016 16:11 #45099
by goebish
It's supposed to work, can you check your a7105 module with another protocol ?
deviationtx.com/forum/protocol-developme...bsans?start=80#41497
Last edit: 24 Mar 2016 16:11 by goebish.
- HappyHarry
24 Mar 2016 17:36 #45103
by HappyHarry
it works ok with my original X4, is there a particular stick position for binding as this one has a sprung throttle that defaults to center stick
- goebish
- NRF Weirdo
24 Mar 2016 17:39 #45104
by goebish
That's weird, can you try the build from this thread:
deviationtx.com/forum/protocol-developme...bsans?start=40#40807
There's nothing special to do.
- HappyHarry
24 Mar 2016 17:41 #45106
by HappyHarry
i will do after taking the dog out, i'll give you a shout back later this evening, thanks for the help
Time to create page: 0.997 seconds
- The New Hubsans
