Flysky AFHDS 2A, protocol as used i10, i6, iT4,
- Fernandez
15 Jun 2017 08:15 #63002
by Fernandez
Replied by Fernandez on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
At least I can confirm that in my case Betaflight + ibus + failsave it works, but only way to do it is to setup the failsave, per channel inside the Tx. So when link lost throttle will go down to zero. (or any predefined value as you like). Not sure if it is a real Betaflight failsave, but at least no signal = my motors stop.
Before setting failasave in Tx (while by default) , at signal loss, it continue sending last received value.......(=dangerous)
- magic_marty
15 Jun 2017 16:54 #63008
by magic_marty
Replied by magic_marty on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
After you set up failsafe on your tx did you have to rebind to the rx before it would work?
- goebish
- NRF Weirdo
15 Jun 2017 17:04 - 20 Jun 2017 16:46 #63009
by goebish
Replied by goebish on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
Failsafe settings are sent regularly every few seconds, it should work instantaneously, no need to rebind or even switch the receiver off/on.(but of course you'll have to switch off the transmitter to check if it works as expected
Last edit: 20 Jun 2017 16:46 by goebish.
- magic_marty
15 Jun 2017 17:07 #63010
by magic_marty
So i goto channel failsafe and set it to -125 on throttle and it should drop the throttle when i power off my tx?
Or i can set the Aux channel i have set to Arm and it would dis-arm when powering off the tx?
- goebish
- NRF Weirdo
15 Jun 2017 17:13 #63011
by goebish
If you're arming with an AUX channel then yes, better use that.
Or if you're using cleanflight / betaflight, go to the failsafe tab (enable expert mode) to configure channel value below 950µs as invalid and set failsafe to -125% on any channel on the Devo.
- magic_marty
15 Jun 2017 17:29 #63012
by magic_marty
On betaflight when watching the receiver inputs and powering off the tx they all hold and none drop like expected..
I'll do some more testing before i do any test hover ect..
I set my Aux channel that i use to arm at - value ant tested it and it seems to be working with a 2 second delay which is better then before it just keep running..
- Arise
20 Jun 2017 14:32 - 20 Jun 2017 14:33 #63055
by Arise
Replied by Arise on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I would like to connect to a x6b receiver, I've soldered the wires to it and set Address field to 0x08000000 and Size to 0x8000.
Then I was able to connect, but when I hit save to dump the firmware (bin file) I get an error.
It seems if I try with a hex file dump it works, it produces a 78KB file.
Anything wrong I'm doing?
I powered the x6b also from USB device (STLink) from 5V pin, should that be an issue?
Please look at the attachements...
Last edit: 20 Jun 2017 14:33 by Arise.
- goebish
- NRF Weirdo
20 Jun 2017 14:50 #63056
by goebish
I'm not sure what the problem is... but if you can produce a .hex file without error then that's fine.
- Arise
20 Jun 2017 16:44 #63057
by Arise
I had to downgrade to ST-Link Utility 3.9.0 from 4.0 and now I can dump the firmware successfully.
- magic_marty
20 Jun 2017 17:06 #63058
by magic_marty
Anybody figured out a simple way to get the RSSI out of the X6B rx to an OSD?
- goebish
- NRF Weirdo
20 Jun 2017 17:10 - 20 Jun 2017 17:12 #63059
by goebish
That's possible with the x6b with betaflight + osd (built-in or minimosd ...)
set the LQI Output protocol option to a free channel and setup betaflight to use this channel as RSSI in the receiver tab.
www.deviationtx.com/forum/protocol-devel...-it4?start=480#62318
Last edit: 20 Jun 2017 17:12 by goebish.
- magic_marty
20 Jun 2017 17:25 #63060
by magic_marty
Will the LQI still be available on the tx for alarms ect..?
- goebish
- NRF Weirdo
20 Jun 2017 17:36 #63061
by goebish
Yes.
- magic_marty
21 Jun 2017 06:34 #63067
by magic_marty
Thanks for all your help and hard work i setup the LQI to ch8 and then proceeded to setup Betaflight to display RSSi and wala it works! Matches my tx LQI display ...Quick question sometimes my telemetry displays turn red but no alarms are triggered cause nothing drops below the settings i have set to sound alarm, then after a few seconds they go back to the normal white display..Any idea what could be causing it?
- goebish
- NRF Weirdo
21 Jun 2017 08:54 #63071
by goebish
That's because your Tx doesn't receive telemetry data for a few seconds, check your antenna.
Also, if you've one of the firsts x-in-1, the LNA is not working for the nrf24l01 and the a7105, this is a known issue, this has been fixed in the last revisions.
- magic_marty
21 Jun 2017 16:27 #63077
by magic_marty
Any way to tell if i have one of the early ones? I bought it Dec30th 2016..And got another one for my other tx on Mar 19th 2017..
- goebish
- NRF Weirdo
21 Jun 2017 16:29 #63078
by goebish
Sorry, no idea, you should ask in the 4-in-1 thread.
- magic_marty
21 Jun 2017 17:32 #63079
by magic_marty
Both modules i have are doing it but it rarely happens so not to worried about it as long as if don't affect the range of the control inputs..
- anthony7288
25 Jun 2017 00:15 - 25 Jun 2017 00:15 #63115
by anthony7288
Replied by anthony7288 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
anyone try to read firmware RX fs A8S ?
www.banggood.com/Flysky-FS-A8S-2_4G-8CH-...utput-p-1092861.html
Last edit: 25 Jun 2017 00:15 by anthony7288.
- michel49
21 Jul 2017 13:06 #63545
by michel49
Replied by michel49 on topic Flysky AFHDS 2A, protocol as used i10, i6, iT4,
I can see alittle difference between the FS and Turnigy Rxs: I can read "Sbus" on the upper connector of the iA6b but I can't run my Corona Sbus servos; is there a way to fix ?
MP
MP
Time to create page: 0.503 seconds
- Flysky AFHDS 2A, protocol as used i10, i6, iT4,
