Fayee FY805 captures
- goebish
- NRF Weirdo
20 Mar 2017 20:14 #60448
by goebish
Replied by goebish on topic Fayee FY805 captures
@Bisky, I just added a 7e ultimate test build.
- SeByDocKy
20 Mar 2017 20:30 #60450
by SeByDocKy
Replied by SeByDocKy on topic Fayee FY805 captures
Flips are working .... didn't test headless ... but should work
- yets
20 Mar 2017 20:35 #60451
by yets
Replied by yets on topic Fayee FY805 captures
Goebish, you are amazing. I'm hoping to Silverxxx firmware the board, hopefully it'll all work.
- goebish
- NRF Weirdo
20 Mar 2017 20:36 #60452
by goebish
Credits go to Pascal for this sub-format
- yets
20 Mar 2017 20:57 #60453
by yets
Well props to Pascal too! What a great community
- Bisky
22 Mar 2017 09:35 #60504
by Bisky
Devo F7 XMS + 4in1 module
Replied by Bisky on topic Fayee FY805 captures
Flashed the TX, can't say its working for me, I can't bind. I heave the same problem with CG022, I also found out that ASSAN dosn't bind every time. I don't get any module error on boot up, but i think the mm1.3 is not working as it should.
- goebish
- NRF Weirdo
22 Mar 2017 11:57 #60512
by goebish
Might be an issue with your nrf24l01, try lowering output power.
- Bisky
22 Mar 2017 18:11 #60551
by Bisky
@goebish
That was my idea to, could it be a supply problem?
- goebish
- NRF Weirdo
22 Mar 2017 18:13 - 22 Mar 2017 18:21 #60552
by goebish
Can you measure 3.3V while this protocol is in use ?
edit: but yes, if you're only using the stock 7e regulator that's probably a power supply issue, that's a known issue ... take care because your regulator degrades over time.
Last edit: 22 Mar 2017 18:21 by goebish.
- Bisky
22 Mar 2017 18:29 #60553
by Bisky
I only use stock supply, will ad aditional ams1117.
Thanks.
Thanks.
- goebish
- NRF Weirdo
22 Mar 2017 18:33 #60555
by goebish
Also, you can use the nightly, it's been merged.
- Bisky
22 Mar 2017 19:04 #60557
by Bisky
You rock!
- Bisky
04 Apr 2017 19:29 - 04 Apr 2017 19:34 #61171
by Bisky
Added AMS1117 to power the MM1.3, problems with NRF24L01 remains
ASSAN binds only if u select some other protocol and then Assan and pres bin, if already selected bind dos not work
CG023 does not bind
FY805 does not bind
HISKY binds always model HFW 400(it uses A7105?)
Regards, Bojan
CG023 does not bind
FY805 does not bind
Regards, Bojan
Last edit: 04 Apr 2017 19:34 by Bisky.
- llinde
24 Jun 2017 19:02 #63112
by llinde
Replied by llinde on topic Fayee FY805 captures
My son and I both have Devo 10 and FY 805.
When one of us is flying no problem, but as soon as we both try fly the problems arise.
When the second FY 805 is switched on it is still normal, is does not bind to the Devo that is already on.
As soon as the second Devo is switched on and bound the problems occur.
Both Devo's are bound to both FY805, but flying is impossible, everything is very slow not even enough to lift off.
We tried with and without fixed id, but no result.
- goebish
- NRF Weirdo
24 Jun 2017 20:28 #63113
by goebish
That's expected as there's only one hardcoded transmitter ID for this sub-protocol.
Dump your 2 stock transmitters if you want me to fix that
Time to create page: 0.122 seconds
- Fayee FY805 captures
